Xiaomi Chuangmi_ir (Universal IR Remote Controller)
The homeassistant api for services has changed. I will update the component!
Could you please post your configuration.yaml. The code of the custom component looks good. I assume your configuration doesn’t looks like this:
switch:
  - platform: chuangmi_ir
    host: !secret chuangmi_ip
    token: !secret chuangmi_key
    switches:
      tv:
        command_on: ''
        command_off: ''
Looks exactly like that. Problems started when updated to 0.61.
Will wait for the update of the component.
Alright. I found the issue. Please update your custom component:
Nice work! Works great.
But command is switch.send_command_192_xxx
Maybe it would be more convenient if it was switch.chuangmi_send_command_192_xxx
If one use different IR platforms
You are totally right. I will refactor the code soon.
I updated the component and I get this error.
Error while setting up platform chuangmi_ir
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 171, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
  File "/usr/lib/python3.6/asyncio/tasks.py", line 358, in wait_for
    return fut.result()
  File "/usr/lib/python3.6/asyncio/futures.py", line 245, in result
    raise self._exception
  File "/usr/lib/python3.6/concurrent/futures/thread.py", line 56, in run
  File "/config/custom_components/switch/chuangmi_ir.py", line 64, in setup_platform
    from miio import ChuangmiIr, DeviceException
  File "/usr/lib/python3.6/site-packages/miio/__init__.py", line 2, in <module>
    from miio.protocol import Message, Utils
  File "/usr/lib/python3.6/site-packages/miio/protocol.py", line 21, in <module>
    from construct import (Struct, Bytes, Const, Int16ub, Int32ub, GreedyBytes,
  File "/config/deps/lib/python3.6/site-packages/construct/__init__.py", line 22, in <module>
    from construct.core import *
  File "/config/deps/lib/python3.6/site-packages/construct/core.py", line 11, in <module>
    from construct.lib import *
  File "/config/deps/lib/python3.6/site-packages/construct/lib/__init__.py", line 3, in <module>
    from construct.lib.bitstream import RestreamedBytesIO, RebufferedBytesIO
ImportError: cannot import name 'RestreamedBytesIO'
This is my config file:
switch:
    timeout: 20
    switches:
      projector:
        command_on: Z6VLAAkCAABpAgAAYgYAAKYIAACJEQAAoSMAAKScAABYeQEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABFAQEBAQEBAQEhISEhISEhIQEBISEBAQEBISEBASEhISFhNXE1AQ
        command_off: Z6VHAPEBAACBAgAASQYAAIYIAABqEQAAySMAAECcAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABFAQEBAQEBAQEhISEhISEhIQEBASEhAQEBISEhAQEhISFhNQE
Name: not between " " ?
Nope, doesn’t make a difference. @syssi This is my error:
Log Details (ERROR)
Sun Jan 21 2018 19:23:02 GMT+0100 (W. Europe Standard Time)
    return fut.result()
config:
switch:
    switches:
      projector:
        command_on: 'Z6VLAAkCAABpAgAAYgYAAKYIAACJEQAAoSMAAKScAABYeQEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABFAQEBAQEBAQEhISEhISEhIQEBISEBAQEBISEBASEhISFhNXE1AQ'
        command_off: 'Z6VHAPEBAACBAgAASQYAAIYIAABqEQAAySMAAECcAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABFAQEBAQEBAQEhISEhISEhIQEBASEhAQEBISEhAQEhISFhNQE'
This is strange. Could you try to call “python” and input the following lines:
Does it return the same error?
Hi, how do I call python? I use hass.io 0.61.1, do I need to use hassbian instead?
In this case please wait for the next homeassistant release. The miio components are broken at 0.61.1.
Hello.
Sorry if I missed something. After the latest update the service isn’t working anymore.
