I do have a Google Home too. May I use your component as well?
To be clear - this is not my code. I just modified bits of it to instantiate multiple instances.
But, I looked and there are some restrictions for Google Home. One of them is the port 80 is required. So, having multiple ports for multiple instances will not work.
I assume you can mix Google Home (port 80) and Alexa configurations with multiple instances (port 8301, port 8302, etc.). But, I don’t know. I have not tried.
I finally have some time to set this up and it works amazingly. This is far more superior than the official version.
@balloob & @fabaff please reconsider merging this into the official version. I believe most of us will eventually hit the 49 devices limit as we add more and more lights, switches, scripts, scenes, groups and automations.
Anyway @shenning00, is it possible to create a new service as a virtual link button so that I can call this service in front end > developer tools > services when I want to rediscover new devices in the Alexa app? Right now, I need to restart HA and keep refreshing http://IPADDRESS:8301/description.xml in order to rediscover new devices. It is really inconvenient.
I have more then 200.
And I vote this code one of the best there is
yes clear, for GH I can use only one instance.
Have you any idea on the maximum amount of devices that GH can handle?
Anyway I will try to find out myself
you not? Light, group, switch, script, scene …
and now I can all call them from Alxa … pretty cool
Nope. I just started playing with this. I found out not everything can be controlled from emulated hue. For example, I have a script that reads out the weather report via TTS. I named it… emulated_hue_name: 'Weather Report'
When I say, “Alexa, turn on weather report”, it gives me its own weather report instead of the one I have in HA.
Yes you need to give names that doesn’t conflict with Amazon own database
May I see your script?
I really doubt that trying to replace some Alexa skill would work.
You can use automations in emulated_hue?
haven’t try. I assume I can use it to turn on/off any automation. will try later.
I just want to turn on a script. if I cannot use “weather” in the device name, I wonder what other name that make sense and related to weather report. perhaps “Alexa, turn on outdoor report” ???
sure…
in template sensor…
# Weather conditions
weather_condition:
friendly_name: 'Weather Condition'
value_template: "The weather condition is {{ states('sensor.dark_sky_summary') }} and {{ states('sensor.temp_feel_darksky') }} at {{ states('sensor.dark_sky_temperature') }}°C and the forecast is {{ states('sensor.dark_sky_hourly_summary') }} with temperature ranging from {{ states('sensor.dark_sky_daily_low_temperature') }}°C to {{ states('sensor.dark_sky_daily_high_temperature') }}°C"
entity_id:
- sensor.dark_sky_summary
- sensor.temp_feel_darksky
- sensor.dark_sky_temperature
- sensor.dark_sky_hourly_summary
- sensor.dark_sky_daily_low_temperature
- sensor.dark_sky_daily_high_temperature
temp_feel_darksky:
friendly_name: 'Dark Sky Temperature Feel'
value_template: >-
{%- if states.sensor.dark_sky_temperature.state | float < 29 %}
nice
{%- elif states.sensor.dark_sky_temperature.state | float < 31 %}
warm
{%- elif states.sensor.dark_sky_temperature.state | float < 33 %}
hot
{% else %}
baking
{%- endif %}
entity_id: sensor.dark_sky_temperature
in script…
howistheweather:
alias: 'How is the weather?'
sequence:
- service: tts.google_say
entity_id: media_player.vlc_living_room
message: "{{ states('sensor.weather_condition') }}"
so far no discovery of elements from GH.
Someone that has GH and emulated_hue (WITH also a Hue physical hub) can it show me how it worked for them? After how long are the emulated_hue devices discovered by GH app?
that’s my config.
emulated_hue:
hue1:
type: alexa
listen_port: 8301
target_ip: 192.168.1.92
exposed_domains:
- switch
- script
- light
hue2:
type: alexa
listen_port: 8302
exposed_domains:
- scene
hue3:
type: alexa
listen_port: 8303
exposed_domains:
- group
hue4:
type: google_home
listen_port: 80
target_ip: 192.168.1.91
exposed_domains:
- switch
- script
- light
has this error anything to do ?
17-02-25 13:34:00 ERROR (MainThread) [homeassistant.components.http] Failed to create HTTP server at port 80: [Errno 13] error while attempting to bind on address (‘192.168.1.239’, 80): permission denied
This error indicates that you might already have some other program that is using this port. You might have a web server, proxy, etc. that is already using port 80.
I had a web server that I took out when I used HA bridge. Now I stopped HA bridge from booting.
Not sure what else can be, or how to troubleshoot
Sorry, missed this message. So, you found that HA Bridge was using the port.
I have this test config:
emulated_hue:
hue1:
type: alexa
listen_port: 8301
expose_by_default: true
exposed_domains:
- fan
- group
- climate
- script
hue2:
type: alexa
listen_port: 8302
exposed_domains:
- light
hue3:
type: google_home
listen_port: 80
exposed_domains:
- fan
Then I checked to see if that port was allocated: netstat -anp | grep 80
This showed that a python application (HA) had the port opened.
Then I queried the web address: http://192.168.1.211/description.xml
I received this:
<root xmlns="urn:schemas-upnp-org:device-1-0">
<specVersion>
<major>1</major>
<minor>0</minor>
</specVersion>
<URLBase>http://192.168.1.211:80/</URLBase>
<device>
<deviceType>urn:schemas-upnp-org:device:Basic:1</deviceType>
<friendlyName>HASS Bridge (192.168.1.211)</friendlyName>
<manufacturer>Royal Philips Electronics</manufacturer>
<manufacturerURL>http://www.philips.com</manufacturerURL>
<modelDescription>Philips hue Personal Wireless Lighting</modelDescription>
<modelName>Philips hue bridge 2015</modelName>
<modelNumber>BSB002</modelNumber>
<modelURL>http://www.meethue.com</modelURL>
<serialNumber>80</serialNumber>
<UDN>uuid:2f402f80-da50-11e1-80-001788255acc</UDN>
</device>
</root>
Now - remember my code changes some values in this output - like serialNumber, UDN, etc. I could make a change in the code that if this is ‘google home’ don’t apply these changes.
Then I tried this URL: http://192.168.1.211/api/pi/lights
And got back a series of these:
1: {
modelid: "HASS123",
name: "Guest Bedroom Fan",
state: {
bri: 0,
on: false,
reachable: true
swversion: "123",
type: "Dimmable light",
uniqueid: "fan.guest_bedroom_fan"
… more of the fans
I didn’t try to check the UPNP discovery.
I don’t have a Google Home so I can’t confirm that it would work.
But this should give you some idea that most of this seems to be working.
