XIAO ESP32C3 not sending mmWave sensor data
I just got my hands on some:
Seeed-XIAO-ESP32C3
Seeed 24GHz mmWave Sensor
Seeed got a blog post containing a tutorial on how to set this up with ESPHome.
I’ve of course followed the tutorial very thoroughly. The ESP will connect to Home Assistant, but it won’t send me any sensor data at all. Logs are not telling me anything, it’s like the mmWave sensor is not even connected to the ESP. I have tripple checked the wiring, tried with three different esp’s and sensors.
Help me please :slight_smile:
ESPHome log:
INFO Reading configuration /config/esphome/ny.yaml...
INFO Starting log output from ny.local using esphome API
INFO Successfully connected to ny.local
[23:53:06][I][app:102]: ESPHome version 2023.3.1 compiled on Mar 25 2023, 21:01:17
[23:53:06][C][wifi:504]: WiFi:
[23:53:06][C][wifi:362]:   Local MAC: 34:85:18:05:43:E0
[23:53:06][C][wifi:363]:   SSID: [redacted]
[23:53:06][C][wifi:364]:   IP Address: 192.168.1.101
[23:53:06][C][wifi:366]:   BSSID: [redacted]
[23:53:06][C][wifi:367]:   Hostname: 'ny'
[23:53:06][C][wifi:369]:   Signal strength: -46 dB ▂▄▆█
[23:53:06][C][wifi:373]:   Channel: 6
[23:53:06][C][wifi:374]:   Subnet: 255.255.255.0
[23:53:06][C][wifi:375]:   Gateway: 192.168.1.1
[23:53:06][C][wifi:376]:   DNS1: 192.168.1.1
[23:53:06][C][wifi:377]:   DNS2: 0.0.0.0
[23:53:06][C][logger:293]: Logger:
[23:53:06][C][logger:294]:   Level: DEBUG
[23:53:06][C][logger:295]:   Log Baud Rate: 115200
[23:53:06][C][logger:296]:   Hardware UART: USB_SERIAL_JTAG
[23:53:06][C][uart.idf:116]: UART Bus:
[23:53:06][C][uart.idf:117]:   Number: 0
[23:53:06][C][uart.idf:118]:   TX Pin: GPIO21
[23:53:06][C][uart.idf:119]:   RX Pin: GPIO20
[23:53:06][C][uart.idf:121]:   RX Buffer Size: 256
[23:53:06][C][uart.idf:123]:   Baud Rate: 115200 baud
[23:53:06][C][uart.idf:124]:   Data Bits: 8
[23:53:06][C][uart.idf:125]:   Parity: NONE
[23:53:06][C][uart.idf:126]:   Stop bits: 1
[23:53:06][C][template.select:065]: Template Select 'Standard Scene mode'
[23:53:06][C][template.select:065]:   Icon: 'mdi:hoop-house'
[23:53:06][C][template.select:066]:   Update Interval: 60.0s
[23:53:06][C][template.select:069]:   Optimistic: YES
[23:53:06][C][template.select:070]:   Initial Option: Living room
[23:53:06][C][template.select:071]:   Restore Value: NO
[23:53:06][C][template.select:065]: Template Select 'Standard unmanned time'
[23:53:06][C][template.select:065]:   Icon: 'mdi:timeline-clock'
[23:53:06][C][template.select:070]:   Initial Option: None
[23:53:06][C][template.select:065]: Template Select 'Custom Presence of perception boundary'
[23:53:06][C][template.select:070]:   Initial Option: 0.5m
[23:53:06][C][template.select:065]: Template Select 'Custom Motion trigger boundary'
[23:53:06][C][template.number:050]: Template Number 'Standard sensitivity'
[23:53:06][C][template.number:050]:   Icon: 'mdi:archive-check-outline'
[23:53:06][C][template.number:051]:   Optimistic: NO
[23:53:06][C][template.number:052]:   Update Interval: 2.0s
[23:53:06][C][template.number:050]: Template Number 'Standard Maximum detectable range of moving target'
[23:53:06][C][template.number:050]:   Icon: 'mdi:map-marker-path'
[23:53:06][C][template.number:050]:   Unit of Measurement: 'cm'
[23:53:06][C][template.number:052]:   Update Interval: 60.0s
[23:53:06][C][template.number:050]: Template Number 'Standard Maximum detectable range of stationary target'
