quickly checked and this is amazing, using weather info instead of light sensor! will try it out. thanks!
Time zone is only part of the story.
That same time zone will run at all latitudes from the north pole to the south. Time zones are based generally on longitude and geopolitical basis.
Sun elevation is determined by your exact location.
On this page
Is your location set correctly on the map?
Thanks! I was using some config in yaml file and so disabled from the UI. Now I have updated and should be good.
