WHAT am i doing wrong - RS485 Modbus
Ah your right, thats another thing i wanted tofind out is how would i change the type?
You will need to create a number i think: Modbus Controller Number — ESPHome
number:
  - platform: modbus_controller
    modbus_controller_id: reader1
    address: 0x0020
    value_type: U_WORD
    min_value: 0
    max_value: 3
I’m used to using the modbus integration since i only use network based controllers and i just use a service call for these kind of settings.
That sorta worked, but the unit starts to reboot itself every time now.
I am trying to get a reading from all of these in order and the #'s dont seem right. I found the correct pdf for my sensor which has way more features.
updated code
uart:
  tx_pin: 1
  rx_pin: 3
  baud_rate: 9600
  stop_bits: 1
  parity: NONE
  data_bits: 8
  # debug:
  #   direction: RX
  #   dummy_receiver: false
  #   after:
  #     delimiter: "\n"
  #   sequence:
  #     - lambda: UARTDebug::log_string(direction, bytes);
modbus:
  flow_control_pin: 4
modbus_controller:
  - id: reader1
    address: 0x01
    modbus_id: modbus1
    setup_priority: -10
    update_interval: 2s
    # id: flow
    register_type: read
    # register_count: 2
    address: 0x0000
    response_size: 2
    # accuracy_decimals: 3
    value_type: U_WORD
    # unit_of_measurement: "°C"
    # accuracy_decimals: 1
    # filters:
    #   - multiply: 256
    # id: flow
    register_type: read
    # register_count: 2
    address: 0x0001
    response_size: 2
    value_type: U_WORD
    unit_of_measurement: "VWC"
    # filters:
    #   - multiply: .01
    # id: flow
    register_type: read
    # register_count: 2
    address: 0x0002
    response_size: 2
    value_type: U_WORD
    unit_of_measurement: "us/cm"
    # filters:
    #   - multiply: .01
    # id: flow
    register_type: read
    address: 0x0003
    response_size: 2
    value_type: U_WORD
    unit_of_measurement: "mg/L"
    # filters:
    #   - multiply: .01
    # id: flow
    register_type: read
    address: 0x0004
    response_size: 2
    value_type: U_WORD
    # filters:
    #   - multiply: .01
    # id: flow
    register_type: read
    address: 0x0005
    response_size: 2
    value_type: U_WORD
    # filters:
    #   - multiply: .01
    # id: flow
    register_type: holding
    address: 0x0020
    # register_count: 2
    response_size: 2
    value_type: U_WORD
    # unit_of_measurement: "mg/L"
    # filters:
    #   - multiply: .01
When i start with the 1st sensor reading, temp i get the correct one. but then once i start adding moisture, es, etc everything goes wacky. even temp does not have a reading. soil type keeps changing instead of it being 0,1,2, or 3 and is def not the correct output . not sure how to use register count or size in my case and still havnt figured out how to set the soil type
[11:42:44][D][sensor:127]: 'soil_meter_temp': Sending state 0.00000  with 0 decimals of accuracy
[11:42:44][D][modbus_controller.sensor:025]: Sensor new state: 30806.00
[11:42:44][D][sensor:127]: 'soil_meter_moisture': Sending state 30806.00000 VWC with 0 decimals of accuracy
[11:42:44][D][modbus_controller.sensor:025]: Sensor new state: 44474.00
[11:42:44][D][sensor:127]: 'soil_meter_ec': Sending state 44474.00000 us/cm with 0 decimals of accuracy
[11:42:44][D][modbus_controller.sensor:025]: Sensor new state: 28680.00
[11:42:44][D][sensor:127]: 'soil_meter_salinity': Sending state 28680.00000 mg/L with 0 decimals of accuracy
[11:42:44][D][sensor:127]: 'soil_meter_tds': Sending state 30806.00000 mg/L with 0 decimals of accuracy
[11:42:44][D][sensor:127]: 'soil_meter_episilon': Sending state 44474.00000 mg/L with 0 decimals of accuracy
[11:42:45][D][modbus_controller.sensor:025]: Sensor new state: 2338.00
[11:42:45][D][sensor:127]: 'soil_meter_soiltype': Sending state 2338.00000  with 0 decimals of accuracy
[11:42:46][D][modbus_controller.sensor:025]: Sensor new state: 0.00
[11:42:46][D][sensor:127]: 'soil_meter_temp': Sending state 0.00000  with 0 decimals of accuracy
[11:42:46][D][modbus_controller.sensor:025]: Sensor new state: 30806.00
[11:42:46][D][sensor:127]: 'soil_meter_moisture': Sending state 30806.00000 VWC with 0 decimals of accuracy
[11:42:46][D][modbus_controller.sensor:025]: Sensor new state: 44474.00
[11:42:46][D][sensor:127]: 'soil_meter_ec': Sending state 44474.00000 us/cm with 0 decimals of accuracy
[11:42:46][D][modbus_controller.sensor:025]: Sensor new state: 28680.00
[11:42:46][D][sensor:127]: 'soil_meter_salinity': Sending state 28680.00000 mg/L with 0 decimals of accuracy
[11:42:46][D][sensor:127]: 'soil_meter_tds': Sending state 30806.00000 mg/L with 0 decimals of accuracy
[11:42:46][D][sensor:127]: 'soil_meter_episilon': Sending state 44474.00000 mg/L with 0 decimals of accuracy
[11:42:48][D][modbus_controller.sensor:025]: Sensor new state: 2338.00
