WTH Add "Edit in YAML" to Helpers editor
I get the request, but it ain’t the same. The UI isn’t using anything from the manual YAML configuration at all.
I also feel like the discussion here has nothing to do with the original WTH here.
The original WTH is about being able to be abel to configure YAML of a UI created helper, similar to what you can do in the UI and in automations. There are also options not available using the UI so you can change this in YAML without having to do everything in YAML.
Unfortunately thats not the case with helpers, here you have to configure everything in YAML or everything in the UI. A mix is not possible
