You have to add trimming to your config
Sorry, Iām new to these bricks and found nothing like that in the developer tools
For me it looks like this:
access_token: xxxxx
calibration_points:
- vacuum:
x: 0
āyā: 0
map:
x: 400
āyā: 399 - vacuum:
x: 1
āyā: 0
map:
x: 420
āyā: 399 - vacuum:
x: 0
āyā: 1
map:
x: 400
āyā: 379
model: viomi.vacuum.v8
used_api: viomi
friendly_name: Xiaomi Cloud Map Extractor
entity_picture:> -
/api/camera_proxy/camera.xiaomi_cloud_map_extractor?
token = xxxx
supported_features: 1
There are no such entries as below
trim map false 0
Configure the map triming.
Each crop direction is a percentage: a value of 25 means that a quarter of the image size is cropped within that dimension. Available buttons: [left, right, up, down]
Itās not in dev tools, but in cameraās configuration in yaml. Here you have an example usage of trimming
Well, I have a request, another one for a freshman. What the notation / syntax should look like. Iām plugging it and itās still wrong.
These values should be correct for your map:
camera:
- platform: xiaomi_cloud_map_extractor
host: !secret xiaomi_vacuum_host
token: !secret xiaomi_vacuum_token
username: !secret xiaomi_cloud_username
password: !secret xiaomi_cloud_password
draw: ['all']
attributes:
- calibration_points
map_transformation:
scale: 2
trim:
top: 45
bottom: 30
left: 35
right: 35
Oh yes, itās perfect now. I will analyze your entry and see if I can handle further modifications. Thank you very much.
@gersilex Can you try running version from this branch with debug logs?
Btw, I forgot to mention that @andreasc has solved the problem by providing a correct token.
With pleasure. It yields the āempy (zero-bytes) imageā from my previous reply.
With this configuration
camera:
- name: Simple Camera
host: scruffy.nest.de
country: de
it prints these logs after a restart and those continue in the same interval:
2021-07-08 12:28:54 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration google_home which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-08 12:28:54 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration garbage_collection which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-08 12:28:54 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration presence_simulation which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-08 12:28:54 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration spotcast which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-08 12:28:54 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration browser_mod which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-08 12:28:54 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration meteoalarmeu which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-08 12:28:54 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration xiaomi_cloud_map_extractor which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-08 12:28:54 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration trakt which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-08 12:28:54 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-08 12:28:54 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-07-08 12:28:58 DEBUG (SyncWorker_3) [custom_components.xiaomi_cloud_map_extractor.camera] Logging in...
2021-07-08 12:28:58 DEBUG (SyncWorker_5) [custom_components.xiaomi_cloud_map_extractor.camera] Logging in...
2021-07-08 12:28:59 DEBUG (SyncWorker_3) [custom_components.xiaomi_cloud_map_extractor.camera] Logged in
2021-07-08 12:28:59 DEBUG (SyncWorker_3) [custom_components.xiaomi_cloud_map_extractor.camera] Retrieving device info, country: de
2021-07-08 12:28:59 DEBUG (SyncWorker_5) [custom_components.xiaomi_cloud_map_extractor.camera] Logged in
2021-07-08 12:28:59 DEBUG (SyncWorker_5) [custom_components.xiaomi_cloud_map_extractor.camera] Retrieving device info, country: de
2021-07-08 12:28:59 DEBUG (SyncWorker_3) [custom_components.xiaomi_cloud_map_extractor.camera] Retrieving map name from device
2021-07-08 12:28:59 DEBUG (SyncWorker_5) [custom_components.xiaomi_cloud_map_extractor.camera] Retrieving map name from device
2021-07-08 12:28:59 ERROR (SyncWorker_1) [spotipy.client] HTTP Error for GET to https://api.spotify.com/v1/me/ returned 401 due to The access token expired