[23:53:06][C][template.number:050]: Template Number 'Custom Judgment threshold exists'
[23:53:06][C][template.number:050]: Template Number 'Custom Motion amplitude trigger threshold'
[23:53:06][C][template.number:050]: Template Number 'Custom Mode Settings'
[23:53:06][C][template.number:050]:   Icon: 'mdi:cog'
[23:53:06][C][template.number:050]: Template Number 'Custom Mode Settings End'
[23:53:06][C][template.number:050]: Template Number 'Custom Custom Mode Query'
[23:53:06][C][template.number:050]: Template Number 'Custom Motion trigger time'
[23:53:06][C][template.number:050]:   Icon: 'mdi:camera-timer'
[23:53:06][C][template.number:050]:   Unit of Measurement: 'ms'
[23:53:06][C][template.number:050]: Template Number 'Custom Movement to rest time'
[23:53:06][C][template.number:050]: Template Number 'Custom Time of entering unmanned state'
[23:53:06][C][template.text_sensor:021]: Template Sensor 'Standard Product model'
[23:53:06][C][template.text_sensor:021]:   Icon: 'mdi:information-outline'
[23:53:06][C][template.text_sensor:021]: Template Sensor 'Standard Product ID'
[23:53:06][C][template.text_sensor:021]: Template Sensor 'Standard Hardware model'
[23:53:06][C][template.text_sensor:021]: Template Sensor 'Standard Firmware version'
[23:53:07][C][template.text_sensor:021]:   Icon: 'mdi:information-outline'
[23:53:07][C][template.text_sensor:021]: Template Sensor 'Standard protocol type'
[23:53:07][C][template.text_sensor:021]: Template Sensor 'Standard moving direction'
[23:53:07][C][template.text_sensor:021]:   Icon: 'mdi:walk'
[23:53:07][C][template.text_sensor:021]: Template Sensor 'Standard Sports information'
[23:53:07][C][template.text_sensor:021]:   Icon: 'mdi:human-greeting'
[23:53:07][C][template.text_sensor:021]: Template Sensor 'Standard Presence information'
[23:53:07][C][template.text_sensor:021]:   Icon: 'mdi:motion-sensor'
[23:53:07][C][template.text_sensor:021]: Template Sensor 'Custom Presence of detection'
[23:53:07][C][template.text_sensor:021]:   Icon: 'mdi:signal-distance-variant'
[23:53:07][C][template.switch:076]: Template Switch 'Custom Infor output switch'
[23:53:07][C][template.switch:078]:   Icon: 'mdi:electric-switch'
[23:53:07][C][template.switch:081]:   Assumed State: YES
[23:53:07][C][template.switch:099]:   Restore Mode: restore defaults to OFF
[23:53:07][C][template.switch:060]:   Restore State: NO
[23:53:07][C][template.switch:061]:   Optimistic: NO
[23:53:07][C][template.sensor:023]: Template Sensor 'Custom Motion distance'
[23:53:07][C][template.sensor:023]:   State Class: ''
[23:53:07][C][template.sensor:023]:   Unit of Measurement: ''
[23:53:07][C][template.sensor:023]:   Accuracy Decimals: 1
[23:53:07][C][template.sensor:023]:   Icon: 'mdi:signal-distance-variant'
[23:53:07][C][template.sensor:024]:   Update Interval: 60.0s
[23:53:07][C][template.sensor:023]: Template Sensor 'Custom Static distance'
[23:53:07][C][template.sensor:023]: Template Sensor 'Custom Spatial static value'
[23:53:07][C][template.sensor:023]:   Icon: 'mdi:counter'
[23:53:07][C][template.sensor:023]: Template Sensor 'Custom Spatial motion value'
[23:53:07][C][template.sensor:023]: Template Sensor 'Custom Motion speed'
[23:53:07][C][template.sensor:023]:   Icon: 'mdi:run-fast'
[23:53:07][C][mdns:108]: mDNS:
[23:53:07][C][mdns:109]:   Hostname: ny
[23:53:07][C][ota:093]: Over-The-Air Updates:
[23:53:07][C][ota:094]:   Address: ny.local:3232
[23:53:07][C][ota:097]:   Using Password.
