I’m not sure what you mean with the statistics of the devices. If you mean the recorder data, that is only in regards to entities not devices. Merging the devices will simply move all entities from one device to another and disable the entity-less device. This process will not change anything about the entities and recorder data should therefore be kept.
Ability to add text (static custom attributes), number (static custom attributes); link media (e.g. for device pictures or custom icons) or calendar to a specific device would be great. This is a semantic grouping thing
The support for yaml never existed. That was the issue that was being investigated. It was an error in the PR description that made it’s way to the beta release notes. So the release notes were corrected to signify that it’s UI only.
Well, nutz! I was looking forward to employing this feature but all of my Template entities are defined in YAML.
Template helpers don’t currently support all available options (for example, a Template Binary Sensor helper only supports three out of about a dozen options) and are limited to sensor and binary_sensor (no support for trigger-based either) so that’s why I continue to define them in YAML.
Anyways, hopefully Template helpers will eventually be fully fleshed out so I can migrate and take advantage of this new feature.
FWIW, it’s a bit surprising that an advanced feature like appending a Template Binary Sensor to an existing device is introduced to the least feature-complete variation (i.e. helper). In contrast, it’s already possible to assign an MQTT entity to an existing device using YAML.
In the current Home Assistant structure, it is possible to create or link a device with just one config entry. Template entities created via YAML do not have a configuration entry.
So it is not an option not to extend it to entities via YAML config, the developers were willing, but it is not compatible.
That sounds correct to me. The MQTT integration is responsible for handling publish/subscribe and needs to be present to allow MQTT entities (sensor, binary_sensor, lock, etc) to work. The MQTT integration is installed via the UI.
However, when configuring an MQTT entity in YAML, if it is referencing the MQTT integration’s config entry, then that’s transparent to the user. Each MQTT entity is free to define its own device or be part of another device.
Anyways if you feel it’s not possible then so be it. I will have to wait until Template Sensor/Binary Sensor helpers get feature parity with their more capable YAML cousins (before I can migrate what I have). Currently they only support a fraction of the available options (and don’t support the Trigger-based variety at all).
Template helper entities configured via YAML are not linked to a config entry.
What you mention is an entity registry (core.entity_registry file) and not a config entry (core.config_entries file).
The fact is that the current structure of Home Assistant makes it unfeasible to link devices to template helpers configured via YAML. Can this change? It can, but it is very unlikely that they will make such a complex and structural change to meet such a specific use case.
None of the assigned entities have an entry in core.config_entries file either so I don’t get the explanation or don’t see the tree in the woods.
Those have entries in core.entity_registry only as well and assigned by mentioned device_id. Same as exposure is done (via should_expose) or areas assigned via area_id, …
I would bet if a reload of the template would not clear the device_id, a set device_id to an existing device_id would bring it to the device on the UI, wouldn’t it?
