This is a problem with the positioning of cards, which I describe in the topic related to the availability of HomeAssistant (compliance with WCAG guidelines). Cards move in columns (up / down), not in rows (left / right). It makes sense on the smartphone screen. We have one card in a row. There is chaos on the computer screen. We read from left to right, scan the image from left to right, and in HomeAssistant we place cards from top to bottom, column by column. Weak. Example:
- In the view, add a “button” tab with which you want to turn on the light.
- Duplicate the added button 5 times.
- We now have 6 buttons in the view (2 rows of 3 buttons, 3 columns of 2 buttons).
- Now navigate to the buttons with the tab key.
- We will review the buttons in the order (vertical letters, horizontal numbers) a1, b1, a2, b2, a3, b3. There should be a1, a2, a3, b1, b2, b3. The focus should move across the buttons (using tabs) from left to right, line by line. Now it goes from top to bottom, column by column. Cards should move in rows (left / right) not in columns (up / down).
For an even better picture of the problem. We have 12 cards on the page (4 rows of 3 cards, 3 columns of 4 cards). We want to move the card a2 to the position a1 (letters vertical, numbers horizontal). We want the middle card on the first row, set as the left card on the first row.) Tap on the “Move up” button. The card should move to the left to position a1. Currently, however, it disappears from the screen and goes to position d1 (it becomes the left card in the last row). As you can read in this thread, there is a big problem with that. I assume you are people who use eyesight. Bouncing cards from the top of one column to the bottom of the other create an uncomfortable situation. You have to scroll the screen to check what happened. You can take a look and see, “Oh shit, the card is here now!” I am blind, I cannot see, I cannot glance. I am using a screen reader. Your eyesight is getting lost, I get lost 3 times more with my screen reader. For this reason, I am asking you to improve this functionality.
The solution with buttons “Shift left”, “Shift right”, “Move up”, “Move down” is a good idea. It is a good idea because it is a more logical and convenient solution. Additionally, you can enter the “Cards layout” mode. When this mode is turned on, each card has an edit field that defines its position (a1, a2, a3, b1, b2, b3 …). We set the position of the cards (e.g. we swap the position of cards a1 with b3 and b2 with b1). We save the changes. Done. The cards go to the correct positions.
More on this subject from the point of view of accessibility at the link below (voting, compliance with WCAG, as you can see, helps everyone: ![]()
