hass.io 0.62.0
i can’t figure out why some people have this problem and other not…
i had the problem as well on hass.io and downgraded again. i am pretty sure its for every hass.io 0.62 user!
sorry for th noob queestion, how can i downgrade? thre is a command?
the prroblem will be solved in the next update. https://home-assistant.io/blog/2018/01/27/release-62/#release-0621---january-30
you can downgrade after installing SSH addon and then with this command:
curl -d ‘{“version”: “0.61.0”}’ http://hassio/homeassistant/update
I dont think it is fixed in 0.62.1 as I dont see anything about it in the changelog. But there is an open github-issue (Miio platform broken after upgrade 0.62 (hass.io) · Issue #12017 · home-assistant/core · GitHub) on the topic…
You can find it in “all changes”
The change under ‘all changes’ is the update that broke everything in the first place, so it would need to be fixed in 0.62.1, 0.62.2 etc.
the curl command does not works on hassio
he says: curl: (3) [globbing] unmatched close brace/bracket in column 13
Yep. Also affects the WiFi switches. I’ll just wait it out till it’s fixed. I don’t have 0.62.1 yet anyway and I’m not going back to 0.61.1 just for this. I can wait.
Its specifically for hass.io try typing it into the window instead of copy paste. I think the ’ / " get messed up by the codeeditor in this forum (sorry should have said so before)
Got the same problem.
Yesterday it worked on the previous version.
Now running hassio 0.62 and the component is gone.
0.62.1 the component is still broken, need to wait for the next release or downgade.
can confirm, still not working on 0.62.1
Same problem here since 62.0. As well with 62.1
Please dear all. If there are bug fixers in 0.x releases please read release information instead of asking if things are fixed. it is all written in the release notes
still happening for me in 63 :((
it will be fixed in 0.64 the dev reported yesterday
oh great, thank you !!