[23:53:07][C][api:138]: API Server:
[23:53:07][C][api:139]:   Address: ny.local:6053
[23:53:07][C][api:141]:   Using noise encryption: YES
ESPHome sensor .yaml:
esphome:
  platformio_options:
    board_build.flash_mode: dio
    board_build.mcu: esp32c3
  includes:
  - R24dvd.h
esp32:
  board: esp32-c3-devkitm-1
  variant: esp32c3
  framework:
    type: esp-idf
# Enable logging
logger:
  hardware_uart: USB_SERIAL_JTAG
  level: VERY_VERBOSE
# Enable Home Assistant API
api:
  encryption:
    key: "*************"
ota:
  password: "**********"
wifi:
  ssid: Tunling
  password: *********
  ap:
    ssid: "Ny Fallback Hotspot"
    password: "YVpZCs0k4xnY"
uart:
  baud_rate:  115200
  rx_pin: 20
  tx_pin: 21
select:
    name: "Standard Scene mode"
    icon: mdi:hoop-house
    optimistic: true
    options:
      - "Living room"
      - "Area detection"
      - "Washroom"
      - "Bedroom"
    initial_option: "Living room"
    set_action:
      - logger.log:
            format: "set action option: %s"
            args: ["x.c_str()"]
      - uart.write: !lambda
                  auto index = id(scene_mode).index_of(x);
                  uint8_t value = (uint8_t)index.value() + 1;
                  uint8_t crc = value + 0xB9;
                  return {0x53,0x59,0x05,0x07,0x00,0x01,value,crc,0x54,0x43};
    name: "Standard unmanned time"
    icon: mdi:timeline-clock
    optimistic: true
    options:
      - "None"
      - "10s"
      - "30s"
      - "1min"
      - "2min"
      - "5min"
      - "10min"
      - "30min"
      - "1hour"
    initial_option: "None"
    set_action:
      - logger.log:
            format: "Chosen option: %s"
            args: ["x.c_str()"]
                  auto index = id(unmanned_time).index_of(x);
                  uint8_t value = (uint8_t)index.value();
                  uint8_t crc = value + 0x37;
                  return {0x53,0x59,0x80,0x0a,0x00,0x01,value,crc,0x54,0x43};
    name: "Custom Presence of perception boundary"
    optimistic: true
    options:
      - "0.5m"
      - "1.0m"
      - "1.5m"
      - "2.0m"
      - "2.5m"
      - "3.0m"
      - "3.5m"
      - "4.0m"
      - "4.5m"
      - "5.0m"
    set_action:
      - logger.log:
            args: ["x.c_str()"]
                  uint8_t crc = value + 0xBF;
                  return {0x53,0x59,0x08,0x0a,0x00,0x01,value,crc,0x54,0x43};
    name: "Custom Motion trigger boundary"
    optimistic: true
    options:
      - "0.5m"
      - "1.0m"
      - "1.5m"
      - "2.0m"
      - "2.5m"
      - "3.0m"
      - "3.5m"
      - "4.0m"
      - "4.5m"
      - "5.0m"
    set_action:
      - logger.log:
            args: ["x.c_str()"]
                  uint8_t crc = value + 0xC0;
                  return {0x53,0x59,0x08,0x0b,0x00,0x01,value,crc,0x54,0x43};
number:
    name: "Standard sensitivity"
    icon: mdi:archive-check-outline
    min_value: 0
    max_value: 3
    optimistic: false
    step: 1
    update_interval: 2s
    set_action:
                    uint8_t crc = x + 0xBA;
                    return {0x53,0x59,0x05,0x08,0x00,0x01,(uint8_t)x,crc,0x54,0x43};
    name: "Standard Maximum detectable range of moving target"
    icon: mdi:map-marker-path
    unit_of_measurement: "cm"
    min_value: 0
    max_value: 65536
    step: 500
    set_action:
