Will Xiaomi sensors connect to VeraPlus?
I have that with even some ZWAVE devices - Fibaro button for one, can see how to get the 5 different types of button presses exposed to HA… for the rest Vera has been solid as a ZWAVE hub. At the minute it also relays all my RF light switches to HA just fine. No idea why the Fibaro 101 is such a pain. Thanks for the reply though. How on earth did you manage to connect it? I’ve reset and and then start the pairing and keep pressing the pairing button, done that too many times to count. Considering going the conbee route.
I have some ZWAVE sensors loose connection from time to time so even ZW is not always the answer…
I might have been lucky and for some reason this aqara zigbee sensor paired with my vera secure in the first try. I did have to pair it as generic zigbee device
I have some door sensors with included temperature sensors on my vera plus that the temperature doesn’t get pulled in to HA but the door sensor does. I’m using node red to get the temperature then put it in to HA from node red. It’s worth a shot if you want to try to use those sensors.
