I’m setting up PresenceLight with Home Assistant for Teams status.
I’ve followed his guide, it errors out right away. I’ve tweaked the code to the below, but still receiving “Message malformed: Unable to determine action @ data[‘action’][0]” error.
alias: Teams presence - IKEA Light Bulb Living Room
- platform: webhook
allowed_methods:
- POST
local_only: false
webhook_id: "secret!"
- choose:
- conditions:
- condition: template
value_template: "{{ trigger.json.presence_status == 'Busy' }}"
- service: light.turn_on
entity_id: light.hue_color_downlight_1
color_name: red
- conditions:
value_template: "{{ trigger.json.presence_status == 'Available' }}"
color_name: green
- conditions:
value_template: "{{ trigger.json.presence_status == 'Away' }}"
color_name: yellow
default:
color_name: white
123
(Taras)
April 3, 2024, 5:57pm
4
- platform: webhook
allowed_methods:
- POST
local_only: false
- variables:
colors:
Busy: red
Available: green
Away: yellow
color_name: "{{ colors.get(trigger.json.presence_status, 'white') }}"
I still receive the same error from your edited code above.
If it helps, here is the original code. This original give an error on the “ ” condition.
description: >-
Show the Microsoft Teams status via a color of the Light Bulb in the Living
Room
- platform: webhook
allowed_methods:
- POST
local_only: true
webhook_id: "<enter secret webhook id here>"
condition: []
- choose:
- conditions:
metadata: {}
color_name: red
entity_id: light.ikea_bulb
- conditions:
metadata: {}
color_name: green
- conditions:
metadata: {}
color_name: yellow
- conditions: null
- service: light.turn_off
metadata: {}
data: {}
123
(Taras)
April 4, 2024, 7:59pm
6
When do you get the error message?
When you attempt to save the automation in the Automation Editor.
When the automation is triggered by a received Webhook.
If it’s #2 then post an example of the JSON message contained by the Webhook.
Unfortunately, it’s when trying to save.
123
(Taras)
April 4, 2024, 9:24pm
8
I’m using Home Assistant version 2024.3.1 and don’t get any errors when saving the example I posted above.
What is the version number of your Home Assistant?
It saves correctly now. I discovered the issue was my own stupidity.
I was not in YAML mode for the whole automation, only the action.
My next step since it’s saved, is to test the automation.
Thank you @123 , you were extremely helpful!
123
(Taras)
April 5, 2024, 2:25am
11
In that case, I suggest you try the example I posted. It achieves the same result with far less code.
