I’m interested in your automation to: “Dim the lights when I’m watching a show on my TV through Netflix/Plex/Chromecast”. How did you achieve the Netflix part? What event are you using as your trigger?
I only watch Netflix on the Chromecast, sorry for the confusion.
My scripts only monitor if the Chromecast is playing anything and then dims the light. I have no direct hook into Netflix itself.
Maybe you could make something like that though, possibly by monitoring traffic to Netflix domains on a router/PI etc.
I have a Hot water cupboard Its has a heater Bar in it now as i put Instant Gas Hot water.
it has door Sensor
If the door is open turn off the bar heater until it is closed again ONLY if the Heater was on before it was open.
next to automate the hall lights then add more brains to it. If I open The cupboard and its nite time turn on hall Lights until the cupboard door is closed but only if the Light was off before it was opened.
@myle - sure!! First of all - I’ll give credit where credit is due - I had to start a thread where I was having to determine the type of content playing - as I didn’t want the lights to dim when playing ‘tv’ content vs ‘movies’ - so credit to @Zen for the help!! - Thread is here - KODI - Content Type - Movie vs Tv Show - Library
I had the whole solution in that thread - so I’m copying/pasting from there - it’s all still working perfectly!!
Just so everyone has the solution -
bash script:
#! /bin/bash
curl -s -H 'Content-Type: application/json' -d '{"jsonrpc": "2.0", "method": "Player.GetItem", "params": { "playerid": 1}, "id": "VideoGetItem"}' http://<<<IP ADDRESS OF KODI>>>/jsonrpc | if [[ $(grep -o movie) ]]; then echo "ON"; else echo "OFF"; fi
Sensor:
- platform: command_line
scan_interval: 10
command: "/usr/bin/mediachecker.sh"
payload_on: "ON"
payload_off: “OFF”
Automation:
- alias: "KODI Movie Stopped"
- platform: state
entity_id: sensor.movie_time
condition:
- condition: state
entity_id: sun.sun
state: below_horizon
service: scene.turn_on
entity_id: scene.Kodi_Stopped
- alias: "KODI Movie Playing"
- platform: state
to: 'ON'
condition:
- condition: state
entity_id: sun.sun
entity_id: scene.Kodi_Playing
Scene:
scene:
- name: Kodi_Playing
entities:
light.linear_lb60z1_dimmable_led_light_bulb_level_3_0:
state: on
brightness: 25
switch.ge_unknown_type5052_id3031_switch_2_0: off
- name: Kodi_Stopped
entities:
state: on
brightness: 255
switch.ge_unknown_type5052_id3031_switch_2_0: on
Set the heating to come on if we are home in the morning (working from home) and its cold outside
Set the heating back to its normal schedule at 5pm
Set the heating back to its normal schedule if we leave the house during the day
I want to add a fourth using proximity but haven’t quite got there. Annoyingly have to use IFTTT to do the heating control because the home-assistant component is not fit for purpose (Honeywell Evohome).
- alias: Someone Home in the morning so lets set the heating on via IFTTT
platform: time
at: "08:30:00"
condition:
condition: and
conditions:
- condition: numeric_state
entity_id: sensor.dark_sky_apparent_temperature
below: 16.0
- condition: state
entity_id: group.all_devices
state: home
- service: homeassistant.turn_on
entity_id: input_boolean.heating
- service: ifttt.trigger
data: {"event":"Heating_On"}
- service: notify.ios_paul
data_template:
title: "Heating On"
message: "Its morning, cold and people are home. Lets give them heat"
- service: script.turn_on
entity_id: script.tts_to_windows
data_template:
variables:
payload: 'Its 8 30 and people are home so Im going to put the heating on for you'
- alias: Reset Heating at 5
platform: time
at: "17:00:00"
condition:
condition: and
conditions:
- condition: state
state: 'on'
- condition: state
state: home
# Automation enabled
- condition: state
entity_id: input_boolean.automation_override
state: 'off'
data: {"event":"Heating_Off"}
data_template:
title: "Heating Reset"
message: "Clocking off time lets reset the heating to its normal schedule!"
data_template:
variables:
payload: 'Its 5 o clock so setting the heating back to its normal schedule'
- service: homeassistant.turn_off
- alias: Left for the day - reset heating
platform: state
to: 'not_home'
condition:
condition: and
conditions:
- condition: state
state: 'on'
- condition: state
state: 'off'
data_template:
title: "Away - Heating Rest"
message: "Everyone has left so lets reset the heating to its normal schedule!"
@Bobby_Nobble - I ended up putting this to use in node red - worked perfectly - thanks again for the tip on states.media_player.kodi.attributes.media_content_type == “movie”!
@Bobby_Nobble - take a look here for Node Red stuff - this guy put me on the right track - once I caught on - it’s been game on! http://diyfuturism.com/
That was who I followed to get started but found after the first simple description he suddenly leaps forward leaving out big chunks but talks like he’s explained it.
What I could really do with is something like the infamous turn your lights on at sunset automation in the HA docs that everybody uses to pick apart to see how they work, well those that can read or search do at least, rewritten for code red and uploaded somewhere handy so you can click on all the nodes and see what’s inside. All anyone seems to upload, understandably, are huge masterpieces of complex automation.
Not mine - but with my understanding of node red - looks pretty good for a baseline understanding of sunset/lighting actions.
node outputs and msg.payload and debug node are the key points for me when working with node red. a node produces a msg.payload and the data you want could be the payload or the msg.topic or another property (such as the kodi stuff you helped me with above - the kodi state node for HASS produced an object and I just had to drill down into the area you mentioned within that object to get the media type.). Then I use a switch node a lot to determine which ‘path’ I want to go down or look at current states and do ‘stuff’ with HASS etc. I hope that helps a bit - I LOVE node red, but I also have a heavy IT background with orchestration etc - so it makes sense to me even though I know very little javascript or node.js which I think node red uses quite a bit.
Thanks for that, I’ll give it a go. I have very limited programming knowledge but am perfectly capable when it revolves around logic and common sense or I have something similar that I can tweak I’m fine, when you need to ‘know stuff’ like this I come unstuck.
The first three work very well! But I have a serious problem. I can identify if the kodi is playing a movie or not. And I call automation (1), only if it’s a movie.
However, I have the addon (tvtunes) that reproduces the themes of the movies (audio.mp3), at that moment I have problem … Because when it stops playing, it is called automation (3) … No I can use the template to identify movie, because if I use it always will be false after stop.
I need the help of the gentlemen … If there is no solution I will have to deactivate the execution of themes of the films and tvshows …
I believe someone on here has posted about having a esp8266 in a vehicle. Hooked up to ign/usb port so when its turns on, it takes ~ 10 to connect to wifi network and automate garage door open, when signal is lost the automation then shuts the door, same as if they came home and would open faster since the device is booted. and when parked in garage and off the delay on automation would shut the garage door.
