YI Dome Camera
I see.
I tried on ffmpeg_arguments: ‘-pred 1 -vf scale=800:450’ as well.
Reading of the video content speed is still slow, but yes, the video resolution is good enough for my mobile viewing.
I will still monitor and see how it goes. Thanks for the headsup
In case you hadn’t noticed …
There is a way to integrate camera commands in HA?
I wish to integrate it with AlarmSystem so I will activate its recording function only when system alarm is armed. Can anyone help me?
Yeap - got that. Think I will just stick to 0.1.4beta-2 first. It looks good on my end so far.
Hi, is it normal for the video image to have a delay greater than 1 minute of difference with reality? how much is normal? How can I change this parameter? Thanks very much!
I remember someone mentioned this before - this is mainly based on ffmpeg reading from the file saved under the sd card. imagining real-time playback of ‘recorded’ files. my guess is there’s no way to change the parameters of how ‘soon’ you can retrieve the file for playback.
The rest can correct me if I am wrong.
It is a good quality sd card, 32 GB. Is better 16 GB to correct this lag?
@Ren_Kang hey bro, you mentioned you have a V380s camera configured in HA, can u help me out im also trying to do the same and completely new to this, can you tell me how to include it in the yaml file?
@JARVIS hey bro, did you fix your problem with your V380S ?
@Ren_Kang replied your question ?
Can you please share your yaml config because I haven’t enough hair to tear out :confused:
thanks
Nope, no one replied, I never configured any camera in HA
thank you. I’ll post if I find a solution
