Hi all, great project, really appreciate all the work.
$15 Paypal tip for anyone that can help!
I require some expert help.
Tried implementing this, but tweaking it to my specifications, so far all that happens is all LED’s are turned on. Not sure where I’m going wrong with this. Any help would be greatly appreciated.
Scripts are as follows…
wordclock.yaml
esphome:
  includes:
    - wordclock.h
  on_boot:
    priority: 800
    then:
      - light.turn_on:
esp8266:
  board: d1_mini
  framework:
    version: 2.7.4
substitutions:
  devicename: wordclock
  friendly_name: "Wordclock"
wifi:
  ssid: "UPC7C77516"
  password: "password"
  ap:
    ssid: "Horloge Fallback Hotspot"
# WEB Server
web_server:
  port: 80
# Sensors
#sensor:
#  - platform: wifi_signal
#    name: "th0 Signal Wi-Fi"
#    update_interval: 60s
# Enable logging
logger:
#    level: VERBOSE
# Enable Home Assistant API
api:
ota:
light:
  - platform: fastled_clockless
    rgb_order: GRB
    chipset: WS2811
    pin: GPIO02
    restore_mode: RESTORE_DEFAULT_ON
    num_leds: 114
time:
  - platform: homeassistant
custom_component:
- lambda: |-
    auto wordclock = new Wordclock();
    return {wordclock};
wordclock.h
#include "esphome.h"
#include <FastLED.h>
#define NUM_LEDS 114
#define DATA_PIN D4
// esphome dependencies:
// needs: esphome time --> id: current_time
// needs: esphome fastled --> id: fastledlight
// Layout of Clock (X not used chars) - PIN Layout
// ESXISTXFÜNF    1.......11
// ZEHNZWANZIG    22......12
// DREIVIERTEL    23......33
// XXNACHVORXX    44......34
// HALBXZWÖLFX    45......55
// ZWEIXSIEBEN    ....
// XDREIXXFÜNF    ....
// ELFNEUNVIER    ....
// XACHTZEHNRS    ....
// XSECHSXXUHR    109.......101
// ICONS          110.......120
// MINUTES        124.......121
int leds_time_it_is[] = {10, 9, 7, 6, 5}; // ES IST
int leds_minutes[] = {124, 123, 122, 121}; // Minutes LEDS
int leds_skiped[] = {110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120}; // Check Line 101
int leds_time_minutes[][15] = {
    { 60,  61,  62,  63,  64,  65,  -1,  -1,  -1,  -1,  -1,  -1,  -1,  -1,  -1}, // UHR
    { 92,  91,  90,  89,  -1,  -1,  -1,  -1,  -1,  -1,  -1,  -1,  -1,  -1,  -1}, // FÜNF, NACH
    { 68,  67,  66,  -1,  -1,  -1,  -1,  -1,  -1,  -1,  -1,  -1,  -1,  -1,  -1}, // ZEHN, NACH
    { 77,  78,  80,  81,  82,  83,  84,  -1,  -1,  -1,  -1,  -1,  -1,  -1,  -1}, // VIERTEL, NACH
    { 98,  97,  96,  95,  94,  -1,  -1,  -1,  -1,  -1,  -1,  -1,  -1,  -1,  -1}, // ZWANZIG, NACH
    { 98,  97,  96,  95,  94,  93,  92,  91,  90,  89,  -1,  -1,  -1,  -1,  -1}, // FÜNF, VOR, HALB
    {102, 103, 104, 105,  -1,  -1,  -1,  -1,  -1,  -1,  -1,  -1,  -1,  -1,  -1}, // HALB
    { 76,  75,  74,  73,  72,  98,  97,  96,  95,  94,  93,  92,  91,  -1,  -1}, // FÜNF, NACH, HALB
    { 76,  75,  74,  73,  72,  98,  97,  96,  95,  94,  -1,  -1,  -1,  -1,  -1}, // ZWANZIG, VOR
    { 76,  75,  74,  73,  72,  74,  75,  80,  87,  82,  83,  84,  -1,  -1,  -1}, // DREIVIERTEL
    { 76,  75,  74,  73,  72,  68,  67,  66,  -1,  -1,  -1,  -1,  -1,  -1,  -1}, // ZEHN, VOR
    { 76,  75,  74,  73,  72,  92,  91,  90,  89,  -1,  -1,  -1,  -1,  -1,  -1}  // FÜNF, VOR
int leds_time_hours[][6] = {
    { 54,  53,  52,  51,  -1,  -1}, // ZWÖLF
    { 28,  27,  26,  -1,  -1,  -1}, // EINS
    {  3,   2,   1,   0,  -1,  -1}, // ZWEI
    { 17,  18,  19,  20,  21,  -1}, // DREI
    { 11,  12,  13,  14,  15,  16}, // VIER
    { 40,  41,  42,  43,  -1,  -1}, // FÜNF
    { 37,  38,  39, 105,  -1,  -1}, // SECHS
    { 25,  24,  23,  22,  -1,  -1}, // SIEBEN
    { 33,  34,  35,  36,  -1,  -1}, // ACHT
    { 32,  31,  30,  29,  -1,  -1}, // NEUN
    { 52,  51,  50,  96,  -1,  -1}, // ZEHN
    { 55,  56,  57,  58,  -1,  -1}  // ELF
CRGB leds[NUM_LEDS];
int hour = -1;
int minute = -1;
int red = 124;
int green = 124;
int blue = 124;
int brightness = 50;
class Wordclock : public Component, public CustomAPIDevice {
    public:
        void setup() override {
            FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
            FastLED.setBrightness(brightness);
            // Start all LED with on and default color and brightness to check if everything is working...
