why you use after sunset and also between 19 and 23?
is indentation like this?
- alias: "Motion Kitchen"
initial_state: True
hide_entity: False
platform: event
event_type: motion
event_data:
entity_id: binary_sensor.motion_sensor_158d000127acc3
condition:
condition: or
conditions:
- condition: sun
after: sunset
- condition: numeric_state
entity_id: sensor.Esszimmer_Miflora_light_intensity
below: 100
- service: switch.turn_on
entity_id: switch.kitchen
The time condition is still in because I’m currently working on my automations I think I can remove it but I guess especially in the summer when it is longer bright outside it might make sense…
it might be good if you have animals:
PIR triggered, AND is 3am in the night NO action
you may want to keep the light off, and not on because of a cat walking
this is not good for me: since I switch a 433MHz transmitter (Broadlink TC2), every few seconds I see the RMPRO firing the signal ON
I need help with this script:
- alias: Turn on lights after sunrise, when no movement, when doors open
- platform: state
entity_id: binary_sensor.home__door
to: 'on'
condition:
condition: and
conditions:
- condition: sun
event: sunset
offset: "-00:45:00"
- condition: state
entity_id: binary_sensor.home__motion
state: 'off'
service: homeassistant.turn_on
entity_id: light.yeelight_lights_1
As you can see, I want to turn on lights, when door is open, after sunrise, when no motion is detected. Only problem, that I get error:
Invalid config for [automation]: extra keys not allowed @ data['condition'][0]['conditions'][0]['event']. Got None
extra keys not allowed @ data['condition'][0]['conditions'][0]['offset']. Got None
not a valid value for dictionary value @ data['condition'][0]['conditions'][0]['condition']. Got None
required key not provided @ data['condition'][0]['conditions'][0]['entity_id']. Got None. (See /config/configuration.yaml, line 415). Please check the docs at https://home-assistant.io/components/automation/
see here and scroll down to sun conditions:
it says you need to use “after_offset:”
