Will Low Cost ESP8266 4 Channel Power Monitor Work With ESPHome?
Did you only use the good old incandescent “heat” bulbs with a power factor of 1 or also other types like CFL or LED? :twisted_rightwards_arrows:
“real” in terms of real/true power which is typically measured in Watts? :zap:
Also any information/specifications about the plug power meter you used? :page_facing_up:
The “high power” source wasn’t by accident a pure restive load (so again pf=1) :question:
So you are actually calculating (or “guessing”) the apparent power (kVA) actually and not the real power (W) :warning:
As a hint: Power companies usually only bill private individuals for the “useful work” = real/true power :beers:
Thanks @orange-assistant for comprehensive feedback… really useful to know. So would you be enclined to say that the most accurate and cost effective way is to get, say, 3 or 4 of these to hook up to your consumer unit (mains and the optional circuits you want to monitor)? How many can you run of a single ESP32 such as a D1 mini?
Good question. I think there is no “hard” limit but by the looks of it 10 are already somewhat troublesome:
I run 4 pzem004t v3’s on a esp32 with ethernet (in the past I used a esp8266 d1 mini for it) and they just work :tm:
Yes, just hook the coils/clamps up to the circuits/machines you want to monitor - no rocket science :man_scientist::rocket:
The most cost effective way I think yes - the most accurate probably not. But in my opinion it certainly features the (by far) best accuracy per buck :money_mouth_face:
Thanks again for your suggestions @orange-assistant, parts are on order!
Did you only use the good old incandescent “heat” bulbs with a power factor of 1 or also other types like CFL or LED ?
yes both
Any information/specifications about the plug power meter you used?
Chacon power meter
was mixed, I turned on several things at home up to 2A@240v
Well I do not need to verify if my energy seller is cheating me. I need to turn off high power equipment when solar production is <less then consumed.
As a hint: Power companies usually only bill private individuals for the “useful work ” = real/true power
thanks for the accurate tip, I will check in future with a pzem how much is that difference
Actually the power factor is often printed on products and depending on the country you are living there is even regulations “forcing” a minimum power factor :chart_with_upwards_trend:
For example if you have a led light with a power factor of 0.5 your apparent power readings will actually show double (:x::two::warning:) of the real power :zap:
Companies with high consumption often get billed for the apparent power consumption btw. :slot_machine:
I love to read the discussion and the progress but I still feel a bit lost how to build such a PZEM-004T based one.
I am also wondering, if you can replace such coil with that clamp used here cause getting such coils into the cabinet is a lot more challenging considering that I would have to remove every measured line from the board inside.
Thanks for any further hints to find such esp based product to buy or build.
