There is alot of red(bad) ways now. but will have a closer look later or.
Red is weak or a low quality signal. Might be suffering from interference. You might also have a WiFi overlap issue going on. The Zigbee channel may have changed after you swapped from Deconz.
I’ve been trying to figure out how to do that. Thanks! One question though. If I’m using a Conbee2 stick, do I use deconz_config: instead of ezsp_config:?
It appears ZHA only allows lights and sockets/switches in their groups so I use both ZHA and yaml for sensor groups.
“lights, switches, and fans” according to ZHA docs, most commonly used as a light group for lightbulbs:
https://www.home-assistant.io/integrations/zha
“There is also support for grouping of lights, switches, and fans (i.e. support for commanding device groups as entities). At least two entities must be added to a group before the group entity is created. As well as support for binding/unbinding (i.e. bind a remote to a lightbulb or group).”
https://www.home-assistant.io/integrations/zha#binding-and-unbinding
Yes.
A recommendation is to read and follow all of these general tips:
and also general tips in:
https://github.com/home-assistant/home-assistant.io/pull/18864 → https://github.com/home-assistant/home-assistant.io/pull/18864/commits/b21c49589d898d60a1a235afa7b9c148d013cfee
what’s the reason behind moving from deconz to zha? Is zha better in any way?
I had some issues with Deconz and thought it was worth a try.
OSRAM/ LEDVANCE devices are infamously known for having poor radio reception and transmission.
They are also infamously known for not wanting to act as Zigbee router devices for many other brands.
