I am more or less in @jiiins situation. I have a built-in SIP doorbell (GDS3710 grandstream). I am therefore interested on the client side. Can you detail what you have installed on the tablet to receive the call? I assume you are using what is there https://github.com/rdehuyss/DoorDroid but I don’t understand what to do.
It seems you are using the jssip library. So, in theory, it should be in the browser of the android phone? Am I correct?
Thanks for the hints and sharing your project.
GV
So, my indoor station (an in-wall Android Tablet) is running standard Lovelace in Chrome (= browser of the Android phone in your words). I created a custom lovelace component which was called by the DoorDroid application (in your case the GDS3710 grandstream). It indeed used jssip and asterisk.
Have you taken a look at the wiki? Everything is described there…
I did!! But " * Download and install the Android app from the releases page of this repository" from the wiki is not clear to me.
What do you need to install on the android phone? I need (somehow?) to build an apk?
In my understanding with the sipjs library everything was in the browser from the client side. So, in theory, nothing to install on the phone/tablet… Or at least that was my understanding. Hence, my confusion
GV
The apk is on the releases page.
In your case you don’t need to install an apk since your doorbell already supports SIP.
You need to:
- setup asterisk for SIP Call Management (as in WIKI)
- configure your GDS3710 grandstream station to call the SIP account you will use at your indoor station
- Add the lovelace card to your home assistant
- That should be it, I think
Missed that… Sorry! Nevertheless, the question on sipjs remains. In theory, it should be possible to run everything in the browser, and not requiring an apk.
We had an exchange on this page https://community.home-assistant.io/t/sip-client/60964.
GV
Would be great!! I’ll try that. It is going to keep me busy this week-end
In your setup, why do you need the apk? What is the purpose of the app?
GV
The APK is running on a phone which is mounted at my door, so the equivalent of your GDS3710 grandstream.
OK. Thanks. Will try that and if I have some issues I’ll ask
GV
I don’t know if I should report here or on github…
Line 36 of doorpi-camera-view.js is :
imgEl.src = 'https://192.168.1.66:9090/stream/video.mjpeg';
It should be a reference to the settings in doordroid.yaml. The mjpeg settings:
mjpeg_url: https://192.168.1.66:9090/stream/video.mjpeg
No?
GV
Some report on my progress so far. I have installed doordroid and jssip on my HA box. I have created the extension on my asterisk serevr to register by able to register the “card” of doordroid.
Up to that point all good.
When I open lovelace and go to the view with the webrtc phone I can see the phone registering on asterisk.
When I call the webrtc extension, the two additional buttons are displayed. However when I click on “accept call” buttons I have an error message in the developper console. See below.
Loading SIPPhone doordroid-card.js?v=0.0.1:80
initialized camera view doordroid-card.js?v=0.0.1:151:
SIPPhone registered with SIP Server doordroid-card.js?v=0.0.1:100:
jssip-3.3.6.min.js:9 Uncaught INVALID_STATE_ERROR: Invalid status: 5
at t.value (http://192.168.0.150:8123/local/plugins/jssip-3.3.6.min.js:9:117457)
at HTMLElement.<anonymous> (http://192.168.0.150:8123/local/plugins/doordroid-card.js?v=0.0.1:131:71)
r @ jssip-3.3.6.min.js:9
t @ jssip-3.3.6.min.js:9
value @ jssip-3.3.6.min.js:9
(anonymous) @ doordroid-card.js?v=0.0.1:131
doordroid-card.js?v=0.0.1:121
And I am stuck!! Any suggestion where to look at and what to try?
Thanks,
GV
To be honest, I don’t use this setup anymore as mentioned above. So, it may be that the code contains bugs/errors.
I did Google your error and found this: https://github.com/versatica/JsSIP/issues/527
Are you answering the call twice?
Thanks for your answer.
In fact, my “SSL” setup (for hassio, asterisk,…) was not correct and webrtc seems to be very picky when it comes to connection over unsecured channel. So, once HTTPS, WSS was ok, it when well.
In your doordroid-card.js I have added:
JsSIP.debug.enable('JsSIP:*');
which helped greatly!
