I’m using the Home Assistant Container installation type as described here. It has the advantage that everything Home Assistant is nicely contained in the container (I’m also running Rhasspy, mopidy and a bunch of other stuff on the Pi) but apparently it has the disadvantage that it does not have the configuration.yaml
editor that Home Assistant OS and Home Assistant Core have.
Before I start looking into the “how”, I would like to know if there might be any reasons why a regular integration would not be able to write configuration.yaml
. If no, then I might look into making one.
Preferably one that shows up in the “Integrations” setting, but one like those would also be ok.
