Hey just a question before I dive in. Has anyone gotten the integration of Xiaomi Smart Home suite (Aqara switches, door sensors etc), Yeelights and Amazon Echo dialed in successfully with HA?
Reason why i’m asking is I noticed to enable Alexa skills for the Yeelight, one needs the set the yeelight locality to international servers (Singapore is the most commonly suggested). This guide requires the Xiaomi Smart home gateway to be under China Mainland locality and from what I gather you can’t have 2 different servers for proper integration?
I’d like to be able to control my Yeelights (ceiling, bulbs etc) as well as some dumb lights/fans (via aqara switches) via the Echo, while maintaining some automation (xiaomi sensors etc), through HA. Any advice?
I think Echo has a direct integration with Yeelights now via the app (correct me if i’m wrong)? I know the regular RGB and white Yeelights work via emulated_hue, not so sure about the ceiling one (https://www.yeelight.com/en_US/product/luna).
Excuse my question but I have checked current supported devices on https://github.com/lazcad/homeassistant and there’s no word about the Yeelight or Yeelight RGB… does it means it’s not supported? and if not… is something coming up or it’s not possible to do for now? thanks a lot!
Hello guys, I am noob and trying to setup xiaomi gateway with home assistant. But still stuck with following error. May I ask for some help?
e[31m2017-05-20 01:05:20 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback _ProactorReadPipeTransport._loop_reading(<_OverlappedF…op_reading()]>)e[0m
File “c:\users\yao_s\appdata\local\programs\python\python36\lib\asyncio\events.py”, line 127, in _run
self._callback(*self._args)
File “c:\users\yao_s\appdata\local\programs\python\python36\lib\asyncio\proactor_events.py”, line 190, in _loop_reading
data = fut.result() # deliver data later in “finally” clause
asyncio.base_futures.InvalidStateError: Result is not ready.e[0m
e[32m2017-05-20 01:05:20 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sensor.yr_symbol, old_state=<state sensor.yr_symbol=unknown; attribution=Weather forecast from yr.no, delivered by the Norwegian Meteorological Institute and the NRK., friendly_name=yr Symbol, entity_picture=//api.met.no/weatherapi/weathericon/1.1/?symbol=None;content_type=image/png @ 2017-05-20T01:05:18.989328+08:00>, new_state=<state sensor.yr_symbol=2; attribution=Weather forecast from yr.no, delivered by the Norwegian Meteorological Institute and the NRK., friendly_name=yr Symbol, entity_picture=//api.met.no/weatherapi/weathericon/1.1/?symbol=2;content_type=image/png @ 2017-05-20T01:05:20.344104+08:00>>e[0m
e[32m2017-05-20 01:05:20 INFO (MainThread) [homeassistant.core] Bus:Handling <Event component_loaded[L]: component=sensor>e[0m
e[32m2017-05-20 01:05:23 INFO (<concurrent.futures.thread.ThreadPoolExecutor object at 0x00000250A0BE4D68>_3) [custom_components.xiaomi] Gateway finding finished in 5 secondse[0m
e[32m2017-05-20 01:05:23 INFO (<concurrent.futures.thread.ThreadPoolExecutor object at 0x00000250A0BE4D68>_3) [custom_components.xiaomi] Creating Multicast Sockete[0m
e[31m2017-05-20 01:05:23 ERROR (MainThread) [homeassistant.setup] Error during setup of component xiaomie[0m
File “c:\users\yao_s\appdata\local\programs\python\python36\lib\site-packages\homeassistant\setup.py”, line 188, in _async_setup_component
None, component.setup, hass, processed_config)
File “c:\users\yao_s\appdata\local\programs\python\python36\lib\concurrent\futures\thread.py”, line 55, in run
File “C:\Users\yao_s\AppData\Roaming.homeassistant\custom_components\xiaomi.py”, line 85, in setup
PY_XIAOMI_GATEWAY.listen()
File “C:\Users\yao_s\AppData\Roaming.homeassistant\custom_components\xiaomi.py”, line 195, in listen
self._mcastsocket = self._create_mcast_socket()
File “C:\Users\yao_s\AppData\Roaming.homeassistant\custom_components\xiaomi.py”, line 185, in _create_mcast_socket
sock.bind((self.MULTICAST_ADDRESS, self.MULTICAST_PORT))
OSError: [WinError 10049] The requested address is not valid in its contexte[0m
e[32m2017-05-20 01:05:23 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=persistent_notification, service=create, service_data=title=Invalid config, message=The following components and platforms could not be set up:
xiaomi
Please check your config, notification_id=invalid_config, service_call_id=2545319663432-1>e[0m
