PS4 had been working great for ages untill 0.88 update. I am confused as to what to change.
Here is my /config/custom_components/media_player/ps4.py
[details=“Summary”]
“”“Playstation 4 media_player using ps4-waker.”""
import json
import logging
from datetime import timedelta
from urllib.parse import urlparse
import requests
import voluptuous as vol
import homeassistant.util as util
from homeassistant.components.media_player import (
PLATFORM_SCHEMA,
MediaPlayerDevice,
ENTITY_IMAGE_URL
PLATFORM_SCHEMA,
MEDIA_TYPE_CHANNEL,
SUPPORT_TURN_ON,
SUPPORT_TURN_OFF,
SUPPORT_STOP,
SUPPORT_SELECT_SOURCE,
ENTITY_IMAGE_URL,
MediaPlayerDevice
from homeassistant.const import (
STATE_IDLE,
STATE_UNKNOWN,
STATE_OFF,
STATE_PLAYING,
CONF_NAME,
CONF_HOST
from homeassistant.helpers import config_validation as cv
REQUIREMENTS = []
_LOGGER = logging.getLogger(__name__)
SUPPORT_PS4 = SUPPORT_TURN_OFF | SUPPORT_TURN_ON | \
SUPPORT_STOP | SUPPORT_SELECT_SOURCE
DEFAULT_NAME = 'Playstation 4'
DEFAULT_PORT = ''
ICON = 'mdi:playstation'
CONF_GAMES_FILENAME = 'games_filename'
CONF_IMAGEMAP_JSON = 'imagemap_json'
CONF_CMD = 'cmd'
CONF_LOCAL_STORE = "local_store"
CONF_PS4_IP = "ps4_ip"
PS4_GAMES_FILE = 'ps4-games.json'
MEDIA_IMAGE_DEFAULT = None
MEDIA_IMAGEMAP_JSON = 'https://github.com/hmn/ps4-imagemap/raw/master/games.json'
LOCAL_STORE = None
MIN_TIME_BETWEEN_SCANS = timedelta(seconds=10)
MIN_TIME_BETWEEN_FORCED_SCANS = timedelta(seconds=1)
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
vol.Required(CONF_HOST): cv.string,
vol.Optional(CONF_PS4_IP): cv.string,
vol.Optional(CONF_NAME, default=DEFAULT_NAME): cv.string,
vol.Optional(CONF_GAMES_FILENAME, default=PS4_GAMES_FILE): cv.string,
vol.Optional(CONF_IMAGEMAP_JSON, default=MEDIA_IMAGEMAP_JSON): cv.string,
vol.Optional(CONF_LOCAL_STORE, default=LOCAL_STORE): cv.string,
def setup_platform(hass, config, add_devices, discovery_info=None):
"""Setup PS4 platform."""
if discovery_info is not None:
ip = urlparse(discovery_info[1]).hostname
else:
ip = config.get(CONF_PS4_IP)
if ip is None:
_LOGGER.error("No PS4 found in configuration file or with discovery")
return False
host = config.get(CONF_HOST)
name = config.get(CONF_NAME)
games_filename = hass.config.path(config.get(CONF_GAMES_FILENAME))
games_map_json = config.get(CONF_IMAGEMAP_JSON)
local_store = config.get(CONF_LOCAL_STORE)
ps4 = PS4Waker(host, ip, games_filename)
add_devices([PS4Device(name, ps4, games_map_json, local_store)], True)
class PS4Device(MediaPlayerDevice):
"""Representation of a PS4."""
def __init__(self, name, ps4, gamesmap_json, local_store):
"""Initialize the ps4 device."""
self.ps4 = ps4
self._name = name
self._state = STATE_UNKNOWN
self._media_content_id = None
self._media_title = None
self._current_source = None
self._current_source_id = None
self._games_map_json = gamesmap_json
self._games_map = {}
self._local_store = local_store
if self._local_store is None:
self.load_games_map()
self.update()
@util.Throttle(MIN_TIME_BETWEEN_SCANS, MIN_TIME_BETWEEN_FORCED_SCANS)
def update(self):
"""Retrieve the latest data."""
