then this is the developer’s fault. he should describe what he achieved and ask for help (other devs or the reporter).
doing some trial and leaving no information is even worse than doing nothing. It may lead other devs to waste time on the same actions.
then answering the bot cannot change this situation. It proves it’s wasting the time.
If I achieve nothing, and don’t know enough to look in to it then my comment would be more noise and not helpful. People may look at it and not be able to help, you insinuating no one cares enough to look at it is not reasonable. That is my point,
Not sure what is your experience with development. But communication and sharing knowledge and experience (even these bad experiences) is the most important and powerful thing to keep dev teams and software healthy and productive. It’s even more important than programming language skills alone.
From this POV, what you are saying is just the developer’s fault.
Anyway, this doesn’t justify the requirement we are discussing in this thread.
It may be kept open without further report’s actions. This is what we are discussing here.
Repeating ‘it’s still unfixed’ to the bot doesn’t fix missing assignment of code owner.
Yes, stale bot removes the issues that are no longer valid / OP is not answering anymore meanwhile users who reply to remove the stale label do so to give the contributors time to see it and fix it given it is still an issue.
I provided an example of a dev fixing a poorly labeled issue, adding the integration so the correct contributors will be notified and have higher odds of seeing it / fixing it.
It gives contributors time to find it and fix the mislabeling of it.
You forgot your own case when the task is not assigned to code owner (and I answering to). If there is no person assigned, the only involved roles in this game is OP and bot. Nobody else. It’s the wast of time and other resources.
nobody “will find the issue” due to what all of you say: there is too many issues created
No it’s not, as I just provided an example of a contributor (not OP or bot, and that was not assigned) fixing the issue by assigning the correct group… At this point it seems like you’re ignoring what people are saying and just moving the conversation in a circle.
The less time contributors spend reading issues that are actually fixed / OP is not responding, the more time they have to respond to issues that are actually still valid.
Stale bot helps support this by closing issues that are invalid, only requiring a 15 second reply from users who are still experiencing said issue to confirm that. The notion that not having a stale bot, leaving even more issues open perpetually, would lead to more genuine issues being fixed instead of less is nonsensical.
What are you talking about? It moves the issue to the top of the issues page when you reply on it. It certainly makes people aware. It’s comments like this that make this stale bot argument moot. None of you know the process and are making assumptions, incorrectly.
