How did you load the rooms information? is loading by default?
I may be mistaken on this but I believe the Roborock integration pulls that from the map that is saved on the vacuum. I took the time to split out each room when I created the map.
It is embedded in map data
Yes, it seems to retrieve it directly from the vacuum, without the cloud
Edit
Nevermind i did not see the card entity.
Edit
Hi Piotr
I have a strange issue. I have 2 Roborock S7 and everything works fine with the integration. The only bug i have is the Lovelace MAP, it shows me twice the same map on both robots. The Actions on the lovelace are working and go to the right Roborock but the map still doesnāt update.
Now thats a problem for the Pin and Go etc. function.
Any Ideas?
As i said, checked the config, got 2 different IPs and 2 Tokens for the robots, so everything should be configured in the config.yaml
I aswell configured Names on the Platform integration
Hi there
I have everything set up, rooms etc. works very well, thank you Piotr!
The only thing i see is, that when i send my robot to clean a room, he ignores teh x1, x2,x 3. I tested with both my robots and it always just goes and cleans it once.
Could this be a bug perhaps?
Which vacuums do you have?
I have 2 s7 roborock.
issue:
workaround:
Can anyone tell me why I am getting this error in the Log:
2023-01-29 00:44:21.058 ERROR (SyncWorker_7) [custom_components.xiaomi_cloud_map_extractor.camera] Unable to log in, check credentials
Using Roborock S5.
The map itself seems to be extracted from the vacuum.
Does the camera show the map?
Strange.
The camera has some OLD image from some previous run (a whole cleanup map).
Just started the vacuum (zone clean), first got a āunable to retrieve ā¦ā message on the camera, then ran āgo to home commandā, then got the latest cleanup map (which lasted for 1-2 minutes).
Except that āunable to retrieve ā¦ā message, everything seems to work OK.
But why I am getting that āUnable to log in, check credentialsā on HA startup? (only on startup)
I dont know what do to relly,
i have HACS and have install it all, i think.
i can see the map and start/stop robot. i have Xiaomi Miio installd as well, and i can see my house/map on it.
i have this in my cofig. ymal.
- platform: xiaomi_cloud_map_extractor
host: "myipda1"
token: "5ege53533553544a4c"
username: "mymail"
password: "onetow34sx"
country: "de"
draw: ['all']
attributes:
- calibration_points
and i have this on my card that i have added manuell,
title: Xiaomi Vacuum
preset_name: Live map
entity: vacuum.runner
map_source:
camera: camera.xiaomi_cloud_map_extractor
calibration_source:
camera: true
icons:
- icon: mdi:play
conditions:
- entity: vacuum.runner
value_not: cleaning
value_not: error
value_not: returning
tooltip: Start
tap_action:
action: call-service
service: vacuum.start
service_data:
entity_id: vacuum.runner
- icon: mdi:pause
conditions:
value_not: docked
value_not: idle
value_not: error
value_not: paused
tooltip: Pause
tap_action:
service: vacuum.pause
service_data:
- icon: mdi:stop
conditions:
value_not: docked
value_not: idle
value_not: error
value_not: paused
tooltip: Stop
tap_action:
service: vacuum.stop
service_data:
- icon: mdi:home-map-marker
conditions:
value_not: docked
tooltip: Return to base
tap_action:
service_data:
- icon: mdi:target-variant
conditions:
value_not: docked
value_not: error
value_not: cleaning
tooltip: Clean spot
tap_action:
service: vacuum.clean_spot
service_data:
- icon: mdi:map-marker
tooltip: Locate
tap_action:
service: vacuum.locate
service_data:
- icon: mdi:fan-remove
conditions:
attribute: fan_speed
value: Silent
tooltip: Change fan speed
tap_action:
service: vacuum.set_fan_speed
service_data:
fan_speed: Standard
- icon: mdi:fan-speed-1
conditions:
value: Standard
tap_action:
service_data:
fan_speed: Medium
- icon: mdi:fan-speed-2
conditions:
value: Medium
tap_action:
service_data:
fan_speed: Turbo
- icon: mdi:fan-speed-3
conditions:
value: Turbo
tap_action:
service_data:
fan_speed: Silent
- icon: mdi:fan-alert
conditions:
value_not: Silent
value_not: Standard
value_not: Medium
value_not: Turbo
tap_action:
service_data:
fan_speed: Silent
map_modes:
- template: vacuum_clean_segment
service_call_schema:
service: script.vacuum_send_command
service_data:
command: app_segment_clean
params: '[[selection]]'
entity_id: '[[entity_id]]'
- template: vacuum_clean_zone
service_data:
command: app_zoned_clean
- template: vacuum_clean_zone_predefined
service_data:
- template: vacuum_goto
service_data:
command: app_goto_target
- template: vacuum_goto_predefined
service_data:
I whant to sett up zone, and namn for livingroom, kitchne and so on. i was look at a youtube video, but it sems to been a old update. so that dident help.
Or are they any good video that will expalin it all, im pretty new to HA and this is my first thing from HACS
And allso when going to service and trying to start i wont start:/ but if i using the button on the card it will work fine.
THANKS for all the work
What vacuum do you have and which integration do you use to control it?
Thanks for the repy
xiaomi s7 roborock using auto-empty dock station, i have Xiaomi Miio installd
@Ildar_Gabdullin Maybe you have some network issues at HA startup? Itās really hard to tell without direct access to your HA
@otto1 Create a new card and start from the beginning using this guide. Use ādefaultā vacuum platform
Thanks a lot for the reply.
What I see is:
- There is a record in a Log ā Unable to log in, check credentialsā on HA startup. It presents always and occurs only on startup.
- There are integrations needed access to Internet like openweathermap; sometimes there are errors in the Log like ācannot update sensorsā - like integrations cannot get updated values in time; but mostly data are acquired.
- When I open a view with a camera for the Extractor, I usually see the map. In some (rare) cases I see a message like ācannot retrieveā on the camera.
- When the vacuum (Roborock s5) is started, a current path is displayed on the map.
- I can open my mi account in a browser using login/password.
Could you help me, what else shall I check?
Mainly, that error message in the Log does not see seem to be a serious problem since things seem to work anyway.
Hi Tobias. Thanks for your work with Valetudo on the fork. I had a look but canāt see any update in the readme, so Iām not sure if this is usable or different.
(For anyone to answer)
What Iād like to do is simply get coordinates from my Valetudo map, so I can do zoned (not segment) cleaning.
I donāt really want to install lots of things to do this.
Is it possible to refer to Valetudo directly without having to specify token, login, usernameā¦ since we can already connect to the robot directly and get map data from MQTT, no need for cloud?
Thanks.
I may be stupid, but i dot get it:( I have add
attributes:
- rooms
In my config, i open the card select default and then room config. but what to then? nothing i my code has been change, same code as before. or iam missing somthingā¦sorry for not understanding:/
And a bonus question, i want to add some services i think, i what to see a entity when its going back to the dock when the cleaning is done,
You have to click āgenerate rooms configā and not click āgenerate static configā. Have you done so?
Tiles should show current status of the vacuum, including āreturning to the docking stationā
