One more thing, vacuum map won’t work with this repo (probably), so I suggest this approach instead:
So … the map works perfectly! My problem is that I’m stuck at the first point.
The script you made me with vacuum_goto no longer goes.
I think I have to use the clean_point or spot service but I tried with the same script but from error.
wait a sec, have you changed back to KrzysztofHajdamowicz/home-assistant-vacuum-styj02ym
or use raidenlal/home-assistant-viomi-vacuum-v8
alias: Giovanni Pulizia
sequence:
- service: vacuum.clean_point
point: [-1.1199999999999974, 0.7499999999999964]
entity_id: vacuum.giovanni
mode: single
icon: hass:robot-vacuum
Giovanni Pulizia: Error executing script. Service not found for call_service at pos 1: Unable to find service vacuum.clean_point
sequence:
- service: viomi_vacuum_v8.clean_point
mode: single
Ok thanks a lot! This works.
Hello everyone,
I have a question about vacuum cleaners. I haven’t been working on it for a while, but I want to work this out a bit now.
the following code used to work:
- platform: xiaomi_cloud_map_extractor
host: !secret whipsie_host
token: !secret whipsie_token
username: !secret mihome_user
password: !secret mihome_pass
colors:
color_map_inside: [32, 115, 185]
color_map_outside: [19, 87, 148]
color_map_wall: [100, 196, 254]
color_map_wall_v2: [93, 109, 126]
color_grey_wall: [93, 109, 126]
color_ignored_obstacle: [0, 0, 0, 127]
color_ignored_obstacle_with_photo: [0, 0, 0, 127]
color_obstacle: [0, 0, 0, 127]
color_obstacle_with_photo: [0, 0, 0, 127]
color_path: [147, 194, 238]
color_goto_path: [0, 255, 0]
color_predicted_path: [255, 255, 0, 0]
color_cleaned_area: [127, 127, 127, 127]
color_zones: [0xAD, 0xD8, 0xFF, 0x8F]
color_zones_outline: [0xAD, 0xD8, 0xFF]
color_virtual_walls: [255, 0, 0]
color_new_discovered_area: [64, 64, 64]
color_no_go_zones: [255, 33, 55, 127]
color_no_go_zones_outline: [255, 0, 0]
color_no_mop_zones: [163, 130, 211, 127]
color_no_mop_zones_outline: [163, 130, 211]
color_charger: [0x66, 0xfe, 0xda, 0x7f]
color_robo: [75, 235, 149]
color_room_names: [0, 0, 0]
color_unknown: [0, 0, 0]
color_scan: [0xDF, 0xDF, 0xDF]
room_colors:
1: [240, 178, 122]
2: [133, 193, 233]
3: [217, 136, 128]
4: [52, 152, 219]
5: [205, 97, 85]
6: [243, 156, 18]
7: [88, 214, 141]
8: [245, 176, 65]
9: [252, 212, 81]
10: [72, 201, 176]
11: [84, 153, 199]
12: [133, 193, 233]
13: [245, 176, 65]
14: [82, 190, 128]
15: [72, 201, 176]
16: [165, 105, 18]
draw:
- charger
- cleaned_area
- goto_path
- ignored_obstacles
- ignored_obstacles_with_photo
- no_go_zones
- no_mopping_zones
- obstacles
- obstacles_with_photo
- path
- predicted_path
- room_names
- vacuum_position
- virtual_walls
- zones
texts:
- text: "Room 1"
x: 25
y: 25
color: [125, 20, 213]
- text: "Room 2"
x: 25
y: 75
color: [125, 20, 213, 127]
font: "FreeSans.ttf"
font_size: 25
map_transformation:
scale: 1
rotate: 0
trim:
top: 35
bottom: 33
left: 23
right: 25
sizes:
charger_radius: 4
vacuum_radius: 4.5
obstacle_radius: 3
ignored_obstacle_radius: 3
obstacle_with_photo_radius: 3
ignored_obstacle_with_photo_radius: 3
attributes:
- calibration_points
- charger
- cleaned_rooms
- country
- goto
- goto_path
- goto_predicted_path
- image
- is_empty
- map_name
- no_go_areas
- no_mopping_areas
- obstacles
- ignored_obstacles
- path
- room_numbers
- rooms
- vacuum_position
- vacuum_room
- vacuum_room_name
- walls
- zones
scan_interval:
seconds: 10
auto_update: true
store_map_raw: false
store_map_image: true
store_map_path: "/tmp"
force_api: xiaomi
but now suddenly not anymore and I get the error message:’ invalid calibration, plaese check your configuration’. However, if I remove this part:
texts:
- text: "Room 1"
x: 25
y: 25
- text: "Room 2"
x: 25
y: 75
font_size: 25
then it will work.
My problem is how can I name my rooms then?
thanks for every response.
It’s a compatibility issue with HA 2023.8+. I will publish a fix later today/tomorrow
Thanks, it’s working again.
Hello, with Xiaomi miio my Roborock S7 wasn’t working properly, but now there is an integration of Roborock. At the time of adding to the lovelace, I can’t get the map working, my vacuum entity is selected but nothing happens, is it possible to obtain the map ussing the Roborock integration? Thanks
Why does my map look so blocky vs other people are posting, what I am I doing wrong?
camera:
host: XXX.XXX.XXX.XXX
token: XXXXXXXXXXXXXXXXX
username: XXXXXXXXXXXXXXX
password: XXXXXXXXXXXXXXX
draw: ['all']
attributes:
map_transformation:
scale: 1
rotate: 0
trim:
top: 25
bottom: 32
left: 32
right: 28 ```
scale: 2
should make it a bit nicer
You do nothing wrong, the bigger the map the nicer I looks - your map seems to be one a smaller side
hi to ev.
i’m trying to let this work but it still says “inactive”
and when i click on it it says that “it doesn’t have an unique id”
what i’m supposed to do? ndr: xiaomi robot vacuum s12
this is my configuration in configuration.yaml (and nothing more at all, did i miss something?)
camera:
host: xxx.xxx.xxx.xxx
token: 32 digitsxxxxxxxxx
username: [email protected]
password: xxxxxxxx
draw: ['all']
attributes:
- charger
- cleaned_rooms
- country
- goto
- goto_path
- image
- is_empty
- map_name
- no_go_areas
- no_mopping_areas
- obstacles
- ignored_obstacles
- path
- room_numbers
- rooms
- vacuum_position
- vacuum_room
- vacuum_room_name
- walls
- zones
scan_interval:
seconds: 10
auto_update: true
Does the camera entity has any image?
“inactive” is ok, it’s a standard state. Missing unique id doesn’t affect functionality of the integration. Try enclosing the token in double quotes and use following config:
camera:
token: "32 digitsxxxxxxxxx"
password: xxxxxxxx
draw: ['all']
attributes:
- rooms
