Xiaomi Cloud Vacuum Map Extractor
There is a service input_select.set_option which accepts a list.
A correct syntax with a template is:
service: input_select.set_options
  entity_id: input_select.test_input_select_templatable
  options: "{{['one','two','three','four']}}"
Calling a service for vacuum with the same format
entity_id: vacuum.xiaomi_roborock_s50
command: app_segment_clean
params: "{{['2','3','3']}}"
causes same error
Unable to send command to the vacuum: {'code': -10000, 'message': 'data for segment is not a number'}
I think that the problem is in the service itself - it accepts a number, not a string.
I tried this call:
params: "{{[2|int,3|int,3|int]}}"
it works!!!
Soooo, maybe this will work as well?
          {%- set ns.COMMAND = (ns.COMMAND)[:-1] -%}
          {{ ns.COMMAND | from_json }}
Made this, gonna test it after completion of the started cleaning:
          params: >-
            {% set ns = namespace(COMMAND = "") -%}
            {%- set ROOM_FLAGS = expand('group.vacuum_clean_rooms') -%}
            {%- for flag in ROOM_FLAGS -%}
              {%- if flag.entity_id | regex_match("input_boolean.vacuum_clean_room_", ignorecase=False) and
                    is_state(flag.entity_id,'on') -%}
                {%- set ROOM = flag.entity_id.split("vacuum_clean_room_")[1] -%}
                {%- set ROOM_NUMBER = states('input_number.vacuum_clean_room_number_' + ROOM)|int -%}
                {%- set CLEAN_COUNT = states('input_number.vacuum_clean_room_count_' + ROOM)|int -%}
                {%- set ROOM_NUMBER_STRING = (ROOM_NUMBER|string +"|int" + ",") * CLEAN_COUNT -%}
                {%- set ns.COMMAND = ns.COMMAND + ROOM_NUMBER_STRING -%}
              {%- endif -%}
            {%- endfor -%}
            [{{ ns.COMMAND }}]
Actually, I have never used from_json things, need some time for testing…
Update:
Because of unknown reasons the script above did not work - same error as before…
So I went back to the previous version with this expression:
[{{ ns.COMMAND }}]
and without this expression:
+"|int"
Code:
  vacuum_clean_rooms:
    alias: 'vacuum: Clean rooms'
    sequence:
      - service: vacuum.send_command
          params: >-
                {%- set ROOM_NUMBER_STRING = (ROOM_NUMBER|string +",") * CLEAN_COUNT -%}
              {%- endif -%}
            {%- endfor -%}
            [{{ ns.COMMAND }}]
Probably earlier I started the script before it was actually updated in HA after correction.
So to be sure I restarted HA - and the script works!
Now everything looks OK:
expanded control panel:
expanded settings with restricted access:
hey, I’m new in HA so sorry for probably stupid questions. questions are related to both Xiaomi Cloud Vacuum Map Extractor and Lovelace Xiaomi Vacuum Map card:
  1. it is nowhere said how vacuum itself should be integrated in HA (to get entity for Lovelace Xiaomi Vacuum Map card). I understand, that probably it is out of scope, but for new users it can be very helpful. tried first via Vacuum integration, but entity didn’t appear. then tried via Xiaomi Miio and finally get entity. but this integration cannot be configured via config. is it correct way?
  2. how can I clean specific rooms? example in config is based only on coordinates, not sure if it is proper way, because in MiHome I can clean specific rooms with complex shapes.
  3. how can I get room numbers? there is said in the docs add rooms/room_numbers attribute - and what next? in tons of comments I found that I should check it in dev tools. how? what should I do to see it? https://i.imgur.com/OECBfta.png why docs is so not new-user-friendly :frowning:
  4. I have HA in russian, obviously set russian language in Lovelace Xiaomi Vacuum Map card, but bottom row still has mixed texts from english and russian. is it a bug? missing translation? misconfiguration? https://i.imgur.com/XJyWlIE.png
thanks in advance.
@3_14 please advice
That is the way I have set up mine, over a year ago. As far as I know, that’s still how it’s done.
  1. Vacuum configuration depends on specific model, I am not able to cover all cases. You should use an integration that supports your model, built-in Xiaomi Miio is always a good first shot.
  2. It’s possible to do it. Discussion: link
  3. This screenshot shows attributes of the vacuum, room numbers are in attributes of a camera entity.
  4. These values are entity states/attributes, which currently are not translated. Maybe I will add possibility to translate them in future versions of the card.
@3_14 thank you, finally got what I wanted:
another question: is there any way to reset sensors/filter/main brush/side brush from the card? it is the only thing, for which I still need MiHome. I saw tap_action/hold_action/double_tap_action options in config, but better to have example.
Kind of this code (russian:Choto tipa takogo):
                  - type: custom:button-card
                    template: button_card_template__simple_button_red
                    name: Сбросить наработку щетки
                    tap_action:
                      action: call-service
                      service_data:
                        entity_id: '[[SENSOR_VACUUM]]'
                        command: reset_consumable
                        params:
                          - main_brush_work_time
                      confirmation: &ref_confirmation
                        text: |
                          Сбросить время наработки?
                          Данное действие необратимо
                    tap_action:
                      service_data:
                        params:
                          - side_brush_work_time
                      confirmation: *ref_confirmation
                    name: Сбросить наработку фильтра
                    tap_action:
                      service_data:
                        params:
                          - filter_work_time
                    name: Сбросить наработку сенсоров
                    tap_action:
                      service_data:
                        params:
                          - sensor_dirty_time
This has stopped working on the latest beta, 2021.12.0b1 error below
Entity camera.xiaomi_cloud_map_extractor (<class ‘custom_components.xiaomi_cloud_map_extractor.camera.VacuumCamera’>) implements device_state_attributes. Please report it to the custom component author
And now these warnings in 2021.12.0 release.
Why do I constantly have this:
I have 2.1.1 installed via HACS.
This error originated from a custom integration.
Logger: custom_components.xiaomi_cloud_map_extractor.camera
Source: custom_components/xiaomi_cloud_map_extractor/camera.py:333
Integration: xiaomi_cloud_map_extractor (documentation, issues)
First occurred: 09:14:27 (1 occurrences)
Last logged: 09:14:27
Unable to retrieve map data
But does it work despite this error?
I see the same errors like @sender in the error logs. On a daily base and multiple times. They happen since v.1-times already but I just ignore them because all is seemingly working despite of the error:
However, what is strange is that this error only occurs on one of my two identic S5 Max devices (same model, same firmware, same configuration, same wlan/ssid).
maybe a wifi issue?
This is in fact what I am suspecting although I have full wifi coverage throughout the whole floor.
I have done several wifi-resets before but it does not help. But as I said before: Since the vacuum doesn’t seem to loose its functionality I have learned to just ignore the error messages (although they somehow still bother me :stuck_out_tongue_winking_eye:)
There are several steps that are required for successful map download:
  1. Extractor asks vacuum for map id
  2. Vacuum uploads map to the cloud
  3. Cloud returns map id to the vacuum
  4. Vacuum returns map id to the extractor
  5. Extractor authenticates in cloud if needed
  6. Extractor downloads map data
If any of these steps fails to succeed the map will not be returned.
The error messages are only showing from time to time (multiple times daily though). The map retrieval itself seems to work:
For me the maps also shows (works) but this is one of the top-level errors all day…
Hi Tamsy,
can you share your COde?
Damn looks good :relaxed: :relaxed:
