Your installation is unhealthy - help needed
Is there no way to bypass the warning or smth?
HomeKit will not work. There is an addon for Homebridge that adds support for Haier ACs, so Homebridge is used as an intermediary to talk to my air conditioner split system. I did start trying to create my own custom component for Hass, reverse engineering HB JS addon into Python, but in the end I did not have time to complete that project. You can read more about Haier ACs here: Haier AC integration
In the worst case yes I will migrate it. But I have a HUGE problem with this. Because this is an artificial limitation imposed on the user, as far as I understand it. Because it’s “Unsupported”. IMO the correct approach would’ve been to warn the user but let me proceed with the update and everything. Because I’m pretty sure that if I could force the update it would just keep working fine. But I can’t run the update just because developers are being overcautious, even though I am already running a ‘community supported, use at your own risk’ installation method. By running it this way I have already accepted the risks and I know that it may be unstable, and that I will have to deal with any problems myself.
I think this is either just a redundant limitation that has to be removed, or they are deliberately doing this to further discourage people from using this installation method. I don’t see any other reason for this limitation.
