I have tried every possible trigger variation from the mqtt client log. It doesnt turn the light on. Any way to test my automation? No errors in the log
Do you have mqtt integrated in home assistant? It will not do anything if you don’t have mqtt set up properly. And can you turn that switch on/off in home assistant without the automation? Switch entity exactly correct from home assistant developer tools?
Yes because i can see the humidity and temperature from the wink relay sensors on the dashboard. The name i copied from an existing working light switch.
So for that to be true I assume you have mqtt auto discovery turned on, true? What is the temp mqtt topic?
Under developer tools, can you execute the automation directly and toggle the zwave switch? If that works you don’t have the mqtt portion correct. But I’m running out of suggestions based on what you are reporting.
In dev tools under services if i select the automation trigger. The light turns on. Everything works
Now why in the world doesnt it work from the wink relay
