(post deleted by author)
Cool, yeah I should have provided some instructions. The easiest thing to do would be get the wink.py from my branch (you can just copy and paste) and put it into a wink.py inside of your configuration directory/custom_components/
Then you need to remove everything from your configuration under wink:
so it is empty.
And then, restart HA and you should end up with a Wink configuration button on the frontend, follow the directions there and see what happens.
So far it seems that you have to be on the same local network as your HA box for this to work, and you have to access the redirect URL via IP address not a hostname (if you have one setup)
Also found that if you have problems with the auth, it may help to open a desktop session on the host itself and run the authorization in the browser on the host. I struggled with it until @w1ll1am23 suggested this and it worked on my Pi.
Hi, just wondering what you are to use for a Website and Redirect URL on the Wink API application form if you donβt have a website?
The redirect URL is the local address of your HA box. For example 192.168.1.5:8123/auth/wink/callback would be a valid one. If you are running the new version of the file wink.py
the configurator will walk you through what needs done.
Thanks Iβll give that a try.
Hi guys, having the same problem as you all with the token. Iβve tried the wink.py file linked above and now Iβm getting the following:
Jul 12 19:38:14 centbox scl[25022]: 2017-07-12 19:38:14 INFO (MainThread) [homeassistant.loader] Loaded wink from custom_components.wink
Jul 12 19:38:15 centbox scl[25022]: 2017-07-12 19:38:15 INFO (Thread-5) [homeassistant.util.package] Attempting install of python-wink==1.2.6
Jul 12 19:38:21 centbox scl[25022]: 2017-07-12 19:38:21 INFO (MainThread) [homeassistant.setup] Setting up wink
Jul 12 19:38:21 centbox scl[25022]: 2017-07-12 19:38:21 INFO (Thread-9) [custom_components.wink] Using new oauth authentication
Jul 12 19:38:21 centbox scl[25022]: 2017-07-12 19:38:21 ERROR (MainThread) [homeassistant.setup] Error during setup of component wink
Jul 12 19:38:21 centbox scl[25022]: File "/opt/homeassistant/custom_components/wink.py", line 233, in setup
Jul 12 19:38:21 centbox scl[25022]: File "/opt/homeassistant/custom_components/wink.py", line 148, in _request_app_setup
Jul 12 19:38:21 centbox scl[25022]: * [wink](https://home-assistant.io/components/wink/)
Is there nothing else in the log? Did you remove everything under wink:
in your config?
Yes. All I have in the config is βwink:β nothing after it. The log I posted was grepβd to βwinkβ. Here is the whole thing; I copied only the relevant parts, I think, as the whole log is pretty long:
Jul 12 20:04:28 centbox scl[25182]: 2017-07-12 20:04:28 INFO (Thread-3) [custom_components.wink] Using new oauth authentication
Jul 12 20:04:28 centbox scl[25182]: 2017-07-12 20:04:28 INFO (Thread-3) [homeassistant.loader] Loaded configurator from homeassistant.components.configurator
Jul 12 20:04:28 centbox scl[25182]: 2017-07-12 20:04:28 ERROR (MainThread) [homeassistant.setup] Error during setup of component wink
Jul 12 20:04:28 centbox scl[25182]: Traceback (most recent call last):
Jul 12 20:04:28 centbox scl[25182]: File "/opt/homeassistant/lib/python3.5/site-packages/homeassistant/setup.py", line 190, in _async_setup_component
Jul 12 20:04:28 centbox scl[25182]: component.setup, hass, processed_config)
Jul 12 20:04:28 centbox scl[25182]: File "/opt/rh/rh-python35/root/usr/lib64/python3.5/asyncio/futures.py", line 358, in __iter__
Jul 12 20:04:28 centbox scl[25182]: yield self # This tells Task to wait for completion.