e[32m2017-05-20 01:05:23 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=persistent_notification.invalid_config, old_state=None, new_state=<state persistent_notification.invalid_config=The following components and platforms could not be set up:
xiaomi
Please check your config; title=Invalid config @ 2017-05-20T01:05:23.756386+08:00>>e[0m
e[32m2017-05-20 01:05:23 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=2545319663432-1>e[0m
e[32m2017-05-20 01:05:23 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 6.00se[0m
e[32m2017-05-20 01:05:23 INFO (MainThread) [homeassistant.core] Starting Home Assistant core loope[0m
e[32m2017-05-20 01:05:23 INFO (MainThread) [homeassistant.core] Starting Home Assistante[0m
e[32m2017-05-20 01:05:23 INFO (MainThread) [homeassistant.core] Bus:Handling <Event homeassistant_start[L]>e[0m
e[32m2017-05-20 01:05:23 INFO (MainThread) [homeassistant.core] Timer:startinge[0m
e[32m2017-05-20 01:05:25 INFO (MainThread) [homeassistant.components.http] Serving /api/websocket to 192.168.31.227 (auth: True)e[0m
e[32m2017-05-20 01:05:25 INFO (MainThread) [homeassistant.components.http] Serving /api/websocket to 127.0.0.1 (auth: True)e[0m
e[32m2017-05-20 01:05:29 INFO (MainThread) [homeassistant.components.http] Serving /api/websocket to 127.0.0.1 (auth: True)e[0m
e[32m2017-05-20 01:05:30 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sun.sun, old_state=<state sun.sun=below_horizon; next_dawn=2017-05-19T20:23:35+00:00, next_dusk=2017-05-20T11:58:26+00:00, next_midnight=2017-05-20T16:11:06+00:00, next_noon=2017-05-20T04:11:00+00:00, next_rising=2017-05-19T20:54:43+00:00, next_setting=2017-05-20T11:27:18+00:00, elevation=0, azimuth=0, friendly_name=Sun @ 2017-05-20T01:05:18.660660+08:00>, new_state=<state sun.sun=below_horizon; next_dawn=2017-05-19T20:23:35+00:00, next_dusk=2017-05-20T11:58:26+00:00, next_midnight=2017-05-20T16:11:06+00:00, next_noon=2017-05-20T04:11:00+00:00, next_rising=2017-05-19T20:54:43+00:00, next_setting=2017-05-20T11:27:18+00:00, elevation=-28.67, azimuth=14.61, friendly_name=Sun @ 2017-05-20T01:05:18.660660+08:00>>e[0m
e[31m2017-05-20 01:05:36 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback _ProactorReadPipeTransport._loop_reading(<_OverlappedF…ed result=b’’>)e[0m
File “c:\users\yao_s\appdata\local\programs\python\python36\lib\asyncio\proactor_events.py”, line 188, in _loop_reading
self._closing)
AssertionErrore[0m
Considering that there haven’t been any updates lately to any of the branches - might be time to put it into the main HA tree? It’s a pity that such a great component still doesn’t get enough credit
I have updated my gateway to latest firmware but last night my two motion sensors had ghost issues again. So it seems that ghost issues aren’t fixed in firmware yet.
In the end I’ve used only the trigger and it’s reliable to me, now I want to achieve something more complex:
shutdown the fan after the value gets under 50 or after an hour, BUT ONLY if has been started by the previous automation (trigger when value is above 70)
It’s possible?
I can write the inverted trigger: platform: numeric_state entity_id: sensor.your.xiaomi.bathroom.entity.id below: your_value
but don’t know how to check if it has been turned on from an automation and not, for example a wireless switch
1st link is for just the gateway. If it says it has radio (which this did) then you’re good.
The 2nd link is for a kit inc the v2 gateway. and this is featuring the very latest (as in from last month or so) 2nd generation sensor designs. Not sure if anyone on this thread has reported on whether these work the same or not.
My guess is basically cosmetic change - especially now we can see they sell a kit with what looks to be same gateway.
3rd link is also v2 gateway based on the description but comes with 1st gen design sensors
all three you linked are the same. the v2 is the gateway with the “shield” icon instead of MI.
All versions beyond that I haven’t seen being sold for awhile already, only that and the Aqara which has a different design and functions
I got my starter kit a few days ago from Gearbest and I was pretty much in the same spot as you
I received the new version and the integration with HA was very easy. As long as you can see the new logo () you should be ok.
I’m buying a few more sensors now and found apparently Xiaomi is adding all the home automation line to the aqara line and made some changes in the design language but I’m betting they should be pretty much the same. I’ll let you know when I get the new ones.
