Wher do I enter lines for a sensor in yaml file
Yep lines like sensor: on the first indentation only need to be entered once then every other instance of the same type goes under that heading.
Like this
  - platform: wifi_signal
    name: "WiFi Signal Sensor"
    update_interval: 60s
  - platform: dht
    pin: D4
    temperature:
      name: "Kitchen Temperature"
      filters:
        - offset: -4.5
    humidity:
      name: "Kitchen Humidity"
    #  filters:
      #  - offset: 44
  - platform: bh1750
    name: "Kitchen Illuminance"
    address: 0x23
    update_interval: 300s
i2c:
  - id: bus_a
    sda: D2
    scl: D1
    scan: true
binary_sensor:
  - platform: gpio
    pin: D5
    device_class: motion
web_server:
  port: 80
  version: 2
  include_internal: true
  ota: true
You will see it has a sensors heading with all sensors after it then i2c: with those settings then binary_sensor: with those setting and so on. When you get to grips with it it is easy, And also easy to get wrong :grinning:
After I placed a - in front of platform, then saved and validated it says :slight_smile:
Failed config
esphome: [source /config/esphome/esphome.yaml:2]
  platform: ESP32
  Could not find board 'esp32s'. Valid boards are alksesp32, bpi-bit, d-duino-32, esp-wrover-kit, esp32-devkitlipo, esp32-evb, esp32-gateway, esp32-poe, esp32-poe-iso, esp32-pro, esp320, esp32cam, esp32dev, esp32doit-devkit-v1, esp32thing, esp32vn-iot-uno, espea32, espectro32, espino32, featheresp32, firebeetle32, fm-devkit, frogboard, heltec_wifi_kit_32, heltec_wifi_lora_32, heltec_wifi_lora_32_V2, heltec_wireless_stick, hornbill32dev, hornbill32minima, intorobot, iotaap_magnolia, iotbusio, iotbusproteus, lolin32, lolin_d32, lolin_d32_pro, lopy, lopy4, m5stack-core-esp32, m5stack-fire, m5stack-grey, m5stick-c, magicbit, mhetesp32devkit, mhetesp32minikit, microduino-core-esp32, nano32, nina_w10, node32s, nodemcu-32s, odroid_esp32, onehorse32dev, oroca_edubot, pico32, pocket_32, pycom_gpy, quantum, sparkfun_lora_gateway_1-channel, tinypico, ttgo-lora32-v1, ttgo-t-beam, ttgo-t-watch, ttgo-t1, turta_iot_node, vintlabs-devkit-v1, wemos_d1_mini32, wemosbat, wesp32, widora-air, xinabox_cw02.
  board: esp32s [source /config/esphome/esphome.yaml:4]
My board is a ESP32-WROOM-32, and was ok at one time with another yaml file!!
That error is coming from this configuration:
esphome:
  platform: ESP32
  board: esp32s
Do you know what board you’re using?
ESP32 has a good number of boards:
It says to use the default of “esp32dev”, so change out “esp32s” for “esp32dev” and try recompile.
Yes I do know what board I am using see the last line above.
If I only have 1 sensor included, the BH1750, it validates without error, but when I add the BME280 sensor there are loads of errors , and I don’t know if they should be indented or not.
I am putting the lines in the same place as the BH1750
Can you please tell what is wrong:
  platform: bh1750
  name: "BH1750 Illuminance"
  address: 0x23
  platform: bme280
  temperature:
  #  name: "BME280 Temperature"
  oversampling: 16x
  pressure:
  #    name: "BME280 Pressure"
  humidity:
   #   name: "BME280 Humidity"
  address: 0x77
ERROR Error while reading config: Invalid YAML syntax:
Duplicate key “platform”
in “/config/esphome/lounge .yaml”, line 18, column 3:
platform: bme280
NOTE: Previous declaration here:
in “/config/esphome/lounge .yaml”, line 11, column 3:
platform: bh1750
I should have been clearer. ESP32-WROOM-32 is the chipset on the board, but the PCB/board will be something different.