Jul 12 20:04:28 centbox scl[25182]: File "/opt/rh/rh-python35/root/usr/lib64/python3.5/asyncio/tasks.py", line 290, in _wakeup
Jul 12 20:04:28 centbox scl[25182]: future.result()
Jul 12 20:04:28 centbox scl[25182]: File "/opt/rh/rh-python35/root/usr/lib64/python3.5/asyncio/futures.py", line 274, in result
Jul 12 20:04:28 centbox scl[25182]: raise self._exception
Jul 12 20:04:28 centbox scl[25182]: File "/opt/rh/rh-python35/root/usr/lib64/python3.5/concurrent/futures/thread.py", line 55, in run
Jul 12 20:04:28 centbox scl[25182]: result = self.fn(*self.args, **self.kwargs)
Jul 12 20:04:28 centbox scl[25182]: File "/opt/homeassistant/custom_components/wink.py", line 228, in setup
Jul 12 20:04:28 centbox scl[25182]: _request_app_setup(hass, config)
Jul 12 20:04:28 centbox scl[25182]: File "/opt/homeassistant/custom_components/wink.py", line 148, in _request_app_setup
Jul 12 20:04:28 centbox scl[25182]: 'type': 'string'}]
Jul 12 20:04:28 centbox scl[25182]: File "/opt/homeassistant/lib/python3.5/site-packages/homeassistant/components/configurator.py", line 52, in request_config
Jul 12 20:04:28 centbox scl[25182]: request_id = instance.request_config(
Jul 12 20:04:28 centbox scl[25182]: AttributeError: 'bool' object has no attribute 'request_config'
Jul 12 20:04:28 centbox scl[25182]: 2017-07-12 20:04:28 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: service_call_id=140247765255840-1, service_data=notification_id=invalid_config, title=Invalid config, message=The following components and platforms could not be set up:
Jul 12 20:04:28 centbox scl[25182]: * [wink](https://home-assistant.io/components/wink/)
Jul 12 20:04:28 centbox scl[25182]: Please check your config, service=create, domain=persistent_notification>
Jul 12 20:04:28 centbox scl[25182]: 2017-07-12 20:04:28 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=persistent_notification.invalid_config, new_state=<state persistent_notification.invalid_config=The following components and platforms could not be set up:
Jul 12 20:04:28 centbox scl[25182]: Please check your config; title=Invalid config @ 2017-07-12T20:04:28.220209-04:00>>
Jul 12 20:04:28 centbox scl[25182]: 2017-07-12 20:04:28 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=140247765255840-1>
Jul 12 20:04:28 centbox scl[25182]: 2017-07-12 20:04:28 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=media_player.sony_bravia_tv, new_state=<state media_player.sony_bravia_tv=on; media_content_id=App, is_volume_muted=False, supported_features=19901, friendly_name=Sony Bravia TV, source_list=[], media_title=App @ 2017-07-12T20:04:28.384288-04:00>>
Jul 12 20:04:30 centbox scl[25182]: 2017-07-12 20:04:30 INFO (Thread-4) [homeassistant.components.media_player.onkyo] Resetting connection to Receiver
Did you perform any function in the frontend with the wink configurator? Or does it not get that far?
The invalid config error seems strange.
Can you run the below command in your config directory and see what it says?
hass -c . --script check_config
It never gets that far, I get a error box on the States page:
- wink
The output from that command is:
[root@centbox homeassistant]# source /opt/homeassistant/bin/activate
(homeassistant)[root@centbox homeassistant]# hass -c . --script check_config
Testing configuration at /opt/homeassistant/.
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setting up http
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setting up recorder
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.0 seconds.
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setting up api
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setting up history
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.0 seconds.
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setting up frontend
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds.
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setting up updater
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setting up sensor
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setting up sun
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setting up conversation
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setting up group
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setting up wink
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.1 seconds.
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.0 seconds.
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.0 seconds.
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setup of domain conversation took 0.0 seconds.
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.0 seconds.
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setup of domain wink took 0.0 seconds.
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setting up media_player
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setting up logbook
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setting up tts
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setting up config
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setup of domain media_player took 0.0 seconds.
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.0 seconds.
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setting up automation
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.0 seconds.
2017-07-12 20:20:56 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.
Iβm pretty sure it is using your py script, but is there a way to confirm? Do I need to set permissions on the file? Maybe +x?
Can you PM me your config and a directory listing from inside your config directory and the custom_component folder?
Also, maybe run this on the wink.py
pylint wink.py
Its there a tutorial to get this to work? SORRY, Iβm super new. I just install hasbian, I have all my keys from Wink also I went to your GitHub and copy the file wink.py and save in notepad but where do I place that file?
Thank you
No problem. Place the wink.py into a newly created folder inside your config folder called custom_component
Make sure you donβt have any settings under wink:
in your config and then restart.
