Where should I install HA OS?
Hello everyone,
I purchased a mini PC (Intel NUC) where I installed Home Assistant OS on it and it’s working just fine!
At first that was the only thing I was planning to do but I figured after that I wanted to host a plex server as well
I did found an addon on Home Assistant that I installed and configured and it’s running fine but I feel like it’s not the best way to do it.
I’ve read that I cannot add libraries from external disk (only sources from the current disk where Plex Server is installed) in my case a 128GB SSD…
What would be your advice to host both HA & Plex Server + Transmission (or any other torrent client) on a MINI PC NUC ?
Should I install Windows + Plex Server + a VM with HA on it ?
Thanks for your help
Proxmox is probably the easiest way
and use some scripts from here
https://tteck.github.io/Proxmox/
Next version of HA will allow you to connect external disks
If you are looking for a “Home Server” have a look at CASA OS This is very fancy user friendly front end to Docker and Samba shares . Will allow you to run Plex , HA and many other useful programs as docker images.
