Hello everyone, sorry to bring up an old topic but I can’t seem to get my Roborock S50 back running in HASSIO.
I think it started after I used DHCP addon on HASSIO (since my router only allows 10 ip reservations). Since then I updated HASSIO to the lastest version.
I noticed my vacuum didn’t work anymore in HASS, since it wouldn’t respond to the commands given to Google home anymore.
I’ve did several resets, a wifi reset, factory reset and every time took the token from the device with MiToolkit 1.6. Using SSH HASSIO can ping the roborock, but in the logs it still states “Got exception while fetching the state: Unable to discover the device 192.168.1.249”
Any luck? I just upgraded to 0.94.4 and now getting Unavailable constantly. I am running 3.3.9_001768 as well but didnt have any issues until updating HA
Got it to work. I’m still not sure what was wrong in my settings, but when I reset my Pi’s connection and requested a new ip from the router (switching dhcp server shortly) it worked.
Just modified the connection in ssh to make it static and it works again. So it had something to do with the connection setup on the Pi…
2021-01-15 19:16:20 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:16:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:17:00 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:17:20 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:17:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:18:00 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:18:20 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:18:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:19:00 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:19:20 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:19:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:20:00 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:20:20 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:20:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:21:00 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:21:20 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:21:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:22:00 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:22:20 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:22:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:23:00 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:23:20 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:23:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:24:00 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:24:20 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:24:40 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
2021-01-15 19:25:00 WARNING (MainThread) [homeassistant.helpers.entity] Update of vacuum.xiaomi_vacuum_cleaner is taking over 10 seconds
My IP address changed and even though I changed it in the config, it was still showing as unavailable. To resolve this, I deleted the current integration under config/integrations, and rebooted. Fixed.
Hey, my roborock is changing IP quite often (after reboot and also when there is wifi problem) and I have to change in HA and do a lot of things (such as deleteing the integration as mentioned in #16) any way how to set up roborock to use static IP to avoid this?
A bit late but login to your router and set it’s DHCP-server to bind the Roborock MAC-address to a fixed IP-address that is outside of the dynamic assigned IP-range