Follow the instruction given in the frontend.
when I create the folder \HASSBIAN\homeassistant\custom_component and i put the file wink.py home assist will not load
The custom component folder needs to be in the same folder as your .yaml files.
Yes thas is where i created the folder custom_component.
Itβs long, Iβm sorry:
[root@centbox homeassistant]# scl enable rh-python35 bash
(homeassistant)[root@centbox homeassistant]# pylint wink.py
bash: pylint: command not found
(homeassistant)[root@centbox homeassistant]# pip3 install pylint
Collecting pylint
Downloading pylint-1.7.2-py2.py3-none-any.whl (644kB)
100% |ββββββββββββββββββββββββββββββββ| 647kB 387kB/s
Requirement already satisfied (use --upgrade to upgrade): six in ./lib/python3.5/site-packages (from pylint)
Collecting isort>=4.2.5 (from pylint)
Downloading isort-4.2.15-py2.py3-none-any.whl (43kB)
100% |ββββββββββββββββββββββββββββββββ| 45kB 2.9MB/s
Collecting mccabe (from pylint)
Downloading mccabe-0.6.1-py2.py3-none-any.whl
Collecting astroid>=1.5.1 (from pylint)
Downloading astroid-1.5.3-py2.py3-none-any.whl (269kB)
100% |ββββββββββββββββββββββββββββββββ| 270kB 851kB/s
Collecting lazy-object-proxy (from astroid>=1.5.1->pylint)
Downloading lazy-object-proxy-1.3.1.tar.gz
Collecting wrapt (from astroid>=1.5.1->pylint)
Downloading wrapt-1.10.10.tar.gz
Building wheels for collected packages: lazy-object-proxy, wrapt
Running setup.py bdist_wheel for lazy-object-proxy
Complete output from command /opt/homeassistant/bin/python3 -c "import setuptools;__file__='/tmp/pip-build-w819b2gx/lazy-object-proxy/setup.py';exec(compile(open(__fil e__).read().replace('\r\n', '\n'), __file__, 'exec'))" bdist_wheel -d /tmp/tmp69jrdmdcpip-wheel-:
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-x86_64-3.5
creating build/lib.linux-x86_64-3.5/lazy_object_proxy
copying src/lazy_object_proxy/__init__.py -> build/lib.linux-x86_64-3.5/lazy_object_proxy
copying src/lazy_object_proxy/slots.py -> build/lib.linux-x86_64-3.5/lazy_object_proxy
copying src/lazy_object_proxy/simple.py -> build/lib.linux-x86_64-3.5/lazy_object_proxy
copying src/lazy_object_proxy/compat.py -> build/lib.linux-x86_64-3.5/lazy_object_proxy
copying src/lazy_object_proxy/utils.py -> build/lib.linux-x86_64-3.5/lazy_object_proxy
running egg_info
writing src/lazy_object_proxy.egg-info/PKG-INFO
writing dependency_links to src/lazy_object_proxy.egg-info/dependency_links.txt
writing top-level names to src/lazy_object_proxy.egg-info/top_level.txt
warning: manifest_maker: standard file '-c' not found
reading manifest file 'src/lazy_object_proxy.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: no files found matching '.isort.cfg'
warning: no previously-included files matching '*.py[cod]' found anywhere in distribution
warning: no previously-included files matching '__pycache__' found anywhere in distribution
warning: no previously-included files matching '*.so' found anywhere in distribution
warning: no previously-included files matching '*.dylib' found anywhere in distribution
writing manifest file 'src/lazy_object_proxy.egg-info/SOURCES.txt'
copying src/lazy_object_proxy/cext.c -> build/lib.linux-x86_64-3.5/lazy_object_proxy
running build_ext
building 'lazy_object_proxy.cext' extension
creating build/temp.linux-x86_64-3.5
creating build/temp.linux-x86_64-3.5/src
creating build/temp.linux-x86_64-3.5/src/lazy_object_proxy
