Why doesn't the supervisor integration create addon devices?
It does… I have a device per addon, don’t you?
As for the slug, that’s fair. You can get to the slug but it’s not common knowledge and could definitely be easier. I do it in this blueprint. Assuming you have a variable called entity that contains the id of an entity made by the supervisor integration for an addon you can get to the slug with this template:
{{ (device_attr(entity, 'identifiers') | first)[1] }}