                    int h_num = (int)x >> 8;
                    int l_num = (int)x & 0xff;
                    int crc = 0xB6 + h_num + l_num;
                    return {0x53,0x59,0x07,0x01,0x00,0x02,(uint8_t)(h_num),(uint8_t)(l_num),(uint8_t)crc,0x54,0x43};
    name: "Standard Maximum detectable range of stationary target"
    unit_of_measurement: cm
    min_value: 0
    max_value: 65536
    step: 500
    set_action:
                    int crc = 0xB9 + h_num + l_num;
                    return {0x53,0x59,0x07,0x04,0x00,0x02,(uint8_t)(h_num),(uint8_t)(l_num),(uint8_t)crc,0x54,0x43};
    name: "Custom Judgment threshold exists"
    min_value: 0
    max_value: 250
    step: 1
    set_action:
                    int crc = 0xBD + (int)x;
                    return {0x53,0x59,0x08,0x08,0x00,0x01,(uint8_t)x,(uint8_t)crc,0x54,0x43};
    name: "Custom Motion amplitude trigger threshold"
    min_value: 0
    max_value: 250
    step: 1
    set_action:
                    int crc = 0xBE + (int)x;
                    return {0x53,0x59,0x08,0x09,0x00,0x01,(uint8_t)x,(uint8_t)crc,0x54,0x43};
    name: "Custom Mode Settings"
    icon: mdi:cog
    min_value: 0
    max_value: 250
    step: 1
    set_action:
                    int crc = 0xBB + (int)x;
                    return {0x53,0x59,0x05,0x09,0x00,0x01,(uint8_t)x,(uint8_t)crc,0x54,0x43};
    name: "Custom Mode Settings End"
    icon: mdi:cog
    min_value: 0
    max_value: 250
    step: 1
    set_action:
                    int crc = 0xBC + (int)x;
                    return {0x53,0x59,0x05,0x0a,0x00,0x01,(uint8_t)x,(uint8_t)crc,0x54,0x43};
    name: "Custom Custom Mode Query"
    icon: mdi:cog
    min_value: 0
    max_value: 250
    step: 1
    set_action:
                    int crc = 0x3B + (int)x;
                    return {0x53,0x59,0x05,0x89,0x00,0x01,(uint8_t)x,(uint8_t)crc,0x54,0x43};
    name: "Custom Motion trigger time"
    icon: mdi:camera-timer
    unit_of_measurement: "ms"
    min_value: 0
    max_value: 4294967295
    step: 5000
    set_action:
                    int crc = 0xC4 + (int)x;
                    int h24_num = ((int)x >> 24) & 0xff;
                    int h16_num = ((int)x >> 16) & 0xff;
                    int h8_num = ((int)x >> 8) & 0xff;
                    int l8_num = (int)x & 0xff;
                    return {0x53,0x59,0x08,0x0c,0x00,0x04,(uint8_t)h24_num,(uint8_t)h16_num,(uint8_t)h8_num,(uint8_t)l8_num,(uint8_t)crc,0x54,0x43};
    name: "Custom Movement to rest time"
    min_value: 0
    step: 5000
    set_action:
                    int crc = 0xC5 + (int)x;
                    return {0x53,0x59,0x08,0x0d,0x00,0x04,(uint8_t)h24_num,(uint8_t)h16_num,(uint8_t)h8_num,(uint8_t)l8_num,(uint8_t)crc,0x54,0x43};
    name: "Custom Time of entering unmanned state"
    min_value: 0
    step: 5000
    set_action:
                    int crc = 0xC6 + (int)x;
                    return {0x53,0x59,0x08,0x0e,0x00,0x04,(uint8_t)h24_num,(uint8_t)h16_num,(uint8_t)h8_num,(uint8_t)l8_num,(uint8_t)crc,0x54,0x43};
text_sensor:
- platform: custom
  lambda: |-
    auto my_custom_sensor = new MyCustomTextSensor();
    App.register_component(my_custom_sensor);
    return {my_custom_sensor->Heartbeat};
  text_sensors:
    - name: "Standard Heartbeat"
      icon: mdi:connection
