I’m getting an error for my Spotify secret. I changed it, and I still get the error. I took my secret to haveibeenpwned.com and I don’t get a warning on the site. Something seems wrong.
I tried that solution, but in that case I receive a notification that a notification has been blocked, so not useful…
Thanks anyway.
As suggested by @123, I have blocked (temporarely?) api.pwnedpasswords.com
via AdGuard coming from HA IP
Do you see the comment at the end of the automation?
“Remove this after testing?”
Did you remove “this”?
Ops!
I haven’t noticed the comment and the code to remove…
I will try now.
Thanks!
May I ask how you did this?
I have installed Adguard in HA and added api.pwnedpasswords.com and haveibeenpwned.com to the custom filters section but I am still getting the nag notifications.
am I missing an install step in Adguard or putting the site in the wrong section?
Thank You.
I’ve solved using this code:
https://community.home-assistant.io/t/opt-out-of-pwned-secrets-warnings/286394/24
and removing the code after the comment
# Remove this after testing :-)
My Adguard problem was down to my stupidity. Would have helped if I had pointed HA IP4 DNS entry to the same IP as HA (which of course Adguard is running on).
I tried to change the mosquitto password, but it doesn’t work (also changed in mqtt devices) I tried to uninstall and reinstall the addon but it doesn’t work. Anyone have a solution? Maybe you need to delete some files, but I don’t know which one. (sorry for my English)
I had to play around with it too.
Try removing the user password option in the MQTT configuration. Then either set up a new HA user or use another HA user credentials. The broker allows access to all home assistant users.
Thanks, it worked.