Both trying to call it in the dev tools like {“packet”:“Z6blabla”}, and in the scripts.yaml, like it used to do, using this format
lg_on_off:
sequence:
- service: switch.send_command_192_168_0_152
packet:
- “Z6VHABsCAABEAgAAowYAAL8IAABkEQAAOyMAAKScAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABFEBAgEBAQEBAgIBAgICAgIBAQECAQEBAQICAgECAgICBgNQA=”
No particular messages from log. I just replaced “chuangmi” with “switch” as domain, and stopped working.
The command_on: and command_off: declared in configuration.yaml work instead as expected.
Thanks!
@syssi with the latest Home assistant release (0.62.0) I’m still having problems.
This is my error:
Log Details (ERROR)
Sun Jan 28 2018 23:49:36 GMT+0100 (W. Europe Standard Time)
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_component.py", line 189, in _async_setup_platform
    return fut.result()
Please provide the output (version numbers) of this three commands:
cat /config/deps/lib/python3.6/site-packages/construct/version.py
cat /usr/lib/python3.6/site-packages/miio/version.py
grep REQUIRE /config/custom_components/switch/chuangmi_ir.py
A clever guy was able to encode proton ir commands in a chuang mir ir command (base64 string):
The feature is part of python-miio now and will be available soon at home assistant:
Stay tuned! My custom component will be obsolete then.
@syssi
Trying to get this to work on Hass.io 0.63.1 but got this error. Installed on custom components. Any help?
  File "/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 84, in async_setup
    SLOW_SETUP_MAX_WAIT, loop=hass.loop)
    return fut.result()
  File "/usr/lib/python3.6/site-packages/miio/protocol.py", line 179, in <module>
    Const(0x2131, Int16ub),
  File "/usr/lib/python3.6/site-packages/construct/core.py", line 1894, in __init__
    super(Const, self).__init__(subcon)
  File "/usr/lib/python3.6/site-packages/construct/core.py", line 291, in __init__
    raise TypeError("subcon should be a Construct field")
TypeError: subcon should be a Construct field
@potato.xbe Please wait for HA 0.64. It will be fixed there.
After updating to 0.63.3, chuangmi_ir is back. But it controls becomes an input boolean instead of separate on and off buttons like in the previous versions. And I get the following error when executing
Error executing service <ServiceCall switch.turn_on: entity_id=['switch.daikin_ac_full']>
  File "/usr/lib/python3.6/site-packages/homeassistant/core.py", line 1010, in _event_to_service_call
    yield from service_handler.func(service_call)
  File "/usr/lib/python3.6/site-packages/homeassistant/components/switch/__init__.py", line 111, in async_handle_switch_service
    yield from switch.async_turn_on()
  File "/usr/lib/python3.6/asyncio/futures.py", line 332, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.6/asyncio/tasks.py", line 250, in _wakeup
    future.result()
  File "/config/custom_components/switch/chuangmi_ir.py", line 180, in turn_on
    if self._send_command(self._command_on):
  File "/config/custom_components/switch/chuangmi_ir.py", line 198, in _send_command
    self._device.play(command, 38400)
TypeError: play() takes 2 positional arguments but 3 were given
Can’t send packets with the IR command either
Error executing service <ServiceCall switch.send_command_192_168_0_13: packet=['Z6XTAMIBAADtAQAAdQUAAD8HAADnDgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA0ASEBIQEhASEBIQEhIQEhASEhISEBASEhAQEBASEBAQEhAQEBAQEhISEBAQEhAQEBASEBASEhAQEBAQEBAQEBAQEBASEBAQEBAQEBAQEBASEBAQEBAQEBAQEBIQEhISEhIQEBASEhASEB']>
  File "/usr/lib/python3.6/asyncio/coroutines.py", line 210, in coro
    res = func(*args, **kw)
  File "/config/custom_components/switch/chuangmi_ir.py", line 110, in _send_command
    ir_remote.play(command, 38400)
Please remove the custom_components/switch/chuangmi_ir.py and update your configuration to use the official component remote.xiaomi_miio.
Quick & dirty solution: I fixed the custom_component. https://github.com/syssi/chuangmi_ir