            for(int i = 0; i < NUM_LEDS; i++) { leds[i].setRGB(red, 0, 0); FastLED.show(); delay(10); }
            for(int i = 0; i < NUM_LEDS; i++) { leds[i].setRGB(0, green, 0); FastLED.show(); delay(10); }
            for(int i = 0; i < NUM_LEDS; i++) { leds[i].setRGB(0, 0, blue); FastLED.show(); delay(10); }
            for(int i = 0; i < NUM_LEDS; i++) { leds[i].setRGB(0, 0, 0); }
            FastLED.show();
            register_service(&Wordclock::on_setled, "setled", {"number","red", "blue", "green"});
        void on_setled(int number, int red, int blue, int green) {
            if (number < NUM_LEDS || number > 0) {
                ESP_LOGD("setled", "Setting led number %d to color %i %i %i", number, red, green, blue );
                leds[number].setRGB(red, green, blue);
                FastLED.show();
            else { ESP_LOGE("setled", "Not a valid LED Number - out of range"); }
        void loop() override {
            auto time = id(current_time).now();
            int h = time.hour;
            int m = time.minute;
            // https://www.esphome.io/api/classesphome_1_1light_1_1_light_color_values.html LightColorValues Class
            auto fastledlight2 = id(fastledlight).current_values;
            //convert float 0.0 till 1.0 into int 0 till 255
            red = (int)(fastledlight2.get_red()*255);
            green = (int)(fastledlight2.get_green()*255);
            blue = (int)(fastledlight2.get_blue()*255);
            brightness = 0;
            //check if light is on and set brightness
            if (fastledlight2.get_state() > 0 ) { brightness = (int)(fastledlight2.get_brightness()*255); }
            else { ESP_LOGD("loop", "fastledlight state off - b: %i rgb %i %i %i", brightness, red, green, blue); delay(500);}
            //check if valid time. Blink red,green,blue until valid time is present
            if (time.is_valid() == false) {
                ESP_LOGE("loop", "Got invalid time from current_time Time: %i:%i", h, m );
                leds[0].setRGB(255, 0, 0); FastLED.show(); delay(250);
                leds[0].setRGB(0, 255, 0); FastLED.show(); delay(250);
                leds[0].setRGB(0, 0, 255); FastLED.show(); delay(250);
                leds[0].setRGB(0, 0, 0);   FastLED.show();
            else {
                // only update once in a Minute
                if(h != hour || m != minute) {
                   //ESP_LOGD("loop", "Using b: %i rgb %i %i %i", brightness, red, green, blue);
                    hour = h;
                    minute = m;
                    if (hour >= 0 && time.is_valid() == true){
                        int tmp_hour = hour;
                        int tmp_minute = (minute - (minute % 5));
                        if(tmp_minute >= 25) { tmp_hour += 1; }
                        tmp_minute = tmp_minute / 5;
                        tmp_hour = tmp_hour % 12;
                        int minutessum = minute % 5;
                        // Reset all LED, but skip LED 110 till 120
                        for(int i = 0; i < NUM_LEDS; i++) {     if(i < 110 || i > 120) leds[i].setRGB(0, 0, 0); }
                        for(int i = 0; i < 5; i++) {            leds[leds_time_it_is[i]].setRGB(red, green, blue); }
                        for(int i = 0; i < 15; i++) {           if(leds_time_minutes[tmp_minute][i] >= 0) { leds[leds_time_minutes[tmp_minute][i]].setRGB(red, green, blue); } }
                        for(int i = 0; i < 6; i++) {            if(leds_time_hours[tmp_hour][i] >= 0) { leds[leds_time_hours[tmp_hour][i]].setRGB(red, green, blue); } }
                        for(int i = 0; i < minutessum; i++) {   leds[leds_minutes[i]].setRGB(red, green, blue);}
                        FastLED.show();
                        ESP_LOGD("loop", "Update Time: %i:%i  Brightness: %i RGB: %i-%i-%i", hour, minute, brightness, red, green, blue);
                        ESP_LOGD("loop", "Using tmp_hour: %i tmp_minute: %i minutessum: %i", tmp_hour, tmp_minute, minutessum);
