I used your earlier method of generating certs and Xcel Energy launchpad devices. I haven’t heard back from xcel yet so I don’t know if it works or not.
I’m going to try your new method, but I’m trying to get @SergeantScar 's LFDI working.
I posted a message just above yours. I can ssh into home assistant to execute these commands to get watts and kWh. But when I try to execute the same commands in configuration.yaml, I get an error that says Command failed (with return code 1): /usr/bin/curl
I don’t know why it doesn’t work. It looks just like yours.
I’ve been trying to get this up and running for the last couple days. I added my meter to my wifi network, found it on my controller, and locked it to a certain AP because it kept finding a further away one rather than a closer one with a better signal. It has now been on the network for 17hrs and I’ve generated a pair of keys and added it as an LFDI to my Xcel account, but cannot get any response from the meter on my network. I also don’t get a ping response from the meter either.
If I can get it up and running I’m looking at making a container to use the mDNS functionality to make it easier to find the meter and automate the process a bit more. Then I want to convert the API outputs from the meter and broadcast them via MQTT to more easily integrate the messages into HomeAssisstant.
So the Xcel site shows my meter is “Ready to Go” and I can see its IP on my network. However, I cannot seem to get the website to accept the registration. I have an LFDI based on pdubs10’s latest message, but I just keep getting an unsuccessful message. Does anybody have any thoughts?
I believe something is incorrect with my registration based on comments in this thread, but could someone confirm? I wasn’t ever prompted to set up my WIFI network when registering my meter and attempting to add a new device (using the LFID/certs above or generating my own) doesn’t work because I’m never prompted for the certificate itself. Am I missing a step or does something look incorrect?
I’ll have to look into it later, but thats a lot more promising that zero response from the meter. Looks like registration might be taking a little longer right now?
I’m having the same issue. When I logged into launchpad a few days ago I was prompted to input my wifi network information and noticed the note that it only supported 2.4ghz. In the couple days it took me to get a 2.4ghz access point and set it up, it appears that something has gone wrong on xcel’s side. I’m now not able to bring up the wifi information screen. I tried calling the support number listed on that page and the xcel rep had absolutely no idea what I was talking about.
I had the same experience calling 4 different times. I haven’t been able to find an email addresses, I’m going to email the one @pdubs10 listed and see if they can assist.
