The config looks right. Did you follow these instruction for initial setup?
After that, you should be able to add the yeelights to your lovelace dashboard.
yes, of course. without enabled LAN control the Windows UWP app would not work either.
one thing that may be relevant is that I am running HA in docker in macvlan mode, so two other possible causes came on my mind:
For an installation of Home Assistant Supervised, which includes Home Assistant’s add-on ecosystem, see the instructions for installing Home Assistant Supervised on a generic Linux host.