gcc -pthread -Wno-unused-result -Wsign-compare -Wunreachable-code -DNDEBUG -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp -buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -I/opt/rh/rh-python35/root/usr/include -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -f exceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -fPIC -Isrc/lazy_object_proxy -I/opt/ rh/rh-python35/root/usr/include/python3.5m -c src/lazy_object_proxy/cext.c -o build/temp.linux-x86_64-3.5/src/lazy_object_proxy/cext.o
gcc -pthread -shared -L/opt/rh/rh-python35/root/usr/lib64-Wl,-z,relro build/temp.linux-x86_64-3.5/src/lazy_object_proxy/cext.o -L/opt/rh/rh-python35/root/usr/lib64 -lp ython3.5m -o build/lib.linux-x86_64-3.5/lazy_object_proxy/cext.cpython-35m-x86_64-linux-gnu.so
installing to build/bdist.linux-x86_64/wheel
running install
running install_lib
creating build/bdist.linux-x86_64
creating build/bdist.linux-x86_64/wheel
creating build/bdist.linux-x86_64/wheel/lazy_object_proxy
copying build/lib.linux-x86_64-3.5/lazy_object_proxy/__init__.py -> build/bdist.linux-x86_64/wheel/lazy_object_proxy
copying build/lib.linux-x86_64-3.5/lazy_object_proxy/slots.py -> build/bdist.linux-x86_64/wheel/lazy_object_proxy
copying build/lib.linux-x86_64-3.5/lazy_object_proxy/simple.py -> build/bdist.linux-x86_64/wheel/lazy_object_proxy
copying build/lib.linux-x86_64-3.5/lazy_object_proxy/compat.py -> build/bdist.linux-x86_64/wheel/lazy_object_proxy
copying build/lib.linux-x86_64-3.5/lazy_object_proxy/utils.py -> build/bdist.linux-x86_64/wheel/lazy_object_proxy
copying build/lib.linux-x86_64-3.5/lazy_object_proxy/cext.c -> build/bdist.linux-x86_64/wheel/lazy_object_proxy
copying build/lib.linux-x86_64-3.5/lazy_object_proxy/cext.cpython-35m-x86_64-linux-gnu.so -> build/bdist.linux-x86_64/wheel/lazy_object_proxy
running install_egg_info
Copying src/lazy_object_proxy.egg-info to build/bdist.linux-x86_64/wheel/lazy_object_proxy-1.3.1-py3.5.egg-info
running install_scripts
File "<string>", line 1, in <module>
File "/tmp/pip-build-w819b2gx/lazy-object-proxy/setup.py", line 115, in <module>
for root, _, _ in os.walk('src')
File "/opt/rh/rh-python35/root/usr/lib64/python3.5/distutils/core.py", line 148, in setup
dist.run_commands()
File "/opt/rh/rh-python35/root/usr/lib64/python3.5/distutils/dist.py", line 955, in run_commands
self.run_command(cmd)
File "/opt/rh/rh-python35/root/usr/lib64/python3.5/distutils/dist.py", line 974, in run_command
cmd_obj.run()
File "/opt/homeassistant/lib/python3.5/site-packages/wheel/bdist_wheel.py", line 213, in run
archive_basename = self.get_archive_basename()
File "/opt/homeassistant/lib/python3.5/site-packages/wheel/bdist_wheel.py", line 161, in get_archive_basename
impl_tag, abi_tag, plat_tag = self.get_tag()
File "/opt/homeassistant/lib/python3.5/site-packages/wheel/bdist_wheel.py", line 155, in get_tag
assert tag == supported_tags[0]
AssertionError
Failed building wheel for lazy-object-proxy
Running setup.py bdist_wheel for wrapt
Complete output from command /opt/homeassistant/bin/python3 -c "import setuptools;__file__='/tmp/pip-build-w819b2gx/wrapt/setup.py';exec(compile(open(__file__).read(). replace('\r\n', '\n'), __file__, 'exec'))" bdist_wheel -d /tmp/tmp4wvueddmpip-wheel-:
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-x86_64-3.5/wrapt
copying src/wrapt/__init__.py -> build/lib.linux-x86_64-3.5/wrapt
copying src/wrapt/arguments.py -> build/lib.linux-x86_64-3.5/wrapt
copying src/wrapt/decorators.py -> build/lib.linux-x86_64-3.5/wrapt
copying src/wrapt/importer.py -> build/lib.linux-x86_64-3.5/wrapt
copying src/wrapt/wrappers.py -> build/lib.linux-x86_64-3.5/wrapt
running build_ext
building 'wrapt._wrappers' extension
creating build/temp.linux-x86_64-3.5/src/wrapt