When the manufacturer of the board lays out the PCB and names the pins, they don’t always follow the ping layout of the WROOM-32 chipset and hence you can have mapping or identification errors, or the inputs/outputs can vary. Also this tells the compiler what features are available on the board and ESP32. This is why each board has a specific name.
As a test, please change “board: esp32s” to “board: esp32dev” and just see if it compiles better.
For reference, I have a ESP32-WROOM-32 here too, and it’s configured as esp32dev and working fine.
I would say you need something more like this
  - platform: bme280
    temperature:
      oversampling: 16x
    pressure:
    humidity:
    address: 0x77
see
remember the - before platform the - means everything after it is one device till it sees another -
without it you will have too many platforms etc
Oh, and I also have a BME280 compiling ok with this YAML:
    name: "Shed-Sensor WiFi Signal Sensor"
    update_interval: 5s
  - platform: uptime
  - platform: bme280
    temperature:
      name: "Shed-Sensor Temperature"
      accuracy_decimals: 2
Try follow that layout.
@Arh
your lines didn’t compile either:
while parsing a block mapping
  in "/config/esphome/lounge .yaml", line 1, column 1:
    esphome:
expected <block end>, but found '<block mapping start>'
  in "/config/esphome/lounge .yaml", line 17, column 2:
     -platform: bme280
But with only 1 sensor , BH1750, it compiles no problem???
@Arh
I’m on the verge of giving up , as it is one thing after another. What compiled with 1 sensor, now throws up another error
You need to.post you whole yaml code each time you ask a question as I have No idea what is on line 17 without it. It would solve far quicker if we had all your code.
Ok thanks, that is what I will do now.
mapping values are not allowed here
  in "/config/esphome/lounge .yaml", line 18, column 16:
        temperature:
esphome:
  platform: ESP32
  board: esp32dev
wifi:
  ssid: "xxxxxxxxxx "
  password: "xxxxxxxx"
  platform: bh1750
  address: 0x23
  platform: bme280
    temperature:
      oversampling: 16x
    pressure:
    humidity:
    address: 0x77
  name BME280
i2c:
  - id: bus_a
    sda: GPIO4
    scl: GPIO5
    scan: true
#ap:
 #  ssid: "Lounge  Fallback Hotspot"
  # password: "xxxxxxxxxx"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: "xxxxxxxxl"
You shouldn’t :stop_sign:
Just give yourself 10 minutes and READ the BASICS about YAML. After that take a deep breath and read the Error messages in detail why your yaml syntax is wrong. :page_facing_up:
Your problems are all related and in a nutshell I would say it’s because you are not (fully) aware how the syntax of yaml is :man_teacher:
I found this tutorial helpfiul YAML Tutorial: Everything You Need to Get Started in Minutes | Cloudbees Blog
I think @Rob_Heselwood you need to change setup like so; instead of
  platform: x
  platform: y
Try this
  - platform: x
  - platform: y
I have created another yaml file, and the board name esp32dev compiles in 1 file but not another. Also In the new file I added just the BME680 sensor, and it compiled without error. But in another file it doesn’t.
Expected integer, but cannot parse 0x77 update_interval:60s as an integer.
  address: 0x77 update_interval:60s
This is for the BME680 sensor which I copied from the example
Untill you put the “-” in it will not work. Please read again what I wrote.
:thinking:
I did that and it still did not compile.
Anyways thanks for your time and help.
I’ll try with an arduino board, that should be easier.
Once again no yaml.
Here you go compiles fine. If you cant see where the changes are there is no hope.
esphome:
  platform: ESP32
  board: esp32dev
wifi:
  ssid: "xxxxxxxxxx "
  - platform: bh1750
    address: 0x23
  - platform: bme280
    temperature:
      oversampling: 16x
    pressure:
    humidity:
    address: 0x77
i2c:
  - id: bus_a
    sda: GPIO4
    scl: GPIO5
    scan: true
#ap:
captive_portal:
# Enable logging
logger:
api:
ota:
Took me less than a minute to format. but it really was - and indentation. RTFM
