Xiaomi Air Purifier - Show all sensors and Switches in UI and HomeKit
I have latest HA (104.2) and device is: fan.xiaomi… but most of services are xiaomi_miio.fan_…. but fan speed is still fan.set_speed
Bit of confusing :confused:
Does anybody have an idea how to realize some kind of “scan_interval” for the template sensors or the integration itself? I don’t need the chatty 30 seconds updates in my database. So of course I could delete the template sensors not really needed (e.g. fan speed), but the main integration will update itself every 30 seconds and I assume that the attributes are also recorded and saved in the the database all the time?
Edit: Okay that was too obvious. Just add scan_interval to the configuration.yaml. It works, even it’s not documented.
does anybody know if version 3 / 3h is supported?
@sobczynski in your config and auto, appear 2 errors in HA 0.105.4
Invalid option: auto (possible options: Auto, Silent, Favorite)
and
Error rendering data template: UndefinedError: 'input_number' is undefined
how too solved
I’m not sure how to solve it, but I had already noticed that the Xiaomi purifier has a small issue: it provides status as lowercase (auto, silent, favourite), but accepts status setting using capitals (Auto, Silent, Favorite).
This way when the automations compare the value seti in Lovelace with the value reported from Xiaomi, the two don’t match perfectly due to capitalization.
Or at least this was what I got from the error logs, then I temporarily abandoned the issue because I don’t change settings from Lovelace anyway, but I know they one day I’ll have to find out how to solve the issue.
Other issue, i put the auto of OP, but the Airpurifier not turn OFF !! eny idea?
model: zhimi.airpurifier.v7
Home Assistant 0.105.5
same here.
The config is the following:
input_select:
  # Xiaomi Air Purifier 2S
  xiaomi_airpurifier_mode:
    options:
      - Auto
      - Silent
      - Favorite
    icon: "mdi:animation-outline"
Any hint?
I asked in a new thread. How to compare values differing for upper/lower case?
I won’t have access to my server for a while, but try this: stop HA, go to the folder where HA is installed, look for the components subfolder, then for xiaomi_miio, then edit the file fan.py.
In that file look for the text “Silent” (it appears only in few lines) and replace all occurrences of the uppercase Auto, Silent, Favourite with the lowercase equivalents.
Start HA and see if the fan still works and accept the new statuses. The automations should be adapted to also have everything lowercase.
If it works, the Xiaomi component should be updated. If not, the component needs to implement a case conversion.
Forget my suggestion.
The thread linked provided the solution.
Alternative solution: Capitalize()
Sorry but just to be sure.
So this
  speed: '{{ states.input_select.xiaomi_airpurifier_mode.state }}'
will become this
  speed: '{{ states.input_select.xiaomi_airpurifier_mode.state | capitalize }}'
and so on. Right?
That syntax is deprecated as far as I know. You should use “state_attr()”
This is mine:
  alias: 'Air Purifier: mode changed to UI'
    platform: state
    entity_id: fan.air_purifier_living_room
  condition:
    condition: and
    conditions:
    - condition: template
      value_template: '{{ (state_attr(''fan.air_purifier_living_room'', ''mode'') | string | capitalize)
        != (states(''input_select.air_purifier_living_room_mode'') | string)
  - service: input_select.select_option
    entity_id: input_select.air_purifier_living_room_mode
    data_template:
      option: '{{ state_attr(''fan.air_purifier_living_room'', ''mode'') | capitalize }}'
The " | string " may not be necessary
Maybe someone will come in handy, works on Home Assistant 0.105.5 and air purifier 2s
 configuration.yaml
fan:
  - platform: xiaomi_miio
    host: your ip
    token: your token
input_select:
         options:
          - Auto
          - Silent
          - Favorite
input_number:
    xiaomi_airpurifie_favorite_level:
        initial: 0
        min: 0
        max: 14
        step: 1
        icon: "mdi:weather-windy"
 sensors.yaml
    sensors:
      xiaomi_airpurifier_temp:
        friendly_name: "Temperature"
        value_template: "{{ state_attr('fan.xiaomi_miio_device', 'temperature') }}"
        unit_of_measurement: "°C"
        device_class: "temperature"
      xiaomi_airpurifier_humidity:
        friendly_name: "Humidity"
        value_template: "{{ state_attr('fan.xiaomi_miio_device', 'humidity') }}"
        unit_of_measurement: "%"
        device_class: "humidity"
      xiaomi_airpurifier_air_quality_pm25:
        friendly_name: "Air quality"
        value_template: "{{ state_attr('fan.xiaomi_miio_device', 'aqi') }}"
        unit_of_measurement: "μg/m³"
        icon_template: "mdi:weather-fog"
      xiaomi_airpurifier_speed:
        friendly_name: "Fan speed"
        value_template: "{{ state_attr('fan.xiaomi_miio_device', 'motor_speed') }}"
        unit_of_measurement: "rpm"
        icon_template: "mdi:speedometer"
      xiaomi_airpurifier_filter_remaining:
        friendly_name: "Filter remaining"
        value_template: "{{ state_attr('fan.xiaomi_miio_device', 'filter_life_remaining') }}"
        icon_template: "mdi:heart-outline"
      xiaomi_airpurifier_illuminance:
        friendly_name: "Filter illuminance"
        value_template: "{{ state_attr('fan.xiaomi_miio_device', 'illuminance') }}"
        unit_of_measurement: "lx"
        icon_template: "mdi:brightness-5"
automations.yaml
- alias: Air Purifier mode change
    entity_id: input_select.xiaomi_airpurifier_mode
    platform: state
    service: fan.set_speed
    data_template:
      entity_id: fan.xiaomi_miio_device
- alias: Air Purifier favorite level change
    entity_id: input_number.xiaomi_airpurifie_favorite_level
    platform: state
    service: xiaomi_miio.fan_set_favorite_level
    data_template:
      level: '{{ states.input_number.xiaomi_airpurifie_favorite_level.state | int }}'
switch.yaml
  switches:
    xiaomi_airpurifier_led:
      friendly_name: "led"
      value_template: "{{ is_state_attr('fan.xiaomi_miio_device', 'led', true) }}"
      turn_on:
        service: xiaomi_miio.fan_set_led_on
      turn_off:
        service: xiaomi_miio.fan_set_led_off
      icon_template: "mdi:lightbulb-outline"
    xiaomi_airpurifier_child_lock:
      friendly_name: "Child lock"
      value_template: "{{ is_state_attr('fan.xiaomi_miio_device', 'child_lock', true) }}"
      turn_on:
        service: xiaomi_miio.fan_set_child_lock_on
      turn_off:
        service: xiaomi_miio.fan_set_child_lock_off
      icon_template: "mdi:lock-outline"
    xiaomi_airpurifier_buzzer:
      friendly_name: "Buzzer"
      value_template: "{{ is_state_attr('fan.xiaomi_miio_device', 'buzzer', true) }}"
      turn_on:
        service: xiaomi_miio.fan_set_buzzer_on
      turn_off:
        service: xiaomi_miio.fan_set_buzzer_off
      icon_template: "mdi:volume-high"
ui-lovelace.yaml
        - type: entities
          show_header_toggle: false
          entities:
            - entity: fan.xiaomi_miio_device
            - entity: sensor.xiaomi_airpurifier_speed
            - entity: switch.xiaomi_airpurifier_led
            - entity: switch.xiaomi_airpurifier_buzzer
            - entity: switch.xiaomi_airpurifier_child_lock
            - entity: sensor.xiaomi_airpurifier_illuminance
            - entity: input_select.xiaomi_airpurifier_mode
            - entity: input_number.xiaomi_airpurifie_favorite_level
            - entity: sensor.xiaomi_airpurifier_temp
              icon: mdi:temperature-celsius
            - entity: sensor.xiaomi_airpurifier_humidity
              icon: mdi:water-percent
            - entity: sensor.xiaomi_airpurifier_air_quality_pm25
              icon: mdi:hexagon-multiple
Hey guys, i have 2 purifiers a 2s and a pro. I cannot get both of them to work at the same time, if only 1 is added it works, the moment i define the second one, the first goes offline.
i define each as a separate entity, do i need to use
fan:
fans:
purifier1:
purifier2:
Write it like this:
fan:
    name: Air Purifier 1
    host: Your IP
    token: Your token
    name: Air Purifier 2
    host: Your IP
    token: Your token
Hey guys! Sorry I didnt receive any mails for this post. They made breaking changes so the names of the services have changed and some buttons were no more working. I updated my initial post so now everythings works again!
What never worked for me is the “Fan speed”. When rebooting hass.io it shows the current value but then never gets updated. Someone has an idea for that?
Yes you can have more than one. I have two. Unfortunately you have to duplicate the configuration but set a different name. I tried to keep mine organized by making comments with #.
For example my configuration.yaml.
fan:
  # Xiaomi Air Purifier 2S (bedroom)
    host: 192.168.178.101
    token: d40e9fc6e92a34cdd92aad38c90b2ed6
    name: "Air Purifier 2S (bedroom)"
  # Xiaomi Air Purifier 2S (living room)
    host: 192.168.178.102
    token: 46bd5a3951a607d21710a10e1b47c86b
    name: "Air Purifier 2S (living room)"
And then my devices are named fan.air_purifier_2s_bedroom and fan.air_purifier_2s_living_room. You can find the names developer tools -> entity autocomplete.
Maybe I did something wrong, but when I start the application, the favorite mode’s slider is set to 0 (initial: 0) despite of checking the actual value. Is it possible to query its setting and start with that one?
That are the two things I didnt figure out yet:
  1. On restart the favorite level is not being set
  2. The fan speed is only set once after restart, but never updated