  name: "Standard Product model"
  icon: mdi:information-outline
  on_raw_value:
    then:
      - logger.log: text_sensor on_raw_value
  name: "Standard Product ID"
  name: "Standard Hardware model"
  name: "Standard Firmware version"
  name: "Standard protocol type"
  name: "Standard moving direction"
  icon: mdi:walk
  name: "Standard Sports information"
  icon: mdi:human-greeting
  name: "Standard Presence information"
  icon: "mdi:motion-sensor"
  name: "Custom Presence of detection"
  icon: mdi:signal-distance-variant
# - platform: template
#   name: "Custom Motion distance"
#   id: custom_motion_distance
#   name: "Custom Static distance"
#   id: custom_static_distance
#   name: "Custom Spatial static value"
#   id: custom_spatial_static_value
#   name: "Custom Spatial motion value"
#   id: custom_spatial_motion_value
#   name: "Custom Motion speed"
#   id: custom_motion_speed
button:
    icon: mdi:reload
    on_press:
      then:
        - logger.log: Button Pressed
        - uart.write: [0x53,0x59,0x01,0x02,0x00,0x01,0x0F,0xBF,0x54,0x43]
switch:
    name: "Custom Infor output switch"
    icon: mdi:electric-switch
    assumed_state: true
    turn_on_action:
      - uart.write: [0x53,0x59,0x08,0x00,0x00,0x01,0x01,0xB6,0x54,0x43]
      - delay: 1s
      - lambda: !lambda |-
          id(product_mode).publish_state("");
          id(product_id).publish_state("");
          id(hardware_model).publish_state("");
          id(firmware_version).publish_state("");
          id(protocol_type).publish_state("");
    turn_off_action:
      - uart.write: [0x53,0x59,0x08,0x00,0x00,0x01,0x00,0xB5,0x54,0x43]
- platform: custom
  lambda: |-
    auto my_custom_sensor = new UartReadLineSensor(id(uart_bus));
    return {
      my_custom_sensor->movementSigns,
      my_custom_sensor->inited,
  sensors:
    - name: "Standard body movement"
      icon: "mdi:human-greeting-variant"
      device_class: "temperature"
      state_class: "measurement"
    - name: "Standard inited"
      icon: mdi:all-inclusive
  on_value:
    then:
      # - logger.log: Custom Motion distance on_value
      - logger.log:
            format: "Custom Motion distance on_value : %d"
            args: ["x"]
  on_raw_value:
    then:
      - logger.log:
            format: "Custom Motion distance on_raw_value : %d"
            args: ["x"]
  icon: mdi:counter
  icon: mdi:counter
  icon: mdi:run-fast
Link to the blog post as I could not post more than two links as a new forum user :stuck_out_tongue:
This code is simply crazy. All serial port operations are in the yaml source code. Compared with the ld2410b library, it is much simplified.
The time of the posted log is too short, and the feedback information of the serial port cannot be seen from it.
Same problem here, did you solve the problem?
I also can’t turn on the sensor with the lighting button
Yep! See this post:
Tried that and still same problem, Soldered the wires to ensure connection and still no com with the module. R24d does get power because it feels warm.
Hmm… weird. Are you sure you have tx/rx wired correctly?
tx - rx
rx - tx
Post your config please :slight_smile:
Yup TX to RX and RX to TX. Also tried to switch TX TX .
Someone said to try D2 D3 and again same, Can’t even turn it on, Straight back to OFF.
