You can do it directly from the home assitant gui now. This should convert it.
I do not seem to have this option…
is your configuration.yaml still as it is above, in regards to MQTT entries?
Unfortunately I am not using my Davis weather station anymore as it died so I switched to a Weatherflow by Tempest. You can try by clicking on the entity on your dashboard, then the gear in the upper right to change the settings.
yes I have done that, but I do not have unit option, unfortunately.
Hm, sorry not sure how to help. Maybe try to find some other posts on the community to figure out how to convert it.
well, it would seem that by not including the “°” in °F would be the cause for a lack or options for temperature units. Including the ° has now allowed me to switch between °F and °C.
I have been making progress with implementing MQTT and my Davis weather station into home assistant. One area of struggle is adding the daily min/max values. Anything I try comes up with unknown. I can see the values when I listen to MQTT. Anyone have any suggestions to present daily min/max values?
