Why can't we add template entities to existing devices?
Correct me if I’m wrong, but MQTT integration has a configuration entry (connection to the broker). Only entities are configured via YAML.
That sounds correct to me. The MQTT integration is responsible for handling publish/subscribe and needs to be present to allow MQTT entities (sensor, binary_sensor, lock, etc) to work. The MQTT integration is installed via the UI.
However, when configuring an MQTT entity in YAML, if it is referencing the MQTT integration’s config entry, then that’s transparent to the user. Each MQTT entity is free to define its own device or be part of another device.
Anyways if you feel it’s not possible then so be it. I will have to wait until Template Sensor/Binary Sensor helpers get feature parity with their more capable YAML cousins (before I can migrate what I have). Currently they only support a fraction of the available options (and don’t support the Trigger-based variety at all).
What do you mean exactly? Really would like to understand.
Template entities have config entires as well ofc.
core.entity_registry
{“aliases”:,“area_id”:“ha_steuerung”,“categories”:{},“capabilities”:null,“config_entry_id”:null,“device_class”:null,“device_id”:null,“disabled_by”:null,“entity_category”:null,“entity_id”:“sensor.foo_bar”,“hidden_by”:null,“icon”:null,“id”:“ididid”,“has_entity_name”:false,“labels”:,“name”:null,“options”:{“conversation”:{“should_expose”:false},“cloud.alexa”:{“should_expose”:false},“cloud.google_assistant”:{“should_expose”:false}},“original_device_class”:null,“original_icon”:“mdi:toggle-switch”,“original_name”:“foo bar”,“platform”:“template”,“supported_features”:0,“translation_key”:null,“unique_id”:“unique_id_template_sensor_unix_tag_gerade_oder_ungerade”,“previous_unique_id”:null,“unit_of_measurement”:null},
Without this is shouldn’t be possible to assigne categories, areas, exposure to voice, … And exactly there is the link to devices as well: device_id
Template helper entities configured via YAML are not linked to a config entry.
What you mention is an entity registry (core.entity_registry file) and not a config entry (core.config_entries file).
The fact is that the current structure of Home Assistant makes it unfeasible to link devices to template helpers configured via YAML. Can this change? It can, but it is very unlikely that they will make such a complex and structural change to meet such a specific use case.
None of the assigned entities have an entry in core.config_entries file either so I don’t get the explanation or don’t see the tree in the woods.
Those have entries in core.entity_registry only as well and assigned by mentioned device_id. Same as exposure is done (via should_expose) or areas assigned via area_id, …
I would bet if a reload of the template would not clear the device_id, a set device_id to an existing device_id would bring it to the device on the UI, wouldn’t it?
It wouldn’t work, a configuration entry is still required for it to work.
this still only doable via helpers?
all my templates are defined in yaml and I’d like to associate those to existing devices (similar to the new helper way…)
UI only.
is there an existing feature request we can vote on to extend to YAML? a device_id property or something would be wonderful