data = self.ps4.search()
self._media_title = data.get('running-app-name')
self._media_content_id = data.get('running-app-titleid')
self._current_source = data.get('running-app-name')
self._current_source_id = data.get('running-app-titleid')
if data.get('status') == 'Ok':
if self._media_content_id is not None:
self._state = STATE_PLAYING
else:
self._state = STATE_IDLE
else:
self._state = STATE_OFF
def load_games_map(self):
try:
self._games_map = json.loads(requests.get(self._games_map_json, verify=False))
except Exception as e:
_LOGGER.error("gamesmap json file could not be loaded, %s" % e)
@property
def entity_picture(self):
if self.state == STATE_OFF:
return None
image_hash = self.media_image_hash
if image_hash is None:
return None
return ENTITY_IMAGE_URL.format(
self.entity_id, self.access_token, image_hash)
if self._media_content_id is None:
return None
filename = "/local/%s/%s.jpg" % (self._local_store, self._media_content_id)
return filename
@property
def name(self):
"""Return the name of the device."""
return self._name
@property
def state(self):
"""Return the state of the device."""
return self._state
@property
def icon(self):
"""Icon."""
return ICON
@property
def media_content_id(self):
"""Content ID of current playing media."""
return self._media_content_id
@property
def media_content_type(self):
"""Content type of current playing media."""
return MEDIA_TYPE_CHANNEL
@property
def media_image_url(self):
"""Image url of current playing media."""
return MEDIA_IMAGE_DEFAULT
try:
return self._games_map[self._media_content_id]
except KeyError:
@property
def media_title(self):
"""Title of current playing media."""
return self._media_title
@property
def supported_features(self):
"""Media player features that are supported."""
return SUPPORT_PS4
@property
def source(self):
"""Return the current input source."""
return self._current_source
@property
def source_list(self):
"""List of available input sources."""
return sorted(self.ps4.games.values())
def turn_off(self):
"""Turn off media player."""
self.ps4.standby()
def turn_on(self):
"""Turn on the media player."""
self.ps4.wake()
self.update()
def media_pause(self):
"""Send keypress ps to return to menu."""
self.ps4.remote('ps')
self.update()
def media_stop(self):
self.update()
def select_source(self, source):
"""Select input source."""
for titleid, game in self.ps4.games.items():
if source == game:
self.ps4.start(titleid)
self._current_source_id = titleid
self._current_source = game
self._media_content_id = titleid
self._media_title = game
self.update()
class PS4Waker(object):
"""Rest client for handling the data retrieval."""
def __init__(self, url, ip, games_filename):
"""Initialize the data object."""
self._url = url
self._ip = ip
self._games_filename = games_filename
self.games = {}
self._load_games()
def __call(self, command, param=None):
url = '{0}/ps4/{1}/{2}'.format(self._url, self._ip, command)
if param is not None:
url += '/{0}'.format(param)
try:
response = requests.get(url, verify=False)
if 200 != response.status_code:
raise Exception(response.text)
return response.text
_LOGGER.error('Failed to call %s: %s', command, e)
return None
def _load_games(self):
try:
with open(self._games_filename, 'r') as f:
self.games = json.load(f)
f.close()
except FileNotFoundError:
self._save_games()
except ValueError as e:
_LOGGER.error('Games json file wrong: %s', e)
def _save_games(self):
try:
with open(self._games_filename, 'w') as f:
json.dump(self.games, f)
f.close()
pass
def wake(self):
"""Wake PS4 up."""
return self.__call('on')
def standby(self):
"""Set PS4 into standby mode."""
return self.__call('off')
def start(self, title_id):
"""Start game using titleId."""
return self.__call('start', title_id)
def remote(self, key):
"""Send remote key press."""
return self.__call('key', key)
def search(self):
"""List current info."""
value = self.__call('info')
if value is None:
return {}
try:
data = json.loads(value)
except json.decoder.JSONDecodeError as e:
_LOGGER.error("Error decoding ps4 json : %s", e)
data = {}
"""Save current game"""
if data.get('running-app-titleid'):
if data.get('running-app-titleid') not in self.games.keys():
game = {data.get('running-app-titleid'):
data.get('running-app-name')}
self.games.update(game)
self._save_games()
return data
[/details]
and her is my /config/mediaplayer.yaml
- platform: ps4
host: http://10.1.1.42:3031
ps4_ip: 10.1.1.207
local_store: games
- platform: vizio
host: 10.1.1.37
access_token: Zml5ui0gxc
