Thanks! You’re edit works for me now. I will edit my original reply
Many thanks for your work and the code. This seems to solve a long-term problem of mine. But unfortunately it doesn’t quite work yet… I can control the group with the template light, but it behaves in the same way as with the normal light group. if I switch off a lamp in the group and then dim the group via the template light/group, the lamp switches on again.
Am I missing something?
Here is my code:
light:
lights:
template_lichtgruppe_arbeitszimmer:
friendly_name: "Lichtgruppe Arbeitszimmer"
level_template: >
{% set group = 'light.arbeitszimmer' %}
expand(group)
| selectattr('attributes.brightness', 'defined')
| selectattr('attributes.brightness')
| map(attribute='attributes.brightness')
| list
| default([0], true)
| average
value_template: "{{ is_state('light.arbeitszimmer', 'on') }}"
turn_on:
- service: light.turn_on
entity_id: light.arbeitszimmer
turn_off:
- service: light.turn_off
set_level:
entity_id: >
expand(group)
| map(attribute='entity_id')
| list
brightness: "{{ brightness }}"
It only works with light groups created as helpers.
If you created the light groups in the configuration.yaml the template will not work and the lights will behave the same.
That’s not correct at all.
Light groups via the UI or yaml are identical. The above code will work with any group via the UI or yaml. It will also work with legacy groups.
The issue is this line
it needs to be removed
That line was intended to filter out none
That would be rejectattr('attributes.brightness', 'none')
Edit sorry on mobile
@petro Without passing a test, the input is tested as a boolean. So it will filter out the lights which are off
This works for me (simplified it a bit, as average
accepts a default
{% set group = 'light.groep_huis' %}
expand(group)
| average(default=0)
Changed the version in post 4 as well
I used your code to make the same thing for color temperature and RGB color and it works nice!
Here is my code:
light:
lights:
anton_lichtgruppe_final:
friendly_name: "Lichtgruppe Anton"
level_template: >
{% set group = 'light.antonlicht' %}
expand(group)
| list
| default([0], true)
| average
value_template: "{{ is_state('light.antonlicht', 'on') }}"
turn_on:
entity_id: light.antonlicht
turn_off:
set_level:
entity_id: >
expand(group)
| list
set_temperature:
entity_id: >
expand(group)
| selectattr('attributes.color_temp', 'defined')
| selectattr('attributes.color_temp')
| list
color_temp: "{{ color_temp }}"
set_rgb:
entity_id: >
expand(group)
| selectattr('attributes.rgb_color','defined')
| selectattr('attributes.rgb_color')
| list
rgb_color: "{{[r,g,b] }}"
My issue now is that when the lights are in RGB mode and i want to change to color temp mode it doesnt do anything. If i change from Color temp to RGB it works