2021-07-08 12:29:05 DEBUG (SyncWorker_3) [custom_components.xiaomi_cloud_map_extractor.camera] Map name rubyslite%2F322176735%2F16
2021-07-08 12:29:05 DEBUG (SyncWorker_3) [custom_components.xiaomi_cloud_map_extractor.camera] Unable to retrieve map, reasons: Logged in - True, map name - rubyslite%2F322176735%2F16, device retrieved - False
2021-07-08 12:29:08 DEBUG (SyncWorker_7) [custom_components.xiaomi_cloud_map_extractor.camera] Retrieving device info, country: None
2021-07-08 12:29:10 DEBUG (SyncWorker_5) [custom_components.xiaomi_cloud_map_extractor.camera] Map name rubyslite%2F322176735%2F17
2021-07-08 12:29:10 DEBUG (SyncWorker_5) [custom_components.xiaomi_cloud_map_extractor.camera] Unable to retrieve map, reasons: Logged in - True, map name - rubyslite%2F322176735%2F17, device retrieved - False
2021-07-08 12:29:21 DEBUG (SyncWorker_7) [custom_components.xiaomi_cloud_map_extractor.camera] Retrieving map name from device
2021-07-08 12:29:21 DEBUG (SyncWorker_7) [custom_components.xiaomi_cloud_map_extractor.camera] Map name rubyslite%2F322176735%2F0
2021-07-08 12:29:21 DEBUG (SyncWorker_7) [custom_components.xiaomi_cloud_map_extractor.camera] Unable to retrieve map, reasons: Logged in - True, map name - rubyslite%2F322176735%2F0, device retrieved - False
2021-07-08 12:29:21 ERROR (SyncWorker_3) [spotipy.client] HTTP Error for GET to https://api.spotify.com/v1/me/ returned 401 due to The access token expired
2021-07-08 12:29:23 DEBUG (SyncWorker_1) [custom_components.xiaomi_cloud_map_extractor.camera] Retrieving device info, country: None
Did by any chance the token format change between v1 and v2?
Nooo, it shouldnāt. I see that it fails to retrieve device information. It tries to match device by comparing token and IP address. Can you check if token extractor returns the same values as in your config?
They are identical:
As you can see I use the FQDN of the vacuum and not the IP. Could it be an issue when comparing the token and IP address?
Edit: It works when using the IP address instead of the hostname!
That should be itā¦ I think I can change approach to match only by token instead
Yes, it was the problem. Either change that or resolve the hostname upfront. But that might require unneccessary dependencies and increase complexity without bringing much benefit.
Iām having a issue with the blueprint.
Error: Error rendering service name template: UndefinedError: ādict objectā has no attribute āto_stateā
Template variable error: ādict objectā has no attribute āto_stateā when rendering ā{% if trigger.to_state.state in [āunavailableā, āunknownā, ādockedā] %} camera.turn_off {% else %} camera.turn_on {% endif %}ā
I reviewed docs and blueprint seems correct. I canāt find the issue.
Iām trying to solve a problem with rotating map in my vacuum. It causes vacuum goes in a wrong direction when zoned cleaning is used. I partly solved this problem but I think it could be done better. Actually I have two sets of coordinates, and then I choose one depending on the vacuum position.
Is it possible to make zoned cleaning resistant to mapās rotating easier by using xiaomi cloud vacuum map extractor or lovelelace xiaomi map card?
You can suggest a solution for map rotation detection and correction, I havenāt tried to do it so far
Noting that the map does not show the vacuum track as it was before. Nothing else changed.
Hello all,
please i follow all the instructions i create an entity for camera but the error i get is āfailed to retrievev map from vacuumā
I suppose that i have complete all the steps correctly as i foolowed the instructions.
Any suggestion?
thank you!
Check if there is anything suspicious in logs. You can also enable debug logging:
logger:
default: info
logs:
custom_components.xiaomi_cloud_map_extractor: debug
thanks for answer me! I will go that way when i get back and i will see.
I believe i have done everything correct. i didnāt go through HACS. hope this did not affect the installation.
But iāve seen the entity.
hello again, i checked my logs and seem that the device is not responding
The vacuum entity i have to delete it or not? now i had remove it.
I can confirm that i received normally the map! The problem was the extraction token.
Two different tokens for EU servers.
Thank you for your kind help!
