Western Digital My Cloud
One way to get info from the device is by using ssh.
So on the Home Assistant machine, first make ssh keys. Then appropriately locate and permission these files, and make a back up of them.
Next enable ssh on the WD Dashboard (RTFM > Configuring Settings > Network :grin:).
Log in to the WD as the ssh user and create a .ssh directory, permissioned as 700. Within that create a file named ‘authorized_keys’, permissioned as 600, and copy/paste the public key part of the ssh files pair, into here.
Next back up the .ssh directory:
tar -cvzf /shares/<username>/ssh_backup.tar.gz .ssh
Every time the WD reboots, it wipes the directory, so you’ll need to manually ssh in and restore the ssh directory:
tar -xvzf /shares/<username>/ssh_backup.tar.gz
Not ideal, but then it isn’t often that it needs a reboot.
With that done, back up the tar.gz file, to somewhere off the device.
Next test connecting using the keys, over ssh:
ssh -i <path_to_private_key_file> <ssh_user>@<device_ip_or_hostname>
… and accept when the confirmation happens.
Once the ssh part is working, the next task is to get the data. Here’s what I have in my sensors.yaml file:
- platform: command_line
  unit_of_measurement: '°C'
  command: ssh -i <path_to_private_key_file> -o StrictHostKeyChecking=no -q <ssh_user>@<device_ip_or_hostname> fan_control -g 0 | grep CPU | cut -d' ' -f 2 | cut -d'=' -f 2
# NAS Board Temperature
  command: ssh -i <path_to_private_key_file> -o StrictHostKeyChecking=no -q <ssh_user>@<device_ip_or_hostname> fan_control -g 0 | grep Current | cut -d' ' -f 4
# NAS HD0 Temperature
  command: ssh -i <path_to_private_key_file> -o StrictHostKeyChecking=no -q <ssh_user>@<device_ip_or_hostname> fan_control -g 0 | grep hd0 | cut -d' ' -f 2 | cut -d'=' -f 2
# NAS HD1 Temperature
  command: ssh -i <path_to_private_key_file> -o StrictHostKeyChecking=no -q <ssh_user>@<device_ip_or_hostname> fan_control -g 0 | grep hd1 | cut -d' ' -f 2 | cut -d'=' -f 2
# NAS HD2 Temperature
  command: ssh -i <path_to_private_key_file> -o StrictHostKeyChecking=no -q <ssh_user>@<device_ip_or_hostname> fan_control -g 0 | grep hd2 | cut -d' ' -f 2 | cut -d'=' -f 2
# NAS HD3 Temperature
  command: ssh -i <path_to_private_key_file> -o StrictHostKeyChecking=no -q <ssh_user>@<device_ip_or_hostname> fan_control -g 0 | grep hd3 | cut -d' ' -f 2 | cut -d'=' -f 2
# NAS Fan RPM
  unit_of_measurement: 'rpm'
  command: ssh -i <path_to_private_key_file> -o StrictHostKeyChecking=no -q <ssh_user>@<device_ip_or_hostname> fan_control -g 4 | cut -d' ' -f 4
# NAS SMART Status
  command: ssh -i <path_to_private_key_file> -o StrictHostKeyChecking=no -q <ssh_user>@<device_ip_or_hostname> /usr/local/sbin/getSmartStatus.sh
# NAS Firmware Status
  command: ssh -i <path_to_private_key_file> -o StrictHostKeyChecking=no -q <ssh_user>@<device_ip_or_hostname> /usr/local/sbin/getNewFirmwareAvailable.sh | sed 's/"//g' | sed 's/no upgrade/current/g'
# NAS Disk Space Total
  unit_of_measurement: 'kB'
  command: ssh -i <path_to_private_key_file> -o StrictHostKeyChecking=no -q <ssh_user>@<device_ip_or_hostname> df | sed -n '/HD_a2/s/ \+/ /gp' | cut -d' ' -f 2
