Thank you for your reply and for the wonderful add-on.
So, I won’t be able to use it because all the players in my house are Alexa. I’ll keep an eye on the add-on to see if it will ever support Alexa. Very sad, but that’s part of it.
@JKW
I know that playing on Alexa is not easy, however, it seems that this project has managed to do it: GitHub - rosskouk/asknavidrome: An Alexa skill to allow streaming of music from Subsonic API compatible media servers on Amazon Echo devices.
Unfortunately my knowledge is limited. Could you take a look?
Hi, that is great. Would be awesome to have an Alex Homeassistent skill like that.
Unfortunately I also don’t have Alexa skill skills
But once you can send a URL to Alex it should work with this integration
Jkw
Hi, I’ve got a quick question. when I execute this action: ytube_music_player.search
nothing happens eventually. So I’m missing some other action to stream it to my Nest device, or not?
hi
is it work with sonos?
when i try to play a playlist from youtube, sonos go to “paused”
Is anyone having issues recently with this integration?
When I click play it starts up but skips through the tracks not playing anything and then turns off.
Tried reinstalling a couple of times. Might try uninstalling the mini media player.
Yes, something changed on YouTube
Will a new version be released to fix the issue?
New version out today and works fine ! Thanks
I’m still having issues unfortunately even with the new version. The integration seems to all be connected and playing normally but no sound is coming out. If I adjust the volume on the chromecast speaker the volume button on the integration adjust accordingly and it says it is playing but no sound.
Very odd
sadly it seems to be broken again, unknown error pulling in media. Tried re-authorising, redownloading, rebooting etc.
No such luck yet.
Has anyone else experienced the same? Maybe my firewall blocking the communication as I have been updating my network with all omada stuff.
Yes look at the git hub they are trying to repear it.
Appears fixed now but Google Cast is broken so willl not cast to my player although it appears to be playing on the dash.
Anyone having issues with Cast integration?
No, it s ok for me.
I have homeassistant as an lxc on proxmox on vlan 20 and also the sony chromecast bluetooth speaker is on vlan 20. So if they are on the same subnet I can’t work out why chromecast is not detecting it.
Sony SRS-X77
Does the homeassistant lxc need to be unprivileged?
Hello, since this morning the integration doesn’t work. See that in log :
use_po_token=True
to view. See more details at Added PoToken support by felipeucelli · Pull Request #209 · JuanBindez/pytubefix · GitHubI am getting this error,
can’t find header file at /config/.storage/header_ytube_music_player.json
can someone help me out?
An other issue with this intégration ? It didn’t work since this mornig.
I’m also getting the 'can’t find header file at /config/.storage/header_ytube_music_player.json" error
The issue on Github about it has been closed saying you can just reconfigure the integration but that hasn’t worked for me