# part 1:
esphome:
  platformio_options:
  includes:
  - R24dvd.h
esp32:
  variant: esp32c3
  framework:
    type: esp-idf
#Enable logging
logger:
  level: DEBUG
api:
  encryption:
    key: "EDIT"
ota:
  password: "EDIT"
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: 192.168.1.50
    gateway: 192.168.1.11
    subnet: 255.255.255.0
    dns1: 192.168.1.11
  ap:
    ssid: "Xiao-Esp32 Fallback Hotspot"
    password: "EDIT"
# part 3:
uart:
  baud_rate:  115200
  rx_pin: 2
  tx_pin: 3
select:
    optimistic: true
    options:
      - "Living room"
      - "Area detection"
      - "Washroom"
      - "Bedroom"
    set_action:
      - logger.log:
            args: ["x.c_str()"]
    optimistic: true
    options:
      - "None"
      - "10s"
      - "30s"
      - "1min"
      - "2min"
      - "5min"
      - "10min"
      - "30min"
      - "1hour"
    set_action:
      - logger.log:
            args: ["x.c_str()"]
    optimistic: true
    options:
      - "0.5m"
      - "1.0m"
      - "1.5m"
      - "2.0m"
      - "2.5m"
      - "3.0m"
      - "3.5m"
      - "4.0m"
      - "4.5m"
      - "5.0m"
    set_action:
      - logger.log:
            args: ["x.c_str()"]
    optimistic: true
    options:
      - "0.5m"
      - "1.0m"
      - "1.5m"
      - "2.0m"
      - "2.5m"
      - "3.0m"
      - "3.5m"
      - "4.0m"
      - "4.5m"
      - "5.0m"
    set_action:
      - logger.log:
            args: ["x.c_str()"]
number:
    min_value: 0
    max_value: 3
    optimistic: false
    step: 1
    update_interval: 2s
    set_action:
    min_value: 0
    max_value: 65536
    step: 500
    set_action:
    min_value: 0
    max_value: 65536
    step: 500
    set_action:
    min_value: 0
    max_value: 250
    step: 1
    set_action:
    min_value: 0
    max_value: 250
    step: 1
    set_action:
    icon: mdi:cog
    min_value: 0
    max_value: 250
    step: 1
    set_action:
    icon: mdi:cog
    min_value: 0
    max_value: 250
    step: 1
    set_action:
    icon: mdi:cog
    min_value: 0
    max_value: 250
    step: 1
    set_action:
    min_value: 0
    step: 5000
    set_action:
    min_value: 0
    step: 5000
    set_action:
    min_value: 0
    step: 5000
    set_action:
text_sensor:
- platform: custom
  lambda: |-
  text_sensors:
  on_raw_value:
    then:
  icon: mdi:walk
button:
    icon: mdi:reload
    on_press:
      then:
switch:
    assumed_state: true
    turn_on_action:
      - delay: 1s
    turn_off_action:
- platform: custom
  lambda: |-
    return {
  sensors:
  on_value:
    then:
      - logger.log:
            args: ["x"]
  on_raw_value:
    then:
      - logger.log:
            args: ["x"]
  icon: mdi:counter
  icon: mdi:counter
  icon: mdi:run-fast
On install I did notice this:
Logs when turning module on with lightning button.
[17:22:09][D][switch:013]: 'Custom Infor output switch' Turning ON.
[17:22:10][D][main:339]: text_sensor on_raw_value
[17:22:10][D][text_sensor:067]: 'Standard Product model': Sending state ''
[17:22:10][D][text_sensor:067]: 'Standard Product ID': Sending state ''
[17:22:10][D][text_sensor:067]: 'Standard Hardware model': Sending state ''
[17:22:10][D][text_sensor:067]: 'Standard Firmware version': Sending state ''
[17:22:10][D][text_sensor:067]: 'Standard protocol type': Sending state ''
Did you get anywhere with this? I am having the same issues, perhaps it is something with the xiao chips? I am not having any luck getting uart data from a ld2410b either…
No, still same problem
Not sure this is the same problem, I had my modules initially working for a few minutes then they stopped and I tried everything.
Found a recent update on the seeedstudio tutorial saying:
“As of June 1, 2023 troubleshooting has revealed that if you set any value or change any scene in the dashboard of ESPHome, there is a possibility that the radar will go down, we would like to inform you that the engineers of Seeed Studio are currently working intensively to troubleshoot the problem, until then, please do not adjust the values of the dashboard at will !!!”
I have the same issue here, I bought 10 sensors and already tried 3 of them, before hooking to the ESP32C3 I did try them with USB-UART bridge to make sure they were working with the PC. One out of the 3 trials I got the sensor working for a while then it stopped. After that I tried it with PC and it just didn’t work anymore. I seriously doube the HW of the sensor design.
There was an issue with the SW from Seeed Studio for the ESP32C3 that caused the mmWave sensor to go in a blocked state. They have provided an SW update, but I thing it does not “unlock” devices that do not respond any longer. See also: Seeed Studio XIAO ESP32C3 Wiki in the “Getting started” section.