I believe that my configuration is OK (SIP extensions, asterisk,…) the only missing bit is incoming audio from the SIP contact. And I believe, I understand why, even if I can’t see what to do…
In my setup the SIP extensions calls the webrtc endpoint. I can accept the call and it can be seen in the debug console:
JsSIP:RTCSession receiveRequest() +14ms
jssip-3.3.6.min.js:9 JsSIP:RTCSession session confirmed +1ms
jssip-3.3.6.min.js:9 JsSIP:RTCSession emit "confirmed" +0ms
doordroid-card.js?v=0.0.4:124 call confirmed
jssip-3.3.6.min.js:9 JsSIP:WebSocketInterface received WebSocket message +13s
However, looking at the code, the next event should be:
session.on("addstream", (e) => {
the event addstream AFAIK doesn’t exist any more in the JSSIP 3. It was part of the API in 2.X.
With my (extremely) limited understanding of JS and JSSIP, I can’t figure out what should be the final (?) step to “link” the RTP audio (seen in the wireshark capture) with the audio of my PC.
Any suggestion?
Thanks,
GV
You are correct.
I updated my github with my latest version of the DoorDroid Card.
And indeed, without https, webrtc refuses to work except for localhost.
Thanks !!
Will try that when I am back home.
If I can achieve what I want I will “Share my project” with a lot of credit to you
Next (last ?) episode tonight
GV
Hourrah !! It works. Thank you for your help.
I have (kind of) took some bits of the new version provided yesterday with the previous one. I don’t need the part with the “everywhere” or not
After this first success, I have continued my investigations. When the call is accepted I would like to turn on an input_boolean in hass to do further action.
I thought it would be straightforward. It is not. At least for me.
Here is what I have done:
session.on("peerconnection", () => {
session.connection.addEventListener("addstream", (e) => {
console.log('adding audiostream')
// set remote audio stream (to listen to remote audio)
// remoteAudio is <audio> element on page
const remoteAudio = document.createElement('audio');
//const remoteAudio = droidCard.getElementById('audio-player');
remoteAudio.srcObject = e.stream;
remoteAudio.play();
hass.callservice('input_boolean', 'turn_on', { entity_id: 'input_boolean.portail' });
The callservice at the end of the function…
I can’t see the change in lovelace. The input_boolean.portail stays off
Is there something else to do?
How do I debug this? I don’t even know in the developer console if the callservice is called or not.
GV
Have you tried debugging it? Just place a breakpoint and see if it is hit. I’m also not sure whether hass is known as you are in a callback.
Debugging it will tell you…
I was able to “fix” my code. In another post https://community.home-assistant.io/t/sip-client/60964 I am giving a status.
Thanks for your help and providing 99% of the work for making this possible
GV
I still have some issues with my setup and I was wondering if you could help!
My (tweaked) version of doodroid.js is running in a view that is not always displayed. Sometimes the tablet falls asleep. As a consequence the webrtc connexion is dropped.
However, by looking at the code I can see:
set hass(hass) {
if(this.notYetInitialized()) {
this.initJsSIPIfNecessary(hass);
this.initCameraView(hass);
} else if(this.cameraEntityHasNewAccessToken(hass)) {
this.updateCameraView(hass);
this.initDoorbellRinging(hass)
and below:
notYetInitialized() {
return window.JsSIP && !this.sipPhone && this.config;
My understanding of javascript gives me the feeling that when the tablet is back on and the doordroid view is displayed, the webrtc connexion is not restarted as it has been Initialized once.
To be on the safe side, wouldn’t it be better to “initialize” again the webrtc phone when the doordroid view is displayed? What would be the best way to do that?
As explained above, JS and I are not the best friends. So, I may miss something here!!
Thanks.
GV
My tablet was always on so I did not have the problem.
I checked the docs of JsSip and found this: https://jssip.net/documentation/3.3.x/api/ua/
You could check if this.sipPhone.isConnected()
. So, it would be something like:
return window.JsSIP && this.config && !this.sipPhone && !this.sipPhone.isConnected();
Do note that I did not test this so you will need to investigate a bit (and my head can’t process that much booleans right now) .
