Xiaomi Cloud Vacuum Map Extractor
Thank you @3_14, I’ll remove it soon.
I’m configuring the cards and when a end the configuration I’ll remove the needless attributes.
Hi I have a Viomi S9 robot vacuum cleaner.
When I choose a room to clean, I receive this message " Entity vaccum.viomi_v18_e360_robot_cleaner does not support this service"
and “Service xiaomi_miio.vaccum_clean_zone not found” when i choose zone cleanup.
Which integration have you used to add this vacuum to HA?
xiaomi miot auto
Only this one supports it.
If you use Xiaomi Miot Auto you have to configure everything manually based on Miot spec. You might try to use/adjust this one
Hello, and thank you for the card. I have already configured it and would like to integrate it into my existing Picture Element Card based on my floor plan. Unfortunately, the Image-Card does not update automatically when I start the vacuum cleaner. I would like everything to be transparent so that only the vacuum cleaner and its path are visible.
I have now used the image card, but unfortunately, it doesn’t update. When I start the vacuum, I see movement once, but then nothing happens anymore, even when I refresh the browser.
  - type: image
    entity: camera.xiaomi_cloud_map_extractor
    camera_image: camera.xiaomi_cloud_map_extractor
    camera_view: live
    style:
      top: 10%
      left: 10%
      width: 100%
      height: 100%
      transform: scale(1.0)
camera:
  - platform: xiaomi_cloud_map_extractor
    host:
    token:
    username:
    password:
    country: "de"
    attributes:
      - calibration_points
      - rooms
      - room_numbers
    store_map_path: "/tmp"
    colors:
      color_map_outside: [0, 0, 0, 0]
      color_map_wall: [0, 0, 0, 0]
      color_map_wall_v2: [34, 35, 36]
      color_path: [255, 255, 255]
      color_charger: [8, 120, 36]
      color_robo: [255, 255, 255]
      color_scan: [0, 0, 0, 0]
      color_unknown: [0, 0, 0, 0]
      color_obstacle: [0, 0, 0, 0]
      color_grey_wall: [0, 0, 0, 0]
      color_ignored_obstacle: [0, 0, 0, 0]
      color_zones: [109, 37, 37]
      color_zones_outline: [0, 0, 0, 0]
      color_virtual_walls: [109, 37, 37]
      color_no_go_zones: [109, 37, 37]
      color_no_go_zones_outline: [0, 0, 0, 0]
      color_no_mop_zones: [109, 37, 37]
      color_no_mop_zones_outline: [0, 0, 0, 0]
      color_robo_outline: [255, 255, 255, 0]
    room_colors:
      1: [255, 255, 255, 1]
      2: [255, 255, 255, 1]
      3: [255, 255, 255, 1]
      4: [255, 255, 255, 1]
    draw:
      - charger
      - path
      - goto_path
      - predicted_path
      - no_go_zones
      - no_mopping_zones
      - vacuum_position
      - virtual_walls
      - zones
    map_transformation:
      scale: 1
      rotate: 180
    scan_interval:
      seconds: 10
    auto_update: true
Which vacuum do you have? Do you use this blueprint?
Room selection and cleaning are now working, but unfortunately, I can’t get zone cleaning to start in any way. Thank you very much for your help. Best regards!
I have the Dreame L10s Ultra. No, I didn’t use the blueprint.
You can use this integration instead:
I’m going to buy that vacuum cleaner. Does it integrate well with home assistant?
Hi
Xiaomi Mop 2 Pro (ijai.vacuum.v3) support pls? :face_holding_back_tears:
I just got a X20 Xiaomi vacuum thats saying its not supported . haas-miot integration works and i can connect it to HA . Any suggestions?
These are the error logs:
2024-07-13 14:21:35.196 WARNING (ImportExecutor_0) [homeassistant.components.camera] SUPPORT_ON_OFF was used from xiaomi_cloud_map_extractor, this is a deprecated constant which will be removed in HA Core 2025.1. Use CameraEntityFeature.ON_OFF instead, please report it to the author of the 'xiaomi_cloud_map_extractor' custom integration
2024-07-13 14:21:35.205 WARNING (ImportExecutor_0) [homeassistant.components.camera] SUPPORT_ON_OFF was used from xiaomi_cloud_map_extractor, this is a deprecated constant which will be removed in HA Core 2025.1. Use CameraEntityFeature.ON_OFF instead, please report it to the author of the 'xiaomi_cloud_map_extractor' custom integration
This is in my .yaml file
camera:
    host: 192.168.xxx
    token: 697574624f5xxx933566c32455731
    username: yadayada
    password: blahblah
    draw: ['all']
    attributes:
Hi, I don’t understand if the vacuum cleaner is running, the map is visible, but after some time it becomes inaccessible. What is wrong ? Vacuum Xiaomi S5
camera:
    host: 192.168.3.151
    token: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    username: xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    password: xxxxxxxxxx
    country: cn
    draw: ["all"]
    map_transformation:
      scale: 1
      rotate: 180
      trim:
        top: 10
        bottom: 20
        left: 30
        right: 40
    auto_update: false
    store_map_raw: true
    attributes:
That is an issue with blocked Xiaomi cloud connection :frowning: I have been working on workaround in Map Extractor, I have to finally finish it
Hi @3_14, any news about workaround to blocked connection?
I’m really looking forward to using it, since I can’t use this version at all.
Hi - just a headsup, that in core 2025.1 this integration might not work anymore:
SUPPORT_ON_OFF was used from xiaomi_cloud_map_extractor, this is a deprecated constant which will be removed in HA Core 2025.1. Use CameraEntityFeature.ON_OFF instead, please report it to the author of the ‘xiaomi_cloud_map_extractor’ custom integration
Could you update it Piotr?
The issue is already reported, but the fix has not been developed.
Greetings,
I use Xiaomi Mi Mop 2c (dreame.vacuum.md1808), when I check the supported devices, dreame.vacuum.mc1808 (Mi Mop) is available. I tried to use it for my device but I could not pull the map to HA. Will there be support for Mop 2 or can I get the map with the current version?
Note: I can see and use the map in mi home app.