gcc -pthread -Wno-unused-result -Wsign-compare -Wunreachable-code -DNDEBUG -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp -buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -I/opt/rh/rh-python35/root/usr/include -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -f exceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -D_GNU_SOURCE -fPIC -fwrapv -fPIC -I/opt/rh/rh-python35/root/usr/ include/python3.5m -c src/wrapt/_wrappers.c -o build/temp.linux-x86_64-3.5/src/wrapt/_wrappers.o
gcc -pthread -shared -L/opt/rh/rh-python35/root/usr/lib64-Wl,-z,relro build/temp.linux-x86_64-3.5/src/wrapt/_wrappers.o -L/opt/rh/rh-python35/root/usr/lib64 -lpython3. 5m -o build/lib.linux-x86_64-3.5/wrapt/_wrappers.cpython-35m-x86_64-linux-gnu.so
running install
running install_lib
creating build/bdist.linux-x86_64/wheel/wrapt
copying build/lib.linux-x86_64-3.5/wrapt/__init__.py -> build/bdist.linux-x86_64/wheel/wrapt
copying build/lib.linux-x86_64-3.5/wrapt/arguments.py -> build/bdist.linux-x86_64/wheel/wrapt
copying build/lib.linux-x86_64-3.5/wrapt/decorators.py -> build/bdist.linux-x86_64/wheel/wrapt
copying build/lib.linux-x86_64-3.5/wrapt/importer.py -> build/bdist.linux-x86_64/wheel/wrapt
copying build/lib.linux-x86_64-3.5/wrapt/wrappers.py -> build/bdist.linux-x86_64/wheel/wrapt
copying build/lib.linux-x86_64-3.5/wrapt/_wrappers.cpython-35m-x86_64-linux-gnu.so -> build/bdist.linux-x86_64/wheel/wrapt
running egg_info
creating src/wrapt.egg-info
writing dependency_links to src/wrapt.egg-info/dependency_links.txt
writing src/wrapt.egg-info/PKG-INFO
writing top-level names to src/wrapt.egg-info/top_level.txt
writing manifest file 'src/wrapt.egg-info/SOURCES.txt'
reading manifest file 'src/wrapt.egg-info/SOURCES.txt'
Copying src/wrapt.egg-info to build/bdist.linux-x86_64/wheel/wrapt-1.10.10-py3.5.egg-info
File "/tmp/pip-build-w819b2gx/wrapt/setup.py", line 94, in <module>
run_setup(with_extensions=True)
File "/tmp/pip-build-w819b2gx/wrapt/setup.py", line 70, in run_setup
setup(**setup_kwargs_tmp)
dist.run_commands()
cmd_obj.run()
AssertionError
Failed building wheel for wrapt
Failed to build lazy-object-proxy wrapt
Installing collected packages: isort, mccabe, lazy-object-proxy, wrapt, astroid, pylint
Running setup.py install for lazy-object-proxy
Running setup.py install for wrapt
Successfully installed astroid-1.5.3 isort-4.2.15 lazy-object-proxy-1.3.1 mccabe-0.6.1 pylint-1.7.2 wrapt-1.10.10
No config file found, using default configuration
************* Module wink.py
F: 1, 0: No module named wink.py (fatal)
(homeassistant)[root@centbox homeassistant]# cd /opt/homeassistant/custom_components/
(homeassistant)[root@centbox custom_components]# pylint wink.py
C:485, 0: Trailing newlines (trailing-newlines)
R:177, 0: Too many local variables (23/15) (too-many-locals)
E:179, 4: Unable to import 'pywink' (import-error)
E:180, 4: Unable to import 'pubnubsubhandler' (import-error)
W:281,24: Unused argument 'event_time' (unused-argument)
W:295,27: Unused argument 'event' (unused-argument)
W:301,26: Unused argument 'event' (unused-argument)
W:307,21: Unused argument 'call' (unused-argument)
W:317,25: Unused argument 'call' (unused-argument)
Your code has been rated at 9.35/10
That should be custom_components with an s
ok, now it loads but it says invalid config on my dash,
I see this error 2017-07-13 11:23:57 ERROR (MainThread) [homeassistant.setup] Error during setup of component wink
i also see this in the error log
File β/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/wink.pyβ, line 114, in setup
email = config[DOMAIN][CONF_EMAIL]
my yaml file has wink:
