WTH wider cards are needed sometimes
Have you tried the Sidebar view layout option?
It gives you one wide and one narrow column. And you can use a horizontal stack in the wide column to divide it into halves or thirds, e.g.
Although, it would be nice to change the width of the Sidebar … and orientation left or right
You could make a separate WTH for that. It would be a small change.
I can’t believe I missed this Sidebar layout option!! Awesome!
It was developed at the same time as the energy dashboard (it uses it).
Yes, it is fine fine but have some limitations:
Good job. Voted.
The sidebar gives you only one very wide card, when using a screen bigger than a phone’s it isn’t confortable
Nope. As noted above this can be split into as many divisions as you want with a horizontal stack.
Not sure what you mean.
There will be issues displaying wider cards on smaller screens.
The way I get around this is to have one dashboard for mobile devices and one for desktop devices. I then choose my layouts appropriately. The screenshot of the view I showed above looks like this for my mobile dashboard:
Thanks, sometimes I want to see the same cards ond on top of the other (in a phone) and when using a widescreen to see it aside…
I don’t like to maintain two sets of the same data it is not optimal usage…
