Thanks for this idea. Reading the Bayesian documentation it sounds like it would be a sensor per room. Therefore it could identify multiple rooms. Have you found a way to combine them to identify the room that a person is in? Or, am I overthinking this?
Bluetooth would be the way to do presence detection by person/device in my opinion.
Thereās a Room-assistant addon and Bluetooth tracking integration Iām not familiar with
, but check out this post:
Thatās right.
I had motion sensors in each room anyway, and I added Bluetooth proxies with the Bermuda integration to track phone and watch.
But thereās also time of day - 4am and Iām probably in the bedroom, and so on - and things like the Xbox - if itās on, thereās a good chance Iām in the study. If you think about it, thereās quite a lot of data you can use.
I have a Bayesian calculation for each room giving the probability of it being occupied (probability is an attribute of the binary sensor), and a template to pick the room with the highest probability.
The thing is, it doesnāt have to be 100% for it to work. Quite often, Iāll be in the living room, say, watching TV, with my phone charging in the kitchen, the dog wandering around and the Xbox left on downloading a game. Iāll get something like:
- Kitchen 52%
- Living room 84%
- Study 31%
The template will say (correctly) that Iām in the living room.
Thank you for the informaiton on the Bayesian integration. I read through the documentation.
I have not found however a situation where, when I know there are only two people in a home*, and motion is sensed in two different rooms within seconds of each other, to then automatically know to just turn off the lights in all of the other rooms. Given the WAF and other factors (such as a guest mode turned on which would have it ignore any such logic), it is unfortunate but custom programming is the best way in such a situation as there are too many custom considerations to take into accountā¦
Since this is all done āon a shoestring budgetā, all sensors are PIR and I am unable to differentiate between human and pet, erring on the side of caution is always best practice
What Bluetooth proxies do you recommend?
Iāve been using M5Stack Atom Lite, primarily because theyāre small and they come in a case.
@ariznaf do you have any experience with
Thanks!
