Z-Wave event not showing in History or Logbook
I have set up Hassio on an RPi 2, with a Z-Wave USB stick and 2 Z-Wave sensors: a door sensor and a motion sensor.
Events from the door sensor do not appear in the Hassio Logbook or History, however I can see them in the OZW log (Configuration -> Z-Wave -> OZW Log). E.g from the OZW log I see this:
2017-09-06 11:04:45.137 Detail, Node010,   Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x0a, 0x03, 0x20, 0x01, 0xff, 0x25
2017-09-06 11:04:45.138 Info, Node010, Received Basic set from node 10: level=255. Treating it as a Basic report.
2017-09-06 11:04:45.138 Detail, Node010, Initial read of value
2017-09-06 11:04:45.138 Detail, Node010, Notification: ValueChanged
In Logbook, node 10 (“Front Door”) is always listed as “Sleeping”, with no events appearing around 11:04 (or at any time).
I tried removing and re-adding the node. I have restart and rebooted several times. I have this added as a Secure Node if that makes a difference.
Any suggestions on how I can debug this?
Note, that events from the motion sensor work fine and appear in the Logbook and History.
Cheers,
Justin
Hardware info:
USB Stick: Aeotec DSA02203 Z-Stick S2
Door Sensor: Aeotec ZW089 Recessed Door Sensor Gen5
Motion Sensor: Fibaro FGMS001 Motion Sensor
I found a similar post a bit too late! Hopefully this advice helps…
