Just for the record, it may not be worth investing a lot of time in this unless you have no other way to access your ZWave devices as the trend is to move away from OZW and move the basic management of ZWave into HA natively.
This is why you have seen the changes in the last two releases; @balloob has been working with the other core devs on trying to get full zwave management support into HA directly. This issue posting in github lays out his plan:
but… but… my alarm system is not working right now. it has been down for more than 2 days. can i get it up first then we can slowly move to the new system.
actually, thanks for sharing that. glad to know HA is taking z-wave into its own hand. I really hope this will prevent this issue from happening again.
anyway, I have notice the step git checkout python3 is gone from the guide. so does that mean i can skip that step and re-perform all the steps?
You might want to try an appeal on Gitter chat; usually a few higher level coders hanging out and someone may be able to shed some light on it. You have the knowledge and experience to explain your problem well so I’m sure someone would jump in to help.
I’ve visited a few times and I’ve seen folks there that hadn’t even bothered to research their issue and they were treated friendly enough; you’re certainly way above that crowd. I wish I could help more myself; doing it as an AIO install, I’ve bypassed having to install and config all of the OZWCP stuff so it remains mostly a black box to me. It works and works reliably so I try not to screw with it.
That’s about the best I can offer beyond some of these links I found in my research - maybe one of them will lead to a breakthrough? They aren’t HA but I’m thinking the concepts may lead to some discovery or relation…
Has anyone had anymore luck with this? I can’t seem to find a definitive answer to fix it. I’ve even tried the latest Hassbian image with no luck. Any help would be amazing as Zwave is integral to my setup.
Yeah this new process worked for me also and I did not have to go through the process that arviragu did. Worked as documented after running hassbian-config.
Thanks BendedArrow for posting that link
BTW. This also fixed my thermostat issue I had earlier which I know that problem is posted somewhere else here in the forum but I thought I would just mention it here in case someone here had that problem.