# NAS Disk Space Used
  command: ssh -i <path_to_private_key_file> -o StrictHostKeyChecking=no -q <ssh_user>@<device_ip_or_hostname> df | sed -n '/HD_a2/s/ \+/ /gp' | cut -d' ' -f 3
# NAS Disk Space Free
  command: ssh -i <path_to_private_key_file> -o StrictHostKeyChecking=no -q <ssh_user>@<device_ip_or_hostname> df | sed -n '/HD_a2/s/ \+/ /gp' | cut -d' ' -f 4
# NAS Disk Space Percent Used
  unit_of_measurement: '%'
  command: ssh -i <path_to_private_key_file> -o StrictHostKeyChecking=no -q <ssh_user>@<device_ip_or_hostname> df | sed -n '/HD_a2/s/ \+/ /gp' | cut -d' ' -f 5 | sed 's/%//g'
# NAS CPU Usage
  command: ssh -i <path_to_private_key_file> -o StrictHostKeyChecking=no -q <ssh_user>@<device_ip_or_hostname> mpstat | sed -n '/all/s/ \+/ /gp' | cut -d' ' -f 12 | sed 's/%//g'
# NAS RAM Total
  command: ssh -i <path_to_private_key_file> -o StrictHostKeyChecking=no -q <ssh_user>@<device_ip_or_hostname> free -m | sed -n '/Mem:/s/ \+/ /gp' | cut -d' ' -f 2
# NAS RAM Used
  command: ssh -i <path_to_private_key_file> -o StrictHostKeyChecking=no -q <ssh_user>@<device_ip_or_hostname> free -m | sed -n '/buffers:/s/ \+/ /gp' | cut -d' ' -f 3
# NAS RAM Free
  command: ssh -i <path_to_private_key_file> -o StrictHostKeyChecking=no -q <ssh_user>@<device_ip_or_hostname> free -m | sed -n '/buffers:/s/ \+/ /gp' | cut -d' ' -f 4
# NAS RAM Cached
  command: ssh -i <path_to_private_key_file> -o StrictHostKeyChecking=no -q <ssh_user>@<device_ip_or_hostname> cat /proc/meminfo | sed -n '/Cached/s/ \+/ /gp' | head -n 1 | cut -d' ' -f 2
# NAS Swap Total
  command: ssh -i <path_to_private_key_file> -o StrictHostKeyChecking=no -q <ssh_user>@<device_ip_or_hostname> free -m | sed -n '/Swap/s/ \+/ /gp' | cut -d' ' -f 2
# NAS Swap Free
  command: ssh -i <path_to_private_key_file> -o StrictHostKeyChecking=no -q <ssh_user>@<device_ip_or_hostname> free -m | sed -n '/Swap/s/ \+/ /gp' | cut -d' ' -f 4
# NAS Swap Used
  command: ssh -i <path_to_private_key_file> -o StrictHostKeyChecking=no -q <ssh_user>@<device_ip_or_hostname> free -m | sed -n '/Swap/s/ \+/ /gp' | cut -d' ' -f 3
# NAS Swap Cached
  command: ssh -i <path_to_private_key_file> -o StrictHostKeyChecking=no -q <ssh_user>@<device_ip_or_hostname> cat /proc/meminfo | sed -n '/SwapCached/s/ \+/ /gp' | cut -d' ' -f 3
# Some derived values
  sensors:
    nas_cpu_perc_used:
      friendly_name: NAS CPU Usage
      value_template: "{{ (100 - states('sensor.nas_cpu_idle')|float) | round(1) }}"
    nas_ram_perc_used:
      friendly_name: NAS RAM Usage
      value_template: "{{ ((states('sensor.nas_mem_used')|int / states('sensor.nas_mem_tot')|int) * 100) | round(1) }}"
    nas_swap_perc_used:
      friendly_name: NAS Swap Usage
      value_template: "{{ ((states('sensor.nas_swap_used')|int / states('sensor.nas_swap_tot')|int) * 100) | round(1) }}"
Edit:
  • Added sensors
  • I had a quick look at the WD MyCloud API’s and there’s nothing there (that I can see) about getting this kind of information from the device, rather it’s more about file handling, geared at application integration.
