Yes of course!
Please note that in the meantime I have extended it a bit.
My config looks like this now:
I assume by config you mean the export of nodered, please find it below:
"id": "413b8e96.cea24",
"type": "tab",
"label": "KeyFob",
"disabled": false,
"info": ""
"id": "8c3ab51f.0fa7e8",
"type": "server-events",
"z": "413b8e96.cea24",
"name": "",
"server": "aae67f2b.00539",
"event_type": "zwave_js_event",
"exposeToHomeAssistant": false,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"waitForRunning": true,
"x": 220,
"y": 560,
"wires": [
"1c44fcd3.d29ca3"
"id": "1c44fcd3.d29ca3",
"type": "switch",
"name": "IsKeyFob?",
"property": "payload.event.node_id",
"propertyType": "msg",
"rules": [
"t": "eq",
"v": "39",
"vt": "num"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 430,
"y": 560,
"wires": [
"e6d9d24d.0f7ff"
"id": "e6d9d24d.0f7ff",
"type": "switch",
"name": "WhatKeyAction?",
"property": "payload.event.value",
"rules": [
"t": "eq",
"v": "KeyHeldDown",
"vt": "str"
"t": "eq",
"v": "KeyPressed",
"vt": "str"
"t": "eq",
"v": "KeyReleased",
"vt": "str"
"checkall": "false",
"repair": false,
"outputs": 3,
"x": 610,
"y": 560,
"wires": [
"8b7cbbd8.1b4548"
"cc2defe8.13e86"
"7f2f8b8f.1bdce4"
"id": "cc2defe8.13e86",
"type": "switch",
"name": "WhichKeyWasPressed?",
"property": "payload.event.property_key_name",
"rules": [
"t": "eq",
"v": "001",
"vt": "str"
"t": "eq",
"v": "002",
"vt": "str"
"t": "eq",
"v": "003",
"vt": "str"
"t": "eq",
"v": "004",
"vt": "str"
"t": "eq",
"v": "005",
"vt": "str"
"t": "eq",
"v": "006",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 6,
"x": 870,
"y": 560,
"wires": [
"f68443d4.601f9"
"137c17cf.cfa4d8"
"b3c22a8c.f4bf58"
"5bc87326.c0530c"
"5b46782c.99ac18"
"2186b1f9.a8aa3e"
"id": "f68443d4.601f9",
"type": "api-call-service",
"name": "Turn On Indoor Lights",
"version": 1,
"debugenabled": false,
"service_domain": "light",
"service": "turn_on",
"entityId": "light.plant_current_value_7, light.backdoor_current_value_6, light.window_current_value, light.stairway_current_value_4, light.kitchen_current_value, light.dining_current_value_14, light.frontwindow_current_value_3",
"data": "",
"dataType": "jsonata",
"mergecontext": "",
"output_location": "",
"output_location_type": "none",
"mustacheAltTags": false,
"x": 1200,
"y": 420,
"wires": [
"id": "b3c22a8c.f4bf58",
"name": "Turn On Garden",
"version": 1,
"service_domain": "switch",
"entityId": "switch.outdoor_current_value_2_2",
"data": "",
"mergecontext": "",
"x": 1180,
"y": 540,
"wires": [
"id": "5bc87326.c0530c",
"name": "Turn Off Garden",
"version": 1,
"service": "turn_off",
"data": "",
"mergecontext": "",
"x": 1180,
"y": 600,
"wires": [
"id": "137c17cf.cfa4d8",
"name": "Turn Off Indoor Lights",
"version": 1,
"data": "",
"mergecontext": "",
"x": 1200,
"y": 480,
"wires": [
"id": "5b46782c.99ac18",
"name": "Fully Close Sunshade",
"version": 1,
"service_domain": "cover",
"service": "close_cover",
"entityId": "cover.sunshade_current_value",
"data": "",
"mergecontext": "",
"x": 1200,
"y": 660,
"wires": [
"id": "2186b1f9.a8aa3e",
"name": "Fully Open Sunshade",
"version": 1,
"service": "open_cover",
"data": "",
"mergecontext": "",
"x": 1200,
"y": 720,
"wires": [
"id": "8b7cbbd8.1b4548",
"type": "switch",
"name": "WhichKeyIsHeldDown?",
"rules": [
"t": "eq",
"v": "001",
"vt": "str"
"t": "eq",
"v": "002",
"vt": "str"
"t": "eq",
"v": "003",
"vt": "str"
"t": "eq",
"v": "004",
"vt": "str"
"t": "eq",
"v": "005",
"vt": "str"
"t": "eq",
"v": "006",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 6,
"x": 870,
"y": 240,
"wires": [
"ab5c46fe.115e28"
"cea75ddd.40ba3"
"id": "ab5c46fe.115e28",
"name": "Close Sunshade",
"version": 1,
"data": "",
"mergecontext": "",
"x": 1180,
"y": 220,
"wires": [
"id": "cea75ddd.40ba3",
"name": "Open Sunshade",
"version": 1,
"data": "",
"mergecontext": "",
"x": 1180,
"y": 280,
"wires": [
"id": "7f2f8b8f.1bdce4",
"type": "switch",
"name": "WhichKeyWasReleased?",
"rules": [
"t": "eq",
"v": "001",
"vt": "str"
"t": "eq",
"v": "002",
"vt": "str"
"t": "eq",
"v": "003",
"vt": "str"
"t": "eq",
"v": "004",
"vt": "str"
"t": "eq",
"v": "005",
"vt": "str"
"t": "eq",
"v": "006",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 6,
"x": 870,
"y": 840,
"wires": [
"5e103c50.1e80f4"
"5e103c50.1e80f4"
"id": "5e103c50.1e80f4",
"name": "Stop Closing/Opening Sunshade",
"version": 1,
"service": "stop_cover",
"data": "",
"mergecontext": "",
"x": 1220,
"y": 860,
"wires": [
"id": "aae67f2b.00539",
"type": "server",
"name": "Home Assistant",
"addon": true
In order to make this work on your end probably only thing you need to do is change the node Id in the “IsKeyfob?” check to the node id of your keyfob and update the relevant actions (lights/sunshade, etc.)
