Xiaomi Eve Plus Integration
Hello guys.
I learned how to make scripts for cleaning zones by Roidmi EVE Plus.
Look to my example:
clean_living_room:
  alias: clean_living_room
  sequence:
    - service: xiaomi_miot.call_action
        entity_id: vacuum.roidmi_eve_robot_cleaner
        did: 441963123
        siid: 14
        aiid: 1
        params: [2,"{\"mapId\":1627839123,\"segmentId\":[3]}"]
  mode: single
  icon: mdi:sofa
Little how-to:
  1. Use Xiaomi Miot For HomeAssistant integration. Install it by manual. If it ask type of commands - select CLOUD connect.
  2. Use vevs mod of Mi home for collect needed data. Install mod and create folders for logs: /vevs/logs/. After make folder - login to you acc. If you already logined - make relogin, for creating logs.
  3. Go to you Roidmi EVE page and start segment cleaning.
  4. Find in /vevs/logs/miio/ folder txt file with DID of you device. (in my case 441963123.txt)
  5. Send log file to PC and find word ‘segmentId’ - this line will start segment cleaning. In my case line it is: 2021-08-02 20:48:12 → {“params”:{“did”:“441963123”,“siid”:14,“aiid”:1,“in”:[2,"{“mapId”:1627839123,“segmentId”:[3]}"]}} /miotspec/action
  6. Just use data after “in”: this line in you scripts for params line. In my case it params: [2,"{“mapId”:1627839123,“segmentId”:[3]}"]
  7. (additional) You also can use Xiaomi Cloud Map Extractor
    This is my config for it:
  - platform: xiaomi_cloud_map_extractor
    host: 192.168.1.***
    token: 454f4********************9764b58
    username: s******@gmail.com
    password: ***********
    draw: ['all']
    store_map_raw: true
    force_api: roidmi
    attributes:
      - calibration_points
All needed data you can find in vevs mod - just tap and hold you device in start page, and choose reneame button - after you see window with all info about it, inc. token.
Thanks It works
Thanks for the instruction. Everything works. Are you using the “Lovelace Xiaomi Vacuum Map Card”? I can’t send it from the card
Hi, i use Button Card
There is a sample of button:
type: custom:button-card
entity: script.clean_living_room
tap_action:
  action: call-service
  service: script.clean_living_room
state:
  - value: 'off'
  - value: 'on'
    color_type: icon
    color: red
    styles:
      state:
        - color: red
      card:
        - filter: brightness(60%)
styles:
  card:
    - height: 50px
color_type: icon
color: rgb(170, 176, 188)
icon: mdi:sofa
show_name: false
There is a preview of full block of buttons:
chrome_2021-08-24_17-27-22
Thanks. The scrips are working perfect with one or more rooms
alias: Aspiradora Limpieza Zona SalaCocina
sequence:
  - service: xiaomi_miot_raw.call_action
      aiid: 1
      entity_id: vacuum.aspiradora
      siid: 14
      inn:
        - 2
        - '{"mapId":1617187917,"segmentId":[1,8,3,10]}'
mode: single
The quality of the map of the map extractor is low but it also works!
Screenshot_20210829-092919_Home Assistant|225x500
Thank you! It works !
First time poster here, but I’ve been watching this thread ever since it started.
I’ve added the map through the map extractor but wasn’t able yet to control the device itself. I had it added through the MIoT integration but that didn’t work and was planning to get into adding it through the ways mentioned above to get the functionality going at least.
To my surprise it might actually be working through MIoT now, full functionality as well, return to dock, fan speed, start and stop. Even switching between mop/sweeping functions
Hasn’t gone offline for the past 24 hours either. Might be to soon to celebrate, but worth creating an account for to update you guys to see if it works for you too, might have been the last update or something
Has someone managed to control the amount of water in mop mode?
There is a nice intergration.
It has some minor mistakes but can be corrected easily.
Hallo, I have install vevs version of Mi home and I see device on home. But when I click to Roidmi eve device the app try downloading plug-in and then error “Couldn’t find plug-in”. And on this page “https://mi.vevs.me/mihome/pluglist/” I can’t find it to. Can you help me please, what I did wrong? Or can you give me a plug-in please? Thank you.
I use the version “MiHome_6.7.700_64211_vevs”, you can get it and the plugin here → temporarily posted
Thank you very much!! :+1:
Has anyone got a “pause” command somehow for the Roidme Eve Plus ?
I do have “start”, “stop”,“back to charge” but I can not get a “pause” command.
Every card that I tried has a pause that basically stops and does not continue from there, it just starts over again.
Hey,
Just a quick question, does the android phone have to be rooted to get the MapID as that’s the only bit of information I am stuck on at the moment, unless there is another way to get it.
Thanks :slightly_smiling_face:
