I think i tried that before and changed it to on, and still didn’t go. I then compared it to your setup, you had the empty line, changed that, et voila, automation ran fine for the first time…
Just to understand completely: initial_state: ‘off’ implies one can set it to ‘on’ somewhere . How could one do that then, other than changing in the code? Isn’t this where the slider comes in?
I must say it not very nice that on each boot it sets the alarm to the initial time in the settings, rather than the time one had it set to before booting. Would that be even possible to do, have it remember the last time set somehow?
Should get back on this, thanks for the nudge, and no, i hadn’t seen that before. Tbh, I didn’t create the alarm clock myself… copied the package from @mviezzer while working on the Summary card…
What could be the advantage of this technique, and, could you help me changing that input? how would i get that in the frontend?
I must say i find your alternative condition value template much easier to read and saved that for future implementation! thanks.
Ah ok. I like the sliders and I never used the input_datetime. Don’t even know what it looks like.
There probably isn’t an advantage if you already have something set up. My guess is that so many people have datetime requirements and this is a UI element that returns a datetime object with a nice interface. It would just make setup and automations easier to implement.
Instead of having your sliders and a sensor that gets both slider info, you would have 2 datetimes.
Then you’d remove your sliders and sensor. Then use this for your time auotmation value_template:
now().hour == states.input_datetime.weekend.hour and now().minute == states.input_datetime.weekend.minute
Most of the other stuff would be the same. In the end, your interface would have a Time UI element and a On/Off instead of the Time Sensor UI element, On/Off toggle, Hour Slider, and Minute Slider.
